Converting an Organization From Co-term to Per Device Licensing
This article outlines the prerequisites and procedures to convert an organization from a Co-term licensing model to a per-device licensing (PDL) model.
Purpose
Co-term to PDL conversion is being restricted. The purpose of this restriction is to avoid detrimental conversions and allow more strategic conversions to PDL.
Conversions to PDL will no longer be accepted. Customers should reach out to their Meraki Sales Representative to explore alternative options such as co-term or subscription licensing.
Responsible Stakeholders
  • Licensing Support (Primary)
  • Sales (Secondary)
Prerequisites
  • An expired or non-compliant organization should not be converted to PDL
    • This includes device and license compliance
  • An expiring or close to expiring organization should be allowed to convert only if a renewal order is placed.
    • Don't claim in co-term and claim the key post-conversion
  • Verify that the requester is a full org admin with read/write access including SAML read/write users on this organization by verifying their support passcode of the day.
    • A network or enterprise admin should not be allowed and should be asked to loop in their organization admin with full read/write permissions.
  • Verify if the requester is a multi-org admin/ MSP Portal ( Dashboard Navigation Panel > Global Overview or MSP Portal )
Process
Step 1: Reach out to Support
Customers open a case via the dashboard or the Support home page; or call Support to convert their org(s) to the Per-device licensing model. At this point, Support will add your Sales rep (if any) to the thread to ensure visibility.
  • Walk through the following high-level differences between the two models:
Description
Co-term
PDL
Flexibility of License Renewal
Full
Partial and Full
Activation of Licenses
Starts burning from the Start date
Starts burning after the 90-day activation window
License Management
Easy
All licenses within an org expire on the same date
Difficult
Each license assigned to a device will expire independently. This causes keeping track of several expiration end dates of device licenses
License Expiration
Co-term Weighted Average calculates one end date for all the devices
Separate expiration dates across all the devices, networks, and organization
License Change
Adding, moving, or renewing licenses will result in re-calculation of the org end date
Adding or moving licensing will have no effect to other individual licenses in the org
License Association
At the Org Level
At the device level
License Assignment
Not required
Required
License Queuing
Not Supported
Yes,
Extend the duration of the device by queueing additional unused licenses
License Enforcement Action
Org Shutdown
Device Shutdown
MX Product Edition
Single-tier Product Edition set at the org level
MR Product Edition
Multi-Tier Product Edition set at the device level
MS Product Edition
License Automation
APIs available to List, and Move licenses
APIs available to Claim, Assign, move licenses
Step 2: Justify
Justify “why” PDL is the right licensing model for your business and do you align/agree with the above considerations.
  • Provide reasons in writing to document this conversion and confirmation
Step 3: Establish Point of No return
Once verified and If the sales rep is actively involved, please get a final sign-off from the Sales team that they are aware and they agree with this move to PDL.  Support will determine the point of no return i.e. it is good to mention that rollback to co-term is not possible once converted to PDL at any cost.
Step 4: Final Confirmation
Once confirmed and all above requirements are met. Support will enable the button to convert to PDL
Step 5: Conversion
At this point, As organization admins, you can go through the conversion process independently by navigating to the Organization > License Info page.
License status indicator for the organization.
Exceptions: MSPs using the existing PDL model:
To reduce complexity for multi-org customers who are currently using the PDL model and require the creation of new PDL organizations to serve their customers, we will use the following steps:
As a solution we propose customers use the Organization Cloning workflow as documented here: Org Clone or shown below:
