Data Types
Data Types
The following base types of data can be used in variables:
| Type | Description |
             Default Value  |
| Boolean | Represents true or false values. |
             false  |
| Date Time |
             Represents a timestamp including a date and time. Supported formats:
             0001-01-01T00:00:00+00:00  |
| Decimal | Numbers with a decimal point, such as 4.5. |
             0.0  |
| Integer | Whole numbers with no decimals. |
             0  |
| Large String | Strings that can be up to 10 MB in size. |
             "" (null string)  |
| Secure String | Encrypted strings that are masked for security purposes. |
             "" (null string)  |
| String |
             Text containing any combination of characters. Enter value by string type; HTML, JSON, Markdown, text, Python, XML, or YAML. String can be up to 1 MB in size.  |
             "" (null string)  |
| Table |
             Contains rows and columns of structured data, like an Excel spreadsheet. Tables can be up to 1 MB in size.  |
             N/A  |
| Custom Table Type | Custom tables with a pre-defined structure. |
             N/A  |
             Group together various base types of data into an object variable.  |
             {} (null object)  |
             Array containing multiple elements or objects into an array variable.  |
             [] (null array)  |
