Home > General Administration > Tools and Troubleshooting > Installing and using Wireshark for packet captures on a client device
Table of contents
No headers
Wireshark is a utility that will display the packets seen by a device. Packets contain the data that is transmitted between computers. Viewing this information can often aid in the diagnosis of issues that may be occurring in a network. It is possible for a device to not see all packets transmitted on a network if a device is hardwired. In this instance, the device may only see broadcast packets and packets addressed to itself due to the functionality of modern networking equipment.
Installation:
Please visit Wireshark's download page to download Wireshark. When downloading, simply follow the prompts.
Taking a Capture:
  1. Open Wireshark.
  2. Select a capture interface. This will either be your wireless interface or your local area connection.
  3. Click start. This will take you to a new window that will show the packets that the device is picking up.
  4. When the desired packets have been obtained click stop.
  5. Save the capture with a distinct name.
In certain instances, it can be beneficial to filter a capture for a specific clients IP address or for a specific type of traffic. This filtering can be done prior to the capture as well as after the capture. If this is required, a support technician will inform you of the filter that he would like you to apply. This filter is applied in the filter box in Wireshark.
  1. Select the filter box.
  2. Input filter string as provided by support engineer.
  3. Click "Apply".
  4. To save the filtered data, go to File -> Export Specified Packets...
  5. Make sure that the "Displayed" radio button is checked and that the file has a unique filename. Once this is complete, select "Save".
You must to post a comment.
Last modified
08:40, 3 Feb 2015
Tags
This page has no custom tags.
Classifications
Article ID
Contact Support
Open a Case
