How to Assign a Static IP Address to a Switch
Overview
By default, when you set up a switch, it tries to attain connectivity via DHCP. You can also configure a static IP address through the Cisco Meraki dashboard or through the local configuration page.
If a static assignment fails, the switch automatically falls back on DHCP for its IP assignment.
Learn more with this free online training course on the Networking Learning Hub:
Step-by-step instructions
Configure a static IP address via dashboard
Navigate to Switch > Monitor > Switches.
Select the appropriate switch.
Select the pencil icon next to LAN IP.
Configure a static IP address via local IP assignment
Connect a client to the MS. Access the local status page via any ethernet port on the device.
Once you obtain an IP address, browse to the URL switch.meraki.com.
Select Uplink Configuration.
Enter your login credentials when prompted. If local login credentials were configured via dashboard, use these credentials. Otherwise, the default login is the device's serial number as the username and a blank password. Each device is labeled with its serial number on the bottom label.
On the Uplink Configuration page, set the needed connection information.
