Home > General Administration > Tools and Troubleshooting > Using Wireshark for Packet Captures
Wireshark is a utility that will display the packets seen by a device. Packets contain the data that is transmitted between computers. Viewing this information can often aid in the diagnosis of issues that may be occurring in a network. It is possible for a device to not see all packets transmitted on a network if a device is hardwired. In this instance, the device may only see broadcast packets and packets addressed to itself due to the functionality of modern networking equipment.
Please visit Wireshark's download page to download Wireshark. When downloading, simply follow the prompts.
Taking a Capture
  1. Open Wireshark.
  2. Setup the desired capture interface.
    1. Click Capture Options.
    2. Uncheck "Enable promiscuous mode on all interfaces", check the "Promiscuous" option for your capture interface and select the interface.
    3. Optional. Rolling captures can be configured if required. This option will allow packets to be captured continuously without filling up the storage on your device.
      1. In the "Output" tab, click "Browse...".
      2. Enter a filename in the "Save As:" field and select a folder to save captures to. Click Save.
      3. Select "Create a new file automatically after..." and "Use a ring buffer with x files". This creates a maximum of number of files, with each file set to the size or timeframe configured. For example, creating a new file automatically after 32 megabytes, with a ring buffer of 128 files, will provide 4 gigabytes of rolling captures.
    4. Click start. This will take you to a new window that will show the packets that the device is picking up.
  3. When the desired packets have been obtained click stop.
  4. Save the capture from the "File menu" with a distinct name.
In certain instances, it can be beneficial to filter a capture for a specific client's IP address or for a specific type of traffic. This filtering can be done prior to the capture as well as after the capture. If this is required, a support technician will inform you of the filter that he would like you to apply. This filter is applied in the filter box in Wireshark.
  1. Select the filter box.
  2. Input filter string as provided by support engineer. Click the "Apply" button.
  3. To save the filtered data, go to File -> Export Specified Packets...
  4. Make sure that the "Displayed" radio button is checked and that the file has a unique filename. Once this is complete, select "Save".
Last modified
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
