MS Mid-Mount Mounting Brackets
Overview
Meraki offers mid‑mount mounting brackets that allow supported MS switch models to be mounted closer to the center of a 2‑post rack. This mounting option is useful for shallow racks or back‑to‑back rack configurations, where switches are installed on both sides of the rack with their rear panels facing each other. Mid‑mount brackets help improve stability, balance, and clearance in these installation scenarios.
Compatible Switch Models
MS120/125 (except the 8‑port models), MS130 (except the 8‑port and 12‑port models), MS150‑48 port models, and MS210/225/250 models are compatible with the MA‑MNT‑MID‑1 mid‑mount mounting bracket for use in 2‑post rack installations.
Mounting
Brackets
Front View
Rear View
