MT14 Datasheet - Indoor Air Quality Monitor
Overview
Indoor air quality has become increasingly more important to schools, businesses, and other organizations as they look to create smart, sustainable buildings that provide safe and comfortable environments to people. Poor air quality, on the other hand, can decrease productivity or cause adverse health effects ranging from mild to severe.
The Cisco Meraki MT14, part of the Meraki MT sensor portfolio, provides real-time indoor air-quality monitoring to promote smart spaces and create safe environments. MT14 can detect the presence of chemicals, debris, extreme temperature, humidity, and noise. If air quality decreases for any reason, MT can notify you immediately or automate the building HVAC system to increase ventilation and keep people safe.
The MT14 is TAA compliant.
Smart sensors. Smarter businesses
Meraki MT sensors accelerate deployment, simplify management, and provide data-driven business outcomes. Flexible mounting, battery or wired power options, and automatic Bluetooth® pairing make it easy to provision thousands of sensors in a short amount of time. Centralized cloud management enables MT sensors to be managed alongside other networked devices, while open APIs allow MT to integrate with any business system.
Smart spaces start here
Identify anomalies and trends with visualizations and minute-by-minute data reporting
Create a smarter, more sustainable future with Meraki Psychrometric Charts
Never miss an event
Stay in the know with real-time alerts via email, SMS, push notification, or webhook
Gain complete visibility by associating sensor events with MV camera footage
Monitor and troubleshoot on-the-go with the Meraki mobile app
Cloud-first architecture
Cloud-based management eliminates the need for on-premises servers
Visibility alongside other Meraki products on the dashboard empowers lean teams
Simple and secure connectivity
Accelerate deployment with automatic, wireless connectivity to MR/MV gateways
Secure device authentication and encryption with the Cisco Trust Anchor module
Analytics tailored to your business
Build applications custom for your business through the vast partner ecosystem
Analyze data your way with .csv, .xls, API, or MQTT export options
Technical Specifications:
Sensors
Temperature |
Range: 0°C to +55°C / +32°F to +131°F Accuracy: +/- 0.3°C |
Humidity |
Range: 0 to 95% RH Accuracy: +/- 2.5% RH |
Total volatile organic compound |
Excellent: <300 µg/m³ Good: 300 to 1,000 µg/m³ Fair: 1,000 to 3,000 µg/m³ Poor: 3,000 to 10,000 µg/m³ Inadequate: ≥ 10,000 µg/m³ Accuracy: within 1 qualitative range |
Particulate matter (PM 2.5) |
Range: 0 to 100ug/m^3 Accuracy: +/- 10 ug/m^3 Range: 100 to 1,000ug/m^3 Accuracy: +/- 10% measured value |
Ambient noise |
20 to 120 dBA |
Wireless capabilities
Bluetooth® Low Energy |
Operating frequency |
2.400–2.4835 GHz |
IEEE standard |
802.15.1 (Bluetooth Low Energy 4.2) |
Data logging
Data sampling |
Temperature: every two minutes Humidity: every two minutes PM 2.5: every five minutes TVOC: every 90 seconds Ambient Noise: every 5 minutes |
Data reporting to gateway |
Every 20 minutes or immediately upon threshold violation |
Onboard data storage |
Up to five days of data storage |
Security |
Secure Bluetooth Low Energy messaging using long-term key (LTK) |
Power
Four AA batteries or USB-C power adapter |
Battery life up to two years |
Power ratings: 5V; 0.2A |
Physical characteristics
Dimensions: 130.0 mm (L) x 75.4 mm (W) x 31.6 mm (H) Weight (excluding batteries): 102g Battery compartment Multicolor, multifunction status LED General-purpose button Reset button USB-C port (receptacle connector) |
Operating environment
Temperature: 0°C to +55°C (+32°F to +131°F) |
Relative humidity: 0 to 95% RH |
Warranty
Three-year hardware warranty with advanced replacement |
Ordering information
MT14-HW |
Meraki indoor air quality sensor |
LIC-MT-XY |
Meraki MT Enterprise License (X = 1, 3, 5, 7 years) |
MA-PWR-USB-XX |
External power adapter* |
| MA-PWR-ETH | USB-C to Ethernet adapter* |
*External power is required to monitor PM2.5
Note: Each Meraki MT sensor requires a license to operate, however every dashboard organization comes standard with five free MT licenses to get started.
In the box
MT14-HW |
Quick-start and installation guide |
Four AA batteries (preinstalled with pull tab) |
Mounting equipment |
Wall-mount backplate Magnet VHB tape Two mounting screws Two drywall anchors |
