Small-Form Factor Pluggable (SFP) and Stacking Accessories
Cisco Meraki offers branded SFP modules, and while we do not prevent third-party accessories from functioning, users should conduct their own tests to ensure proper compatibility
Cisco Optics Compatibility
Many of the Cisco Optics that are compatible* with the native Catalyst Switch platform (ex. C9300-24S) are also compatible with the corresponding Cloud Managed/Monitored Catalyst Switch Platform (ex.: C9300-24S-M) including the MS390.
• This includes: 1/10/25/40/100G SFP/QSFP fixed wavelength fiber and copper transceivers,
• Please reference the TMGmatrix for Cisco's official optic-to-device compatibility list. Click this LINK for a filtered list of all optics for C9300/C9300L/C9300X platforms
• These compatible optics are covered under the existing Cisco Warranty terms available here
• Meraki support is able to assist with troubleshooting, identifying, and root-causing the issues where the Cisco Optics are being used with their cloud managed/monitored catalyst Switch
• However, if the root cause indicates that the customer is eligible for an RMA, support will continue to follow established procedures for Cisco branded optics, which may include collaborating with Cisco TAC
Note: Validation of dashboard reporting of Cisco Optics is ongoing. In the event Meraki Support identifies an issue with a Cisco Optic, a support case may be filed for further investigation.
Other non-M accessories
Other accessories such as fan spares, power stacking cables, stackwise cables and power supplies are compatible* between non-M and -M models.
Some Examples :
- STACK-T1-50CM is compatible with STACK-T1-50CM-M
- CAB-SPWR-30CM is compatible with CAB-SPWR-30CM-M
- FAN-T2 is compatible with FAN-T2-M
- PWR-C1-1100WAC-P is compatible with PWR-C1-1100WAC-P-M
* Compatibility/ Compatible: The hardware accessory has been determined to operate effectively with the listed switch platforms, and will receive troubleshooting assistance from Cisco Meraki Support in the event of an issue experienced with the hardware. However, in the event of a hardware replacement requirement an additional step may be required to facilitate the RMA which would require collaboration with Cisco TAC under the Cisco warranty terms. Meraki’s hardware warranty and return policy and Meraki EOL policy does not apply to Cisco Optics, Cables and accessories in any shape or form.
C8455-G2-MX: The compatible SFP modules on the C8455-G2-MX can be found in the Here.
Note: regarding switches series
If not specified otherwise, all switches below under "Compatibility" columns, include any model within the series, for example, MS120 on the table represents:
- MS120-24-HW
- MS120-24P-HW
- MS120-48-HW
- MS120-48LP-HW
- MS120-48FP-HW
Transceivers List
1G
Meraki 1000Base SX Multi-Mode
| Meraki Product ID | Standard | Wavelength (nm) | Fiber Type | Fiber Description | Core/ Clad Diameter | Jacket Color | Max Distance | Data Rate | Compatibility |
| MA-SFP-1GB-SX | 1000BASE-SX | 850 | MMF | OM1 | 62.5 μm / 125 μm | Orange | 220 m | Gigabit |
MX75 / MX84 MX85 / MX95 MS390 / C9300* MS410 / MS425 |
| MA-SFP-1GB-SX | 1000BASE-SX | 850 | MMF | OM2 | 50 μm / 125 μm | Orange | 550 m | Gigabit |
| MA-SFP-1GB-SX | 1000BASE-SX | 850 | MMF | OM3 | 50 μm / 125 μm | Aqua | 550 m | Gigabit |
| MA-SFP-1GB-SX | 1000BASE-SX | 850 | MMF | OM4 | 50 μm / 125 μm | Aqua | 1 km | Gigabit |
* All C9300 series are included.
Meraki 1000Base LX10 Single-Mode
| MA-SFP-1GB-LX10 | 1000BASE-LX10 | 1310 | SMF | OS1/OS2 | 9 μm / 125 μm | Yellow | 10 km | Gigabit |
| MA-SFP-1GB-LX10 | 1000BASE-LX10 | 1310 | MMF | with LC mode conditioning cable |
N/A | Yellow / Orange | 550 m | Gigabit |
Meraki 1 GbE SFP Copper Module (RJ45)
| MA-SFP-1GB-TX | 1000BASE-T | N/A | N/A | N/A | N/A | N/A | 100 m | Gigabit |
All MXes Not supported by MS390/ |
10G
Meraki 10G Base SR Multi-Mode
| MA-SFP-10GB-SR | 10GBASE-SR | 850 | MMF | OM1 | 62.5 μm / 125 μm | Orange | 26 m | 10 Gigabit |
MX95 / MX105 MS390 / C9300* MS410 / MS425 |
| MA-SFP-10GB-SR | 10GBASE-SR | 850 | MMF | OM2 | 50 μm / 125 μm | Orange | 82 m | 10 Gigabit |
| MA-SFP-10GB-SR | 10GBASE-SR | 850 | MMF | OM3 | 50 μm / 125 μm | Aqua | 300 m | 10 Gigabit |
| MA-SFP-10GB-SR | 10GBASE-SR | 850 | MMF | OM4 | 50 μm / 125 μm | Aqua | 400 m | 10 Gigabit |
Meraki 10G Base LR Single-Mode
| MA-SFP-10GB-LR | 10GBASE-LR | 1310 | SMF | OS1/OS2 | 9 μm / 125 μm | Yellow | 10 km | 10 Gigabit |
Meraki 10G Base LRM Multi-Mode
| MA-SFP-10GB-LRM | 10GBASE-LRM | 1310 | MMF | OM1 | 62.5 μm / 125 μm | Orange | 220 m | 10 Gigabit |
MS225 / MS250 MS390/C9300** MS410 / MS425 |
| MA-SFP-10GB-LRM | 10GBASE-LRM | 1310 | MMF | OM2 | 50 μm / 125 μm | Orange | 220 m * | 10 Gigabit |
| MA-SFP-10GB-LRM | 10GBASE-LRM | 1310 | MMF | OM3 | 50 μm / 125 μm | Aqua | 220 m | 10 Gigabit |
| MA-SFP-10GB-LRM | 10GBASE-LRM | 1310 | SMF | OS1/OS2 | 9 μm / 125 μm | Yellow | 300 m | 10 Gigabit |
MX95 / MX105 / MX250 MS390/C9300** MS225 / MS250 MS410 / MS425 |
* Modal bandwidth at 500MHz/km
**NOTE: Catalyst 9300X switches do not support LRM modules.
Meraki 10G Base ER Module
| MA-SFP-10GB-ER ** | 10GBASE-ER | 1550 | SMF | OS1/OS2 | 9 μm / 125 μm | Yellow | 40 km | 10 Gigabit |
** Please refer to the MS125 Overview and Specifications for additional compatibility data.
Meraki 10G Base ZR Module
| MA-SFP-10GB-ZR | 10GBASE-ZR | 1550 | SMF | OS1/OS2 | 9 μm / 125 μm | Yellow | 80 km | 10 Gigabit | MX95 / MX105 MX250 / MX450 MS150-4X / MS225 / MS250 MS350 / MS355 MS410 / MS425 |
40G
Meraki SR4 QSFP 40G Transceiver
| MA-QSFP-40G-SR4 | QSFP - MPO12 | 850 | MMF | OM2, OM3, OM4 | 50 μm / - | Aqua | 30 m, 100 m, 150 m | 40 Gigabit |
MS355 MS390 / C9300* MS425 / MS450 |
Meraki LR4 QSFP 40G Transceiver
| MA-QSFP-40G-LR4 |
QSFP - LC | 1310 | SMF | OS1, OS2 | G.652 / - | Yellow | 10 km | 40 Gigabit |
Meraki CSR4 QSFP 40G Transceiver
| MA-QSFP-40G-CSR4 |
QSFP - MPO12 | 850 | MMF | OM2, OM3, OM4 | 50 μm / - | Aqua | 82 m, 300 m, 400 m | 40 Gigabit |
Meraki SR-BD QSFP 40G Transceiver
| MA-QSFP-40G-SR-BD | QSFP - Duplex LC | 832-918 | MMF | OM2, OM3, OM4 | 50 μm / - | Aqua | 30 m, 100 m, 150 m | 40 Gigabit |
100G
Meraki LR4 QSFP 100G Transceiver
| MA-QSFP-100G-LR4 | 100GBASE-LR4 | 1295, 1300, 1304, 1309 | SMF | OS1, OS2 | G.652 / - | Yellow | 10 km | 100 Gigabit | MS450 |
Meraki SR4 QSFP 100G Transceiver
| MA-QSFP-100G-SR4 | 100GBASE-SR4 | 850 | MMF | OM3, OM4/OM5 | 50 μm / - | Aqua | 70 m, 100 m | 100 Gigabit | MS450 |
Direct Attach
| Meraki Product ID | Standard | Cable Length | Assembly Type | Data Rate | Compatibility |
| MA-CBL-TA-1M | 10GSFP+Cu | 1 m | Passive Twinax | 10 Gigabit | MX95 / MX105 MX250 / MX450 MS125 / MS130-X/ MS150-4X / MS225 / MS250 MS350 / MS355 / MS390 / C9300/C9300L/ MS410 / MS425 |
| MA-CBL-TA-3M | 10GSFP+Cu | 3 m | Passive Twinax | 10 Gigabit | MX95 / MX105 MX250 / MX450 MS125 / MS130-X/ MS150-4X / MS225 / MS250 MS350 / MS355 / MS390 / C9300/C9300L/ MS410 / MS425 |
Stacking Cables
| MA-CBL-40G-50CM | 40GQSFP+Cu | 50 cm | QSFP+ passive Twinax cable assembly | 40 Gigabit | MS210 / MS225 / MS250 MS350 MS410 / MS425 |
| MA-CBL-40G-1M | 40GQSFP+Cu | 1 m | QSFP+ passive Twinax cable assembly | 40 Gigabit | MS210 / MS225 / MS250 MS350 MS410 / MS425 |
| MA-CBL-40G-3M | 40GQSFP+Cu | 3 m | QSFP+ passive Twinax cable assembly | 40 Gigabit | MS210 / MS225 / MS250 MS350 MS410 / MS425 |
| MA-CBL-100G-50CM | 100GQSFP28 | 50 cm | QSFP28 passive Twinax cable assembly | 100 Gigabit | MS150 / MS355 / MS450 |
| MA-CBL-100G-1M | 100GQSFP28 | 1 m | QSFP28 passive Twinax cable assembly | 100 Gigabit | MS150 / MS355 / MS450 |
| MA-CBL-100G-3M | 100GQSFP28 | 3 m | QSFP28 passive Twinax cable assembly | 100 Gigabit | MS150 / MS355 / MS450 |
| MA-CBL-120G-50CM | N/A | 50 cm | Cisco Meraki 120G stack cable | 120 Gigabit (480G) | MS390 / C9300* |
| MA-CBL-120G-1M | N/A | 1 m | Cisco Meraki 120G stack cable | 120 Gigabit (480G) | MS390 / C9300* |
| MA-CBL-120G-3M | N/A | 3 m | Cisco Meraki 120G stack cable | 120 Gigabit (480G) | MS390 / C9300* |
| STACK-T1-50CM-M | N/A | 50 cm |
Catalyst 9300/X Stack Cable |
480G / 1Tbps | C9300* / C9300X |
| STACK-T1-1M-M | N/A | 1 m | Catalyst 9300/X Stack Cable | 480G / 1Tbps | C9300* / C9300X |
| STACK-T1-3M-M | N/A | 3 m | Catalyst 9300/X Stack Cable | 480G / 1Tbps | C9300* / C9300X |
| C9300L-STACK-KIT2-M | two uplink modules and one stacking cable | 50 cm | Catalyst 9300L Stacking Kit |
320G | C9300L |
| STACK-T3A-50CM-M | N/A | 50 cm | Catalyst 9300L Stacking Cable | 320G | C9300L |
| STACK-T3A-1M-M | N/A | 1 m | Catalyst 9300L Stacking Cable | 320G | C9300L |
| STACK-T3A-3M-M | N/A | 3 m | Catalyst 9300L Stacking Cable | 320G | C9300L |
StackPower Cables
| Meraki Product ID | Cable Length | Compatibility |
| MA-CBL-SPWR-30CM | 30 cm | MS390 |
| MA-CBL-SPWR-150CM | 1.5 m | MS390 |
| CAB-SPWR-30CM-M | 30 cm | C9300*, C9300X |
| CAB-SPWR-150CM-M | 1.5 m | C9300*, C9300X |
Uplink Modules
| MA-MOD-4x10G* | 4-port 1/10G SFP+ Uplink module | MS390, C9300 |
| MA-MOD-8x10G | 8-port 1/10G SFP+ Uplink module | MS390, C9300 |
| MA-MOD-2x40G | 2-port 40G QSFP+ Uplink module | MS390, C9300 |
| C9300-NM-2Q-M | 2-port 40G QSFP+ Uplink module | C9300 |
| C9300-NM-4X | 4-port 10G/1G SFP+ Uplink module | C9300 |
| C9300-NM-8X-M | 8-port 1/10G SFP+ Uplink module | C9300 |
| C9300-NM-2Y-M* | 2-port 25G/10G/1G SFP28 Uplink module | C9300 |
| C9300X-NM-8Y-M* | 8-port 25G/10G/1G SFP28 Uplink module | C9300X*** |
| C9300X-NM-2C-M** | 2-port 100G/40G QSFP28 Uplink modules | C9300X |
Note: The MA-MOD-4x10G for the MS390 is end of sale. This includes the C9300-NM-4X, which is also supported but will not be available in a -M SKU.
*Note: The SFP28/QSFP28 modules will be orderable March 2024 with software support in CS16.7. 25Gbps Dashboard support is slated for CS17 firmware. 25Gbps optics can be used in CS16.8, but should be considered 'Beta'.
**Note: The C9300X-NM-2C-M modules will operate at 40Gbps with software support in CS17 firmware. For 100G operation, IOS-XE 17.15+ is required.
***Note: The number of Network Module ports are limited when C9300X-NM-8Y are used with the C9300X-48HXN models. Only 6 of the 8 ports will be available on a C9300X-48HXN switch.
C9300-NM-2Y-M / C9300-NM-2Y modules are supported only by C9300-24S/48S switches in firmware CS16.7. Support for the rest of the C9300-M portfolio is supported in CS16.8 firmware.
