How to Configure Power Settings
Click 日本語 for Japanese
Overview
The Power Settings page for Wireless in the Cisco Meraki dashboard includes all settings that control how an access point (AP) consumes power. You can choose a preset profile to control AP behavior when the AP operates in degraded PoE mode.
Use case
In PoE negotiation, the AP would request a certain power budget from the switch that is supplying PoE power.
  • If the switch is able to meet the request of the AP, the AP will proceed to enable all of its functionality and assume normal operation.
  • However, if the switch cannot meet the power budget requested by the AP, the AP will turn off certain functions in order to operate within the power budget that is offered by the switch, this is known as degraded PoE mode.
Degraded PoE profiles let users set power-saving options when the AP is operating in degraded PoE mode. Users can apply one profile to all devices of the same model in a network. Each profile is based on device model power constraints. Supported models are CW9178I, CW9176I, and CW9176D1.
Step-by-step instructions
Configuration
To select a different profile:
  1. In the dashboard, go to Wireless > Configure > Power Settings.
  2. Select the tab for the device model.
  3. Select the profile that matches your degraded PoE needs and preferred interfaces.
This image is displayed to show where to access Degraded PoE Profiles in the Wireless > Configure > Power Settings menu.
  • All networks will have default profiles set for all models initially. Customers have the option to select a different profile depending on their degraded PoE needs and preferred interfaces.
  • Each tab on the Power Settings page represents a device model in the network. The available tabs are CW9178I, CW9176I, and CW9176D1. Settings become available after you add a compatible device to the network.
    This image is displayed to illustrate that device-specific tabs, such as CW9178I, CW9176I, and CW9176D1, appear only when compatible devices are present in the wireless network.
  • Available power profiles:
    • CW9178I
      Profile Name
      Interface
      Value
      Default Profile
      2.4GHz
      2x2
      5GHz-1
      2x2 (Quad Radio), Disabled (Tri-Radio)
      5GHz-2
      2x2 (Quad Radio), 4x4 (Tri-Radio)
      6GHz
      2x2
      Ethernet 0
      2500 Mbps
      Ethernet 1
      2500 Mbps
      USB
      Disabled
      Tri-Radio
      2.4GHz
      2x2
      5GHz-1
      Disabled
      5GHz-2
      4x4
      6GHz
      2x2
      Ethernet 0
      2500Mbps
      Ethernet 1
      2500Mbps
      USB
      Disabled
      Dual Radio, Single Ethernet
      2.4GHz
      4x4
      5GHz-1
      Disabled
      5GHz-2
      4x4
      6GHz
      Disabled
      Ethernet 0
      10000Mbps
      Ethernet 1
      100Mbps
      USB
      Disabled
      Dual Radio, Dual Ethernet
      2.4GHz
      4x4
      5GHz-1
      Disabled
      5GHz-2
      4x4
      6GHz
      Disabled
      Ethernet 0
      1000Mbps
      Ethernet 1
      1000Mbps
      USB
      Disabled
    • CW9176I and CW9176D1
      Profile Name
      Interface
      Value
      Prioritize 5 & 6 GHz (Default)
      2.4GHz
      2x2
      5GHz
      4x4
      6GHz
      4x4
      Ethernet
      2500 Mbps
      USB
      Disabled
      Prioritize 2.4 & 5 GHz
      2.4GHz
      4x4
      5GHz
      4x4
      6GHz
      2x2
      Ethernet
      2500 Mbps
      USB
      Disabled
      Prioritize 2.4 & 6 GHz
      2.4GHz
      4x4
      5GHz
      2x2
      6GHz
      4x4
      Ethernet
      2500 Mbps
      USB
      Disabled
