Meraki Go Indoor WiFi 6 Access Point - GR12 Datasheet
Meraki Go
GR12: Dual-band, 802.11ax Wifi 6 2x2:2 MU MIMO
Features
Dual–radio aggregate frame rate of up to 1.5 Gbps*
5 GHz 2x2:2 and 2.4 GHz 2x2:2 radios offer a combined dual–radio aggregate frame rate of 1.5 Gbps*, with up to 1.201 Mbps in the 5 GHz band and 287 Mbps in the 2.4 GHz band.
* The radio chipset supports an aggregate PHY data rate of 1.7Gbps (1,201 Mbps in the 5 GHz band and 574 Mbps in the 2.4 GHz band).
Self-configuring, self-maintaining, always up-to-date
When plugged in, the GR12 automatically connects to the Meraki cloud, downloads its configuration, and joins the appropriate network. If new firmware is required, this is retrieved by the AP and updated automatically. This ensures the network is kept up-to-date with bug fixes, security updates, and new features.
Simplified Management
The GR12 is managed by the easy to use Meraki Go app, designed for small businesses with little to no network management experience.
Technical Specifications
Radios
802.11ac/ax and 802.11n Capabilities
Antenna
Interfaces
Power
Environment
Physical Dimensions & Weight
Mobility
LED Indicators
Compliance
In the Box
Warranty
2.4 Ghz Signal Pattern |
5 Ghz Signal Pattern |
Cisco Systems, Inc. | 500 Terry A. Francois Blvd, San Francisco, CA 94158 | (415) 432-1000 | help@meraki-go.com |
