IPv6 Support on MR Access Points
This article describes general information on IPv6 Support on MR access points. Please see IPv6 Device Compatibility documentation for more information on compatible devices.
Overview
This document describes the functionality, configuration, and caveats of the IPv6 feature set on MR access points.
Note: Only IPv6 functionality that is explicitly listed in this document is currently supported.
Note: The mandatory DHCP option (Wireless > Configure > Access Control) must be disabled for IPv6-only or dual-stack (IPv4/IPv6) clients connected to a Bridge mode SSID to have IPv6 connectivity.
Minimum Firmware Requirements
IPv6 support on MR access points was added in MR 28.1 firmware, with minimal IPv6 support in MR 27.X. Therefore, the minimum firmware for the IPv6 support on MR access points is MR 28.1. As new IPv6 features are developed, they might have different minimum firmware requirements. This document breaks down IPv6 MR features supported in specific MR firmware releases.
Note: Since most of the IPv6 features listed in this document are firmware-dependent and require MR 28.1 or newer firmware, We suggest that you create and modify your wireless Meraki networks to ensure that all APs can run MR 28.X firmware. For example, if you have an older AP in the network that cannot run MR 28 firmware, some features might not work. Please refer to Product Firmware Version Restrictions for details on maximum runnable firmware on MR access points.
Warning: If a network where any MR IPv6 features are configured (for example, Layer 3 IPv6 firewall rules) is downgraded to MR 27.X or older firmware, this might result in a loss of IPv6 configuration or functionality on MR access points.
MR 27.X and Older Firmware Releases
Wireless IPv6 Bridging
Network-wide > Configure > General > Wireless IPv6 Bridging has two options - Disabled and Enabled.
When set to “Enabled”, MR will pass IPv6 traffic to clients connected to a Bridge mode SSID, MR Tools like Ping and Traceroute will work for IPv6 traffic, and MR will be able to use its IPv6 management address to check-in to the Dashboard over an IPv6-only upstream network.
When set to “Disabled”, MR will not pass IPv6 traffic to clients connected to a Bridge mode SSID, and MR Tools like Ping and Traceroute will not work for IPv6 traffic. However, MR will be able to use IPv6 on the uplink for management and Meraki dashboard connectivity purposes.
Note: Layer 7 rules rely on the NBAR (Network-Based Application Recognition) classification engine. Traffic classification is agnostic to IPv4 or IPv6, as NBAR identifies traffic flows using source IP, source port, destination IP, destination port, and protocol—where both source and destination IP addresses can be either IPv4 or IPv6. This means that if your network meets NBAR requirements from the firmware (MR 27.X+) and hardware perspective and NBAR is not explicitly disabled Layer 7 rules may block IPv6 traffic based on NBAR classification. For more information about NBAR, see this documentation.
HTTP hostname, Port, Remote IP range, Remote IP range & port L7 categories do not rely on NBAR classification engine and will not block IPv6 traffic.
MR 28.X Firmware Release - Supported IPv6 Features
MR 28.X firmware added support for the following IPv6 features:
  • MR live tools IPv6 support
    • Ping
    • Traceroute
  • MR Uplink IPv6 Configuration Options
    • Stateless address configuration (SLAAC)
    • Static IPv6 address assignment via dashboard
    • Static IPv6 address assignment via local status page
  • Layer 3 IPv6 Firewall Rules
  • IPv6 RADIUS Support
  • LDAP over IPv6
  • Walled Garden IPv6 Support
  • RA and DHCPv4/DHCPv6 Guard Support
  • Active Directory over IPv6
  • SNMP polling via their IPv6 LAN address of MR access points
  • IPv6 Event Types in the Event Log
  • Syslog over IPv6
  • Meraki Health IPv6 Support
Please refer to MR 28.X Firmware Release - Supported IPv6 Features for more details.
MR 29.X Firmware Release - Supported IPv6 Features
MR 29.X firmware added support for the following IPv6 features:
  • MR uplink duplicate address detection (DAD) failover address
  • Layer 2 Wireless Client Isolation IPv6 support
  • Multicast to Unicast Conversion and IPv6 Multicast Listener Discovery (MLD) Snooping
  • HotSpot 2.0 Unsolicited Neighbor Advertisements (NAs) Filtering
  • IPv6 Bonjour Forwarding
Please refer to MR 29.X Firmware Release - Supported IPv6 Features for more details.
MR 30.X Firmware Release - Supported IPv6 Features
MR 30.X firmware added support for the following IPv6 features:
  • IPv6 Packet fragmentation with WPN
  • Fast roaming support in IPv6-only networks
  • Distributed L3 roaming for IPv6-only clients on IPv4-only and dual-stack APs
  • IPv6 address assignment for Alternate Management Interface
Please refer to MR 30.X Firmware Release - Supported IPv6 Features for more details.
