Small-Form Factor Pluggable (SFP) and Stacking Accessories
This article provides technical data on Fiber Transceivers and stacking accessories compatible with Meraki devices.
Cisco Meraki offers branded SFP modules, and while we do not prevent third-party accessories from functioning, users should conduct their own tests to ensure proper compatibility
Cisco Optics Compatibility
Many of the Cisco Optics that are compatible* with the native Catalyst Switch platform (ex. C9300-24S) are also compatible with the corresponding Cloud Managed/Monitored Catalyst Switch Platform (ex.: C9300-24S-M) including the MS390.
• This includes: 1/10/25/40/100G SFP/QSFP fixed wavelength fiber and copper transceivers,
• Please reference the TMGmatrix for Cisco's official optic-to-device compatibility list.
  • Click this LINK for a filtered list of all optics for C9300/C9300L/C9300X platforms.
  •  Cisco secure routers C8325, C8335 or C8445.
• These compatible optics are covered under the existing Cisco Warranty terms available here
• Meraki support is able to assist with troubleshooting, identifying, and root-causing the issues where the Cisco Optics are being used with their cloud managed/monitored catalyst Switch
• However, if the root cause indicates that the customer is eligible for an RMA, support will continue to follow established procedures for Cisco branded optics, which may include collaborating with Cisco TAC
Note: Validation of dashboard reporting of Cisco Optics is ongoing. In the event Meraki Support identifies an issue with a Cisco Optic, a support case may be filed for further investigation.
Other non-M accessories
Other accessories such as fan spares, power stacking cables, stackwise cables and power supplies are compatible* between non-M and -M models.
Some Examples :
  • STACK-T1-50CM is compatible with STACK-T1-50CM-M
  • CAB-SPWR-30CM is compatible with CAB-SPWR-30CM-M
  • FAN-T2 is compatible with FAN-T2-M
  • PWR-C1-1100WAC-P is compatible with PWR-C1-1100WAC-P-M
* Compatibility/ Compatible: The hardware accessory has been determined to operate effectively with the listed switch platforms, and will receive troubleshooting assistance from Cisco Meraki Support in the event of an issue experienced with the hardware. However, in the event of a hardware replacement requirement an additional step may be required to facilitate the RMA which would require collaboration with Cisco TAC under the Cisco warranty terms. Meraki’s hardware warranty and return policy and Meraki EOL policy does not apply to Cisco Optics, Cables and accessories in any shape or form.
C8455-G2-MX: The compatible SFP modules  on the C8455-G2-MX can be found in the Here.
Note: regarding switches series
If not specified otherwise, all switches below under "Compatibility" columns, include any model within the series, for example, MS120 on the table represents:
  • MS120-24-HW
  • MS120-24P-HW
  • MS120-48-HW
  • MS120-48LP-HW
  • MS120-48FP-HW
Transceivers List
1G
Meraki 1000Base SX Multi-Mode
Meraki Product ID Standard Wavelength (nm) Fiber Type Fiber Description Core/ Clad Diameter Jacket Color Max Distance Data Rate Compatibility
MA-SFP-1GB-SX 1000BASE-SX 850 MMF OM1 62.5 μm / 125 μm Orange 220 m Gigabit
MX75 /  MX84   MX85 /  MX95
MX100 /  MX105  MX250 / MX400  MX450 /  MX600
MS120 /  MS125
MS130 / MS150 / MS210 / MS225  MS250 / MS350   MS355
MS390 / C9300*
MS410 /  MS425
MA-SFP-1GB-SX 1000BASE-SX 850 MMF OM2 50 μm / 125 μm Orange 550 m Gigabit
MX100 /  MX105    MX250 / MX400 . MX450 /  MX600
MS120 /  MS125
MS390 / C9300*
MS410 /  MS425
MA-SFP-1GB-SX 1000BASE-SX 850 MMF OM3 50 μm / 125 μm Aqua 550 m Gigabit
MS120 /  MS125
MS130  / MS150 / MS210  MS225 /  MS250
MS350 /  MS355
MS390 / C9300*
MS410 /  MS425
MA-SFP-1GB-SX 1000BASE-SX 850 MMF OM4 50 μm / 125 μm Aqua 1 km Gigabit
MS120 /  MS125
MS350 /  MS355
MS390 / C9300*
MS410 /  MS425
* All C9300 series are included.
Meraki 1000Base LX10 Single-Mode
MA-SFP-1GB-LX10 1000BASE-LX10 1310 SMF OS1/OS2 9 μm / 125 μm Yellow 10 km Gigabit
MX100 / MX105 MX250 / MX400 MX450 / MX600 / C8455-G2-MX
MS120 / MS125
MS390 / C9300*
MS410 / MS425
MA-SFP-1GB-LX10 1000BASE-LX10 1310 MMF with LC mode conditioning
cable
N/A Yellow / Orange 550 m Gigabit
MX100 / MX105  MX250 / MX400  MX450 / MX600 / C8235-G2-MX / C8355-G2-MX / C8455-G2-MX
MS120 / MS125
MS390 / C9300*
MS410 / MS425
Meraki 1 GbE SFP Copper Module (RJ45)
MA-SFP-1GB-TX 1000BASE-T N/A N/A N/A N/A N/A 100 m Gigabit
All MXes and C8k-G2-MX
All MSes, except MS130R and Catalyst
Not supported by MS390/
C9300/X/L
10G
Meraki 10G Base SR Multi-Mode
MA-SFP-10GB-SR 10GBASE-SR 850 MMF OM1 62.5 μm / 125 μm Orange 26 m 10 Gigabit
MX95 / MX105
MX250 / MX400
MX450 / MX600 / C8455-G2-MX / C8355-G2-MX / C8235-G2-MX
MS125 / MS130-X / MS150-4X /
MS225 / MS250
MS350 / MS355
MS390 / C9300*
MS410 / MS425
MA-SFP-10GB-SR 10GBASE-SR 850 MMF OM2 50 μm / 125 μm Orange 82 m 10 Gigabit
MX95 / MX105
MX250 / MX400
MS225 / MS250
MS350 / MS355
MS390 / C9300*
MS410 / MS425
MA-SFP-10GB-SR 10GBASE-SR 850 MMF OM3 50 μm / 125 μm Aqua 300 m 10 Gigabit
MX95 / MX105
MX250 / MX400
MS225 / MS250
MS350 / MS355
MS390 / C9300*
 MS410 / MS425
MA-SFP-10GB-SR 10GBASE-SR 850 MMF OM4 50 μm / 125 μm Aqua 400 m 10 Gigabit
MX95 / MX105
MX250 / MX400
MS225 / MS250 MS350 / MS355
MS390 / C9300*
MS410 / MS425
Meraki 10G Base LR Single-Mode
MA-SFP-10GB-LR 10GBASE-LR 1310 SMF OS1/OS2 9 μm / 125 μm Yellow 10 km 10 Gigabit
MX95 / MX105
MX250 / MX400
MS225 / MS250
MS350 / MS355
MS390 / C9300*
MS410 / MS425
Meraki 10G Base LRM Multi-Mode
MA-SFP-10GB-LRM 10GBASE-LRM 1310 MMF OM1 62.5 μm / 125 μm Orange 220 m 10 Gigabit
MS225 / MS250
MS350 / MS355
MS390/C9300**
MS410 / MS425
C8235-G2-MX /
MA-SFP-10GB-LRM 10GBASE-LRM 1310 MMF OM2 50 μm / 125 μm Orange 220 m * 10 Gigabit
MS225 / MS250
MS350 / MS355
MS390/C9300**
MS410 / MS425
C8235-G2-MX /
MA-SFP-10GB-LRM 10GBASE-LRM 1310 MMF OM3 50 μm / 125 μm Aqua 220 m 10 Gigabit
MS225 / MS250
MS350 / MS355
MS390/C9300**
MS410 / MS425
C8235-G2-MX /C8355-G2-MX / C8455-G2-MX
MA-SFP-10GB-LRM 10GBASE-LRM 1310 SMF OS1/OS2 9 μm / 125 μm Yellow 300 m 10 Gigabit
MX95 / MX105 / MX250
MX400 / MX450 / MX600 / C8455-G2-MX / C8235-G2-MX / C8355-G2-MX / C8455-G2-MX
MS390/C9300**
MS225 / MS250
MS350 / MS355
MS410 / MS425
* Modal bandwidth at 500MHz/km
**NOTE: Catalyst 9300X switches do not support LRM modules.
Meraki 10G Base ER Module
MA-SFP-10GB-ER ** 10GBASE-ER 1550 SMF OS1/OS2 9 μm / 125 μm Yellow 40 km 10 Gigabit
MX95 / MX105
MX250 / MX450 / C8235-G2-MX / C8355-G2-MX / C8455-G2-MX
MS130-X / MS150-4X / MS225  MS250 / MS350  MS355
MS390 / C9300*
MS410 / MS425
** Please refer to the MS125 Overview and Specifications for additional compatibility data.
Meraki 10G Base ZR Module
MA-SFP-10GB-ZR 10GBASE-ZR 1550 SMF OS1/OS2 9 μm / 125 μm Yellow 80 km 10 Gigabit MX95 / MX105
MX250 / MX450
MS150-4X / MS225 / MS250
MS350 / MS355
MS410 / MS425
40G
Meraki SR4 QSFP 40G Transceiver
MA-QSFP-40G-SR4 QSFP - MPO12 850 MMF OM2, OM3, OM4 50 μm / - Aqua 30 m, 100 m, 150 m 40 Gigabit
MS355
MS390 / C9300*
MS425 / MS450
Meraki LR4 QSFP 40G Transceiver
MA-QSFP-40G-LR4
QSFP - LC 1310 SMF OS1, OS2 G.652 / - Yellow 10 km 40 Gigabit
MS355
MS390 / C9300*
MS425 / MS450
Meraki CSR4 QSFP 40G Transceiver
MA-QSFP-40G-CSR4
QSFP - MPO12 850 MMF OM2, OM3, OM4 50 μm / - Aqua 82 m, 300 m, 400 m 40 Gigabit
MS355
MS390 / C9300*
MS425 / MS450
Meraki SR-BD QSFP 40G Transceiver
MA-QSFP-40G-SR-BD QSFP - Duplex LC 832-918 MMF OM2, OM3, OM4 50 μm / - Aqua 30 m, 100 m, 150 m 40 Gigabit
MS355
MS390 / C9300*
MS425 / MS450
100G
Meraki LR4 QSFP 100G Transceiver
MA-QSFP-100G-LR4 100GBASE-LR4 1295, 1300, 1304, 1309 SMF OS1, OS2 G.652 / - Yellow 10 km 100 Gigabit MS450
Meraki SR4 QSFP 100G Transceiver
MA-QSFP-100G-SR4 100GBASE-SR4 850 MMF OM3, OM4/OM5 50 μm / - Aqua 70 m, 100 m 100 Gigabit MS450
Direct Attach
Meraki Product ID Standard Cable Length Assembly Type Data Rate Compatibility
MA-CBL-TA-1M 10GSFP+Cu 1 m Passive Twinax 10 Gigabit MX95 / MX105
MX250 / MX450 / C8355-G2-MX / C8455-G2-MX
MS125 / MS130-X/ MS150-4X / MS225 / MS250
MS350 / MS355 / MS390
 / C9300/C9300L/
MS410 / MS425
MA-CBL-TA-3M 10GSFP+Cu 3 m Passive Twinax 10 Gigabit MX95 / MX105
 / C9300/C9300L/
MS410 / MS425
Stacking Cables
MA-CBL-40G-50CM 40GQSFP+Cu 50 cm QSFP+ passive Twinax cable assembly 40 Gigabit MS210 / MS225 / MS250
MS350
MS410 / MS425
MA-CBL-40G-1M 40GQSFP+Cu 1 m QSFP+ passive Twinax cable assembly 40 Gigabit MS210 / MS225 / MS250
MS350
MS410 / MS425
MA-CBL-40G-3M 40GQSFP+Cu 3 m QSFP+ passive Twinax cable assembly 40 Gigabit MS210 / MS225 / MS250
MS350
MS410 / MS425
MA-CBL-100G-50CM 100GQSFP28 50 cm QSFP28 passive Twinax cable assembly 100 Gigabit MS150 / MS355 / MS450
MA-CBL-100G-1M 100GQSFP28 1 m QSFP28 passive Twinax cable assembly 100 Gigabit MS150 / MS355 / MS450
MA-CBL-100G-3M 100GQSFP28 3 m QSFP28 passive Twinax cable assembly 100 Gigabit MS150 / MS355 / MS450
MA-CBL-120G-50CM N/A 50 cm Cisco Meraki 120G stack cable 120 Gigabit (480G) MS390 / C9300*
MA-CBL-120G-1M N/A 1 m Cisco Meraki 120G stack cable 120 Gigabit (480G) MS390 / C9300*
MA-CBL-120G-3M N/A 3 m Cisco Meraki 120G stack cable 120 Gigabit (480G) MS390 / C9300*
STACK-T1-50CM-M N/A 50 cm
Catalyst 9300/X Stack Cable
480G / 1Tbps  C9300* / C9300X
STACK-T1-1M-M N/A 1 m Catalyst 9300/X Stack Cable 480G / 1Tbps C9300* / C9300X
STACK-T1-3M-M N/A 3 m Catalyst 9300/X Stack Cable 480G / 1Tbps C9300* / C9300X
C9300L-STACK-KIT2-M two uplink modules and one stacking cable 50 cm Catalyst 9300L
Stacking Kit
320G C9300L
STACK-T3A-50CM-M N/A 50 cm Catalyst 9300L Stacking Cable 320G C9300L
STACK-T3A-1M-M N/A 1 m Catalyst 9300L Stacking Cable 320G C9300L
STACK-T3A-3M-M N/A 3 m Catalyst 9300L Stacking Cable 320G C9300L
StackPower Cables
Meraki Product ID Cable Length Compatibility
MA-CBL-SPWR-30CM 30 cm MS390
MA-CBL-SPWR-150CM 1.5 m MS390
CAB-SPWR-30CM-M 30 cm C9300*, C9300X
CAB-SPWR-150CM-M 1.5 m C9300*, C9300X
Uplink Modules
MA-MOD-4x10G* 4-port 1/10G SFP+ Uplink module MS390, C9300
MA-MOD-8x10G 8-port 1/10G SFP+ Uplink module MS390, C9300
MA-MOD-2x40G 2-port 40G QSFP+ Uplink module MS390, C9300
C9300-NM-2Q-M 2-port 40G QSFP+ Uplink module C9300
C9300-NM-4X 4-port 10G/1G SFP+ Uplink module C9300
C9300-NM-8X-M 8-port 1/10G SFP+ Uplink module C9300
C9300-NM-2Y-M* 2-port 25G/10G/1G SFP28 Uplink module C9300
C9300X-NM-8Y-M* 8-port 25G/10G/1G SFP28 Uplink module C9300X***
C9300X-NM-2C-M** 2-port 100G/40G QSFP28 Uplink modules C9300X
Note: The MA-MOD-4x10G for the MS390 is end of sale. This includes the C9300-NM-4X, which is also supported but will not be available in a -M SKU.
*Note: The SFP28/QSFP28 modules will be orderable March 2024 with software support in CS16.7. 25Gbps Dashboard support is slated for CS17 firmware. 25Gbps optics can be used in CS16.8,  but should be considered 'Beta'.
**Note: The C9300X-NM-2C-M modules will operate at 40Gbps with software support in CS17 firmware.  For 100G operation, IOS-XE 17.15+ is required.
***Note: The number of Network Module ports are limited when C9300X-NM-8Y are used with the C9300X-48HXN models. Only 6 of the 8 ports will be available on a C9300X-48HXN switch.
C9300-NM-2Y-M / C9300-NM-2Y modules are supported only by C9300-24S/48S switches in firmware CS16.7. Support for the rest of the C9300-M portfolio is supported in CS16.8 firmware.
