Scripts for Bulk Onboarding of Axis devices
Bulk Claiming with Automation Scripts
These scripts are for guidance only and will not be updated for different API versions and firmware. Please check compatibility and functionality in a test environment.
For large deployments with multiple devices, manual onboarding can be time-consuming. The following automation scripts help you collect device information (Serial Number and OAK) that is required for bulk claiming in the Meraki Dashboard as well as virtually enable One-Click Connect to cloud required for devices to fetch configuration.  Please refer to this document for requirements and variables when using the scripts.
get_axis_device_info_interactive.py
#!/usr/bin/env python3
Axis Device Information Retrieval Script - Interactive Mode
This script prompts for camera information interactively and queries each device to retrieve:
- OAK (Owner Authentication Key)
- Serial Number
- Model information
- Firmware Version
Requirements:
    pip install requests
Usage:
    python get_axis_device_info_interactive.py
The script will prompt you for:
- IP address(es)
- Username
- Password
- Optional CSV export
import csv
import sys
import getpass
from datetime import datetime
from typing import Dict, Optional, List
import json
# Third-party library for HTTP requests
# Install with: pip install requests
try:
    import requests
    from requests.auth import HTTPDigestAuth
except ImportError:
    print("ERROR: 'requests' library not found.")
    print("Please install it using: pip install requests")
    sys.exit(1)
# CONFIGURATION
# Timeout for HTTP requests in seconds
REQUEST_TIMEOUT = 10
# Color codes for terminal output (ANSI escape codes)
class Colors:
    """ANSI color codes for colored terminal output"""
    CYAN = '\033[96m'
    GREEN = '\033[92m'
    YELLOW = '\033[93m'
    RED = '\033[91m'
    GRAY = '\033[90m'
    RESET = '\033[0m'
    BOLD = '\033[1m'
# API QUERY FUNCTIONS
def get_axis_oak(ip_address: str, username: str, password: str) -> Optional[str]:
    Retrieve OAK (Owner Authentication Key) from Axis device.
    Args:
        ip_address: IP address of the Axis camera
        username: Username for authentication
        password: Password for authentication
    Returns:
        OAK string if successful, None if failed
    try:
        # Construct the OAK API endpoint URL
        url = f"http://{ip_address}/axis-cgi/oak.cgi"
        # Prepare JSON-RPC request body
        # The Axis OAK API uses JSON-RPC format with method "getOak"
        payload = {
            "apiVersion": "1.0",
            "method": "getOak"
        # Set HTTP headers for JSON content
        headers = {
            "Content-Type": "application/json"
        # Make POST request with HTTP Digest Authentication
        # Axis cameras use Digest Auth (more secure than Basic Auth)
        response = requests.post(
            url,
            json=payload,
            headers=headers,
            auth=HTTPDigestAuth(username, password),
            timeout=REQUEST_TIMEOUT
        # Check if request was successful (HTTP 200)
        response.raise_for_status()
        # Parse JSON response
        data = response.json()
        # Extract OAK from response (try multiple possible locations)
        if "data" in data and "oak" in data["data"]:
            return data["data"]["oak"]
        elif "oak" in data:
            return data["oak"]
        else:
            print(f"  Warning: OAK not found in response from {ip_address}")
            return None
    except requests.exceptions.Timeout:
        print(f"  Warning: Request timeout for OAK from {ip_address}")
        return None
    except requests.exceptions.RequestException as e:
        print(f"  Warning: Failed to retrieve OAK from {ip_address}: {e}")
        return None
    except json.JSONDecodeError:
        print(f"  Warning: Invalid JSON response for OAK from {ip_address}")
        return None
def get_axis_serial_number(ip_address: str, username: str, password: str) -> Optional[str]:
    Retrieve Serial Number from Axis device.
    Args:
    Returns:
        Serial number string if successful, None if failed
    try:
        # Try the newer basicdeviceinfo.cgi API first
        url = f"http://{ip_address}/axis-cgi/basicdeviceinfo.cgi?apiversion=1.0"
        # Make GET request with HTTP Digest Authentication
        response = requests.get(
            url,
        content = response.text
        # Try to parse as JSON first (newer firmware)
        try:
            data = json.loads(content)
            if "SerialNumber" in data:
                return data["SerialNumber"]
            pass
        # Try to find SerialNumber in text/XML format (older firmware)
        import re
        # Look for JSON format: "SerialNumber": "ABC123"
        match = re.search(r'"SerialNumber":\s*"([^"]+)"', content)
        if match:
            return match.group(1)
        # Look for XML format: <SerialNumber>ABC123</SerialNumber>
        match = re.search(r'<SerialNumber>([^<]+)</SerialNumber>', content)
        if match:
        # Fallback: Try the older param.cgi API
        url = f"http://{ip_address}/axis-cgi/param.cgi?action=list&group=Properties.System.SerialNumber"
            url,
        # Parse param.cgi format: SerialNumber=ABC123
        match = re.search(r'SerialNumber=([^\s\r\n]+)', response.text)
        if match:
        return None
        print(f"  Warning: Failed to retrieve Serial Number from {ip_address}: {e}")
        return None
def get_axis_model(ip_address: str, username: str, password: str) -> Optional[str]:
    Retrieve Model/Product Number from Axis device.
    Args:
    Returns:
        Model string if successful, None if failed
    try:
        # Query product number from param.cgi
        url = f"http://{ip_address}/axis-cgi/param.cgi?action=list&group=Properties.System.ProdNbr"
            url,
        # Parse param.cgi format: ProdNbr=M3077-PLVE
        import re
        match = re.search(r'ProdNbr=([^\s\r\n]+)', response.text)
        if match:
        return None
    except requests.exceptions.RequestException:
        # Model is optional, fail silently
        return None
def get_axis_firmware_version(ip_address: str, username: str, password: str) -> Optional[str]:
    Retrieve Firmware Version from Axis device.
    Args:
    Returns:
        Firmware version string if successful, None if failed
    try:
            url,
        try:
            if "Version" in data:
                return data["Version"]
            pass
        # Try to find Version in text/XML format (older firmware)
        import re
        # Look for JSON format: "Version": "9.80.3"
        match = re.search(r'"Version":\s*"([^"]+)"', content)
        if match:
        # Look for XML format: <Version>9.80.3</Version>
        match = re.search(r'<Version>([^<]+)</Version>', content)
        if match:
        url = f"http://{ip_address}/axis-cgi/param.cgi?action=list&group=Properties.Firmware.Version"
            url,
        # Parse param.cgi format: Version=9.80.3
        match = re.search(r'Version=([^\s\r\n]+)', response.text)
        if match:
        return None
        # Firmware version is optional, fail silently
        return None
# MAIN QUERY FUNCTION
def query_device(ip_address: str, username: str, password: str, index: int, total: int) -> Dict:
    Query a single Axis device for all information.
    Args:
        ip_address: IP address of the device
        index: Current device number (for progress display)
        total: Total number of devices
    Returns:
        Dictionary containing all retrieved information
    # Print progress header
    print(f"{Colors.YELLOW}[{index}/{total}] Querying: {ip_address}{Colors.RESET}")
    # Get OAK
    print(f"  Retrieving OAK...", end=" ", flush=True)
    oak = get_axis_oak(ip_address, username, password)
    if oak:
        print(f"{Colors.GREEN}OK{Colors.RESET}")
    else:
        print(f"{Colors.RED}FAILED{Colors.RESET}")
    # Get Serial Number
    print(f"  Retrieving Serial Number...", end=" ", flush=True)
    serial = get_axis_serial_number(ip_address, username, password)
    if serial:
    else:
    # Get Model
    print(f"  Retrieving Model...", end=" ", flush=True)
    model = get_axis_model(ip_address, username, password)
    if model:
    else:
        print(f"{Colors.GRAY}N/A{Colors.RESET}")
    # Get Firmware Version
    print(f"  Retrieving Firmware Version...", end=" ", flush=True)
    firmware = get_axis_firmware_version(ip_address, username, password)
    if firmware:
    else:
    print()  # Empty line for spacing
    # Return result dictionary
    return {
        "IPAddress": ip_address,
        "SerialNumber": serial or "",
        "FirmwareVersion": firmware or "",
        "OAK": oak or "",
        "Model": model or "",
        "Status": "Success" if (oak or serial) else "Failed",
        "Timestamp": datetime.now().strftime("%Y-%m-%d %H:%M:%S")
# INPUT PARSING FUNCTIONS
def parse_ip_input(ip_input: str) -> List[str]:
    Parse IP address input and return list of IP addresses.
    Supports:
    - Single IP: 192.168.1.100
    - Multiple IPs (comma-separated): 192.168.1.100, 192.168.1.101
    - IP range: 192.168.1.100-105
    Args:
        ip_input: User input string containing IP address(es)
    Returns:
        List of IP addresses
    import re
    ip_addresses = []
    # Check for IP range notation (e.g., 192.168.1.100-105)
    range_match = re.match(r'(\d+\.\d+\.\d+\.)(\d+)-(\d+)', ip_input.strip())
    if range_match:
        # Extract base IP and start/end range
        base_ip = range_match.group(1)
        start_range = int(range_match.group(2))
        end_range = int(range_match.group(3))
        # Generate all IPs in the range
        for i in range(start_range, end_range + 1):
            ip_addresses.append(f"{base_ip}{i}")
        print(f"{Colors.GREEN}Expanded range to {len(ip_addresses)} addresses{Colors.RESET}")
    else:
        # Split by comma for multiple IPs
        ip_addresses = [ip.strip() for ip in ip_input.split(',')]
    return ip_addresses
# CSV OUTPUT FUNCTION
def write_output_csv(file_path: str, results: List[Dict]) -> None:
    Write results to output CSV file.
    Args:
        file_path: Path to output CSV file
        results: List of result dictionaries
    # Define output CSV columns in the order we want them
    fieldnames = [
        "IPAddress",
        "SerialNumber",
        "FirmwareVersion",
        "OAK",
        "Model",
        "Status",
        "Timestamp"
    # Write CSV file
    with open(file_path, 'w', newline='', encoding='utf-8') as f:
        writer = csv.DictWriter(f, fieldnames=fieldnames)
        # Write header row
        writer.writeheader()
        # Write all result rows
        writer.writerows(results)
# MAIN PROGRAM
def main():
    """Main program entry point."""
    # Print banner
    print()
    print(f"{Colors.CYAN}{'='*50}{Colors.RESET}")
    print(f"{Colors.CYAN}  Axis Device Info - Interactive Mode{Colors.RESET}")
    print()
    # Prompt for IP addresses with examples
    print(f"{Colors.YELLOW}Enter camera IP address(es):{Colors.RESET}")
    print(f"{Colors.GRAY}  - Single IP: 192.168.1.100{Colors.RESET}")
    print(f"{Colors.GRAY}  - Multiple IPs (comma separated): 192.168.1.100, 192.168.1.101{Colors.RESET}")
    print(f"{Colors.GRAY}  - IP range: 192.168.1.100-105{Colors.RESET}")
    print()
    ip_input = input("IP Address(es): ").strip()
    # Parse IP addresses
    ip_addresses = parse_ip_input(ip_input)
    if not ip_addresses:
        print(f"{Colors.RED}ERROR: No valid IP addresses provided{Colors.RESET}")
        sys.exit(1)
    print()
    # Prompt for credentials
    print(f"{Colors.YELLOW}Enter camera credentials:{Colors.RESET}")
    username = input("Username: ").strip()
    # Use getpass for secure password input (hidden)
    password = getpass.getpass("Password: ")
    print()
    # Ask about CSV export
    export_choice = input("Export results to CSV? (y/n): ").strip().lower()
    csv_path = None
    if export_choice == 'y':
        default_path = f"axis-devices-{datetime.now().strftime('%Y%m%d-%H%M%S')}.csv"
        csv_input = input(f"CSV filename (press Enter for '{default_path}'): ").strip()
        csv_path = csv_input if csv_input else default_path
    print()
    print(f"{Colors.CYAN}Starting device queries...{Colors.RESET}")
    print()
    # Query each device
    results = []
    for index, ip in enumerate(ip_addresses, start=1):
        result = query_device(
            ip_address=ip,
            username=username,
            password=password,
            index=index,
            total=len(ip_addresses)
        results.append(result)
    # Display results summary table
    print()
    print(f"{Colors.CYAN}              RESULTS{Colors.RESET}")
    print()
    # Print results in a formatted table
    print(f"{'IP Address':<16} {'Serial':<16} {'Firmware':<12} {'Status':<10}")
    print("-" * 60)
    for result in results:
        status_color = Colors.GREEN if result['Status'] == 'Success' else Colors.RED
        print(f"{result['IPAddress']:<16} {result['SerialNumber']:<16} "
              f"{result['FirmwareVersion']:<12} {status_color}{result['Status']:<10}{Colors.RESET}")
    # Export to CSV if requested
    if csv_path:
        try:
            write_output_csv(csv_path, results)
            print()
            print(f"{Colors.GREEN}Results exported to: {csv_path}{Colors.RESET}")
        except Exception as e:
            print()
            print(f"{Colors.RED}ERROR: Failed to export CSV: {e}{Colors.RESET}")
    # Print summary statistics
    print()
    success_count = sum(1 for r in results if r['Status'] == 'Success')
    print(f"{Colors.CYAN}Summary: {success_count} of {len(results)} devices queried successfully{Colors.RESET}")
    print()
# Entry point - only run main() if script is executed directly (not imported)
if __name__ == "__main__":
    main()
get_axis_device_info_csv.py
Axis Device Information Retrieval Script - CSV Input Mode
This script reads camera information from a CSV file and queries each device to retrieve:
- Serial Number
- Model information
- Firmware Version
Requirements:
CSV Input Format:
    IPAddress,Username,Password
    192.168.1.100,root,password123
    192.168.1.101,admin,admin456
Usage:
    python get_axis_device_info_csv.py
    python get_axis_device_info_csv.py --input cameras.csv --output results.csv
import csv
import sys
import argparse
import json
try:
    import requests
except ImportError:
    sys.exit(1)
# CONFIGURATION
class Colors:
    CYAN = '\033[96m'
    GREEN = '\033[92m'
    YELLOW = '\033[93m'
    RED = '\033[91m'
    GRAY = '\033[90m'
    RESET = '\033[0m'
    BOLD = '\033[1m'
    Args:
    Returns:
    try:
        payload = {
            "method": "getOak"
        headers = {
            url,
            json=payload,
            headers=headers,
        elif "oak" in data:
            return data["oak"]
        else:
            return None
        return None
        return None
        return None
    Args:
    Returns:
    try:
            url,
        try:
            pass
        import re
        if match:
        if match:
            url,
        if match:
        return None
        return None
    Args:
    Returns:
    try:
            url,
        import re
        if match:
        return None
        return None
    Args:
    Returns:
    try:
            url,
        try:
            pass
        import re
        if match:
        if match:
            url,
        if match:
        return None
        return None
    Args:
    Returns:
    print(f"{Colors.YELLOW}[{index}/{total}] Querying: {ip_address} (User: {username}){Colors.RESET}")
    # Get OAK
    if oak:
    else:
    # Get Serial Number
    if serial:
    else:
    # Get Model
    if model:
    else:
    if firmware:
    else:
    return {
        "Username": username,
        "OAK": oak or "",
# CSV I/O FUNCTIONS
def read_input_csv(file_path: str) -> List[Dict]:
    Read device information from input CSV file.
    Args:
        file_path: Path to input CSV file
    Returns:
        List of dictionaries containing device information
    Raises:
        FileNotFoundError: If file doesn't exist
        ValueError: If CSV format is invalid
    # Check if file exists
    try:
        with open(file_path, 'r', encoding='utf-8') as f:
            # Read CSV using DictReader (automatically handles headers)
            reader = csv.DictReader(f)
            devices = list(reader)
            # Validate required columns exist
            required_columns = ['IPAddress', 'Username', 'Password']
            if not devices:
                raise ValueError("CSV file is empty")
            # Check if all required columns are present
            actual_columns = devices[0].keys()
            missing_columns = [col for col in required_columns if col not in actual_columns]
            if missing_columns:
                raise ValueError(f"CSV missing required columns: {', '.join(missing_columns)}\n"
                               f"Required columns: {', '.join(required_columns)}")
            return devices
    except FileNotFoundError:
        raise FileNotFoundError(f"File not found: {file_path}")
    Args:
    fieldnames = [
        "IPAddress",
        "Username",
        "SerialNumber",
        "FirmwareVersion",
        "OAK",
        "Model",
        "Status",
        "Timestamp"
    # Write CSV file
        # Write header row
# MAIN PROGRAM
def main():
    # Parse command line arguments
    parser = argparse.ArgumentParser(
        description="Retrieve OAK and device information from Axis cameras using CSV input",
        formatter_class=argparse.RawDescriptionHelpFormatter,
        epilog="""
CSV Input Format:
Examples:
    parser.add_argument(
        '--input', '-i',
        help='Path to input CSV file'
        '--output', '-o',
        help='Path to output CSV file'
    args = parser.parse_args()
    # Print banner
    print()
    print(f"{Colors.CYAN}  Axis Device Info - CSV Input Mode{Colors.RESET}")
    print()
    # Get input CSV path (either from command line or prompt user)
    input_csv = args.input
    if not input_csv:
        print(f"{Colors.YELLOW}CSV File Format Required:{Colors.RESET}")
        print(f"{Colors.GRAY}  IPAddress,Username,Password{Colors.RESET}")
        print(f"{Colors.GRAY}  192.168.1.100,root,password123{Colors.RESET}")
        print(f"{Colors.GRAY}  192.168.1.101,admin,admin456{Colors.RESET}")
        print()
        input_csv = input("Enter path to input CSV file: ").strip()
    # Read and validate input CSV
    try:
        devices = read_input_csv(input_csv)
    except (FileNotFoundError, ValueError) as e:
        print(f"{Colors.RED}ERROR: {e}{Colors.RESET}")
        sys.exit(1)
    print(f"{Colors.GREEN}Found {len(devices)} device(s) in CSV{Colors.RESET}")
    print()
    # Get output CSV path (either from command line or prompt user)
    output_csv = args.output
    if not output_csv:
        default_output = f"axis-results-{datetime.now().strftime('%Y%m%d-%H%M%S')}.csv"
        user_input = input(f"Output CSV filename (press Enter for '{default_output}'): ").strip()
        output_csv = user_input if user_input else default_output
    print()
    print()
    # Query each device from the CSV
    results = []
    for index, device in enumerate(devices, start=1):
            ip_address=device['IPAddress'],
            username=device['Username'],
            password=device['Password'],
            index=index,
            total=len(devices)
    print()
    print()
    print("-" * 60)
    # Write results to output CSV
    try:
        write_output_csv(output_csv, results)
        print()
        print(f"{Colors.GREEN}Results exported to: {output_csv}{Colors.RESET}")
        print()
    print()
    print()
    main()
Get-AxisDeviceInfo (Powershell)
.SYNOPSIS
    Retrieves OAK and Serial Number from Axis devices via VAPIX API
.DESCRIPTION
    Interactive script that prompts for camera IP addresses and credentials,
    then queries Axis cameras to retrieve:
    - Serial Number
    - Model information
.NOTES
    Requires network connectivity to Axis devices
    Uses VAPIX API with HTTP Digest Authentication
# Display banner
Write-Host ""
Write-Host "========================================" -ForegroundColor Cyan
Write-Host "  Axis Device Information Retrieval" -ForegroundColor Cyan
Write-Host ""
Write-Host "Enter camera IP address(es):" -ForegroundColor Yellow
Write-Host "  - Single IP: 192.168.1.100" -ForegroundColor Gray
Write-Host "  - Multiple IPs (comma separated): 192.168.1.100, 192.168.1.101" -ForegroundColor Gray
Write-Host "  - IP range notation: 192.168.1.100-105" -ForegroundColor Gray
Write-Host ""
$ipInput = Read-Host "IP Address(es)"
$ipAddresses = @()
if ($ipInput -match '(\d+\.\d+\.\d+\.)(\d+)-(\d+)') {
    # Range notation (e.g., 192.168.1.100-105)
    $baseIP = $matches[1]
    $startRange = [int]$matches[2]
    $endRange = [int]$matches[3]
    for ($i = $startRange; $i -le $endRange; $i++) {
        $ipAddresses += "$baseIP$i"
    Write-Host "Expanded range to $($ipAddresses.Count) addresses" -ForegroundColor Green
} else {
    # Single or comma-separated IPs
    $ipAddresses = $ipInput -split ',' | ForEach-Object { $_.Trim() }
Write-Host ""
Write-Host "Enter camera credentials:" -ForegroundColor Yellow
$username = Read-Host "Username"
$securePassword = Read-Host "Password" -AsSecureString
# Convert to credential object
$credential = New-Object System.Management.Automation.PSCredential($username, $securePassword)
Write-Host ""
$exportChoice = Read-Host "Export results to CSV? (y/n)"
$csvPath = $null
if ($exportChoice -eq 'y') {
    $defaultPath = "axis-devices-$(Get-Date -Format 'yyyyMMdd-HHmmss').csv"
    $csvInput = Read-Host "CSV filename (press Enter for '$defaultPath')"
    $csvPath = if ([string]::IsNullOrWhiteSpace($csvInput)) { $defaultPath } else { $csvInput }
Write-Host ""
Write-Host "Starting device queries..." -ForegroundColor Cyan
Write-Host ""
# Function to query OAK
function Get-AxisOAK {
    param(
        [string]$DeviceIP,
        [PSCredential]$Cred
    try {
        $oakUrl = "http://$DeviceIP/axis-cgi/oak.cgi"
        $body = @{
            apiVersion = "1.0"
            method = "getOak"
        } | ConvertTo-Json
        # Make POST request with JSON body
        $response = Invoke-RestMethod -Uri $oakUrl -Method Post `
            -Credential $Cred -ContentType "application/json" `
            -Body $body -TimeoutSec 10 -ErrorAction Stop
        # Parse OAK from JSON response
        if ($response.data.oak) {
            return $response.data.oak
        elseif ($response.oak) {
            return $response.oak
        else {
            Write-Warning "OAK not found in response from ${DeviceIP}"
            return $null
    catch {
        Write-Warning "Failed to retrieve OAK from ${DeviceIP}: $($_.Exception.Message)"
        return $null
# Function to query Serial Number
function Get-AxisSerialNumber {
    param(
        [string]$DeviceIP,
        [PSCredential]$Cred
    try {
        # Try basicdeviceinfo.cgi first (newer API)
        $infoUrl = "http://$DeviceIP/axis-cgi/basicdeviceinfo.cgi?apiversion=1.0"
        $response = Invoke-WebRequest -Uri $infoUrl -Credential $Cred `
            -TimeoutSec 10 -UseBasicParsing -ErrorAction Stop
        # Parse serial number from response
        if ($response.Content -match '"SerialNumber":\s*"([^"]+)"') {
            return $matches[1]
        elseif ($response.Content -match '<SerialNumber>([^<]+)</SerialNumber>') {
            return $matches[1]
        else {
            # Fallback to param.cgi for older firmware
            $paramUrl = "http://$DeviceIP/axis-cgi/param.cgi?action=list&group=Properties.System.SerialNumber"
            $response = Invoke-WebRequest -Uri $paramUrl -Credential $Cred `
            if ($response.Content -match 'SerialNumber=([^\s\r\n]+)') {
                return $matches[1]
        return $null
    catch {
        Write-Warning "Failed to retrieve Serial Number from ${DeviceIP}: $($_.Exception.Message)"
        return $null
# Function to get device model
function Get-AxisModel {
    param(
        [string]$DeviceIP,
        [PSCredential]$Cred
    try {
        $paramUrl = "http://$DeviceIP/axis-cgi/param.cgi?action=list&group=Properties.System.ProdNbr"
        if ($response.Content -match 'ProdNbr=([^\s\r\n]+)') {
            return $matches[1]
        return $null
    catch {
        return $null
# Query each device
$results = @()
$counter = 1
foreach ($ip in $ipAddresses) {
    Write-Host "[$counter/$($ipAddresses.Count)] Querying: $ip" -ForegroundColor Yellow
    # Get OAK
    Write-Host "  Retrieving OAK..." -NoNewline
    $oak = Get-AxisOAK -DeviceIP $ip -Cred $credential
    if ($oak) {
        Write-Host " OK" -ForegroundColor Green
    } else {
        Write-Host " FAILED" -ForegroundColor Red
    # Get Serial Number
    Write-Host "  Retrieving Serial Number..." -NoNewline
    $serial = Get-AxisSerialNumber -DeviceIP $ip -Cred $credential
    if ($serial) {
    } else {
    # Get Model
    Write-Host "  Retrieving Model..." -NoNewline
    $model = Get-AxisModel -DeviceIP $ip -Cred $credential
    if ($model) {
    } else {
        Write-Host " N/A" -ForegroundColor Gray
    # Create result object
    $result = [PSCustomObject]@{
        IPAddress    = $ip
        SerialNumber = $serial
        OAK          = $oak
        Model        = $model
        Status       = if ($oak -or $serial) { "Success" } else { "Failed" }
        Timestamp    = Get-Date -Format "yyyy-MM-dd HH:mm:ss"
    $results += $result
    $counter++
    Write-Host ""
# Display results
Write-Host ""
Write-Host "              RESULTS" -ForegroundColor Cyan
Write-Host ""
$results | Format-Table -AutoSize
if ($csvPath) {
    try {
        $results | Export-Csv -Path $csvPath -NoTypeInformation
        Write-Host "Results exported to: $csvPath" -ForegroundColor Green
    catch {
        Write-Warning "Failed to export CSV: $($_.Exception.Message)"
# Summary
Write-Host ""
$successCount = ($results | Where-Object { $_.Status -eq "Success" }).Count
Write-Host "Summary: $successCount of $($results.Count) devices queried successfully" -ForegroundColor Cyan
Write-Host ""
Get-AxisDeviceInfo-FromCSV (Powershell)
.SYNOPSIS
    Retrieves OAK and Serial Number from Axis devices using CSV input file
.DESCRIPTION
    Reads camera information from CSV file and queries each device to retrieve:
    - Serial Number
    - Model information
    CSV Format:
.PARAMETER InputCSV
    Path to input CSV file containing device information
.PARAMETER OutputCSV
    Path to output CSV file for results (optional)
.EXAMPLE
    .\Get-AxisDeviceInfo-FromCSV.ps1 -InputCSV "cameras.csv"
.EXAMPLE
    .\Get-AxisDeviceInfo-FromCSV.ps1 -InputCSV "cameras.csv" -OutputCSV "results.csv"
param(
    [Parameter(Mandatory=$false)]
    [string]$InputCSV,
    [string]$OutputCSV
# Display banner
Write-Host ""
Write-Host "  Axis Device Info - CSV Input Mode" -ForegroundColor Cyan
Write-Host ""
# Prompt for input CSV if not provided
if (-not $InputCSV) {
    Write-Host "CSV File Format Required:" -ForegroundColor Yellow
    Write-Host "  IPAddress,Username,Password" -ForegroundColor Gray
    Write-Host "  192.168.1.100,root,password123" -ForegroundColor Gray
    Write-Host "  192.168.1.101,admin,admin456" -ForegroundColor Gray
    Write-Host ""
    $InputCSV = Read-Host "Enter path to input CSV file"
# Validate input file exists
if (-not (Test-Path $InputCSV)) {
    Write-Host "ERROR: File not found: $InputCSV" -ForegroundColor Red
    exit 1
# Prompt for output CSV if not provided
if (-not $OutputCSV) {
    $defaultOutput = "axis-results-$(Get-Date -Format 'yyyyMMdd-HHmmss').csv"
    $outputChoice = Read-Host "Export results to CSV? Enter filename or press Enter for '$defaultOutput' (leave blank to skip)"
    if (-not [string]::IsNullOrWhiteSpace($outputChoice)) {
        $OutputCSV = $outputChoice
    } else {
        $OutputCSV = $defaultOutput
Write-Host ""
Write-Host "Reading devices from: $InputCSV" -ForegroundColor Cyan
# Import CSV
try {
    $devices = Import-Csv -Path $InputCSV
catch {
    Write-Host "ERROR: Failed to read CSV file: $($_.Exception.Message)" -ForegroundColor Red
    exit 1
# Validate CSV format
$requiredColumns = @('IPAddress', 'Username', 'Password')
$csvColumns = $devices[0].PSObject.Properties.Name
foreach ($col in $requiredColumns) {
    if ($col -notin $csvColumns) {
        Write-Host "ERROR: CSV missing required column: $col" -ForegroundColor Red
        Write-Host "Required columns: IPAddress, Username, Password" -ForegroundColor Yellow
        exit 1
Write-Host "Found $($devices.Count) device(s) in CSV" -ForegroundColor Green
Write-Host ""
Write-Host ""
    param(
        [string]$DeviceIP,
        [PSCredential]$Cred
    try {
        $body = @{
            apiVersion = "1.0"
            method = "getOak"
        } | ConvertTo-Json
        else {
            return $null
    catch {
        return $null
    param(
        [string]$DeviceIP,
        [PSCredential]$Cred
    try {
            return $matches[1]
            return $matches[1]
        else {
                return $matches[1]
        return $null
    catch {
        return $null
    param(
        [string]$DeviceIP,
        [PSCredential]$Cred
    try {
            return $matches[1]
        return $null
    catch {
        return $null
# Function to get firmware version
function Get-AxisFirmwareVersion {
    param(
        [string]$DeviceIP,
        [PSCredential]$Cred
    try {
        # Parse firmware version from response
        if ($response.Content -match '"Version":\s*"([^"]+)"') {
            return $matches[1]
        elseif ($response.Content -match '<Version>([^<]+)</Version>') {
            return $matches[1]
        else {
            $paramUrl = "http://$DeviceIP/axis-cgi/param.cgi?action=list&group=Properties.Firmware.Version"
            if ($response.Content -match 'Version=([^\s\r\n]+)') {
                return $matches[1]
        return $null
    catch {
        Write-Warning "Failed to retrieve Firmware Version from ${DeviceIP}: $($_.Exception.Message)"
        return $null
# Query each device
$results = @()
$counter = 1
foreach ($device in $devices) {
    $ip = $device.IPAddress
    $username = $device.Username
    $password = $device.Password
    Write-Host "[$counter/$($devices.Count)] Querying: $ip (User: $username)" -ForegroundColor Yellow
    # Create credential object
    $securePassword = ConvertTo-SecureString $password -AsPlainText -Force
    # Get OAK
    if ($oak) {
    } else {
    # Get Serial Number
    if ($serial) {
    } else {
    # Get Model
    if ($model) {
    } else {
    Write-Host "  Retrieving Firmware Version..." -NoNewline
    $firmwareVersion = Get-AxisFirmwareVersion -DeviceIP $ip -Cred $credential
    if ($firmwareVersion) {
    } else {
        IPAddress       = $ip
        Username        = $username
        FirmwareVersion = $firmwareVersion
        OAK             = $oak
        Model           = $model
    $results += $result
    $counter++
    Write-Host ""
# Display results
Write-Host ""
Write-Host ""
# Export to CSV
if ($OutputCSV) {
    try {
        $results | Export-Csv -Path $OutputCSV -NoTypeInformation
        Write-Host "Results exported to: $OutputCSV" -ForegroundColor Green
    catch {
# Summary
Write-Host ""
Write-Host ""
 set_axis_remote_service.py
Axis Remote Service Configuration Script
This script reads camera information from a CSV file and enables remote service
configuration on each device by sending POST request to /axis-cgi/remoteservice.cgi
Requirements:
CSV Input Format:
Usage:
    python set_axis_remote_service.py
    python set_axis_remote_service.py --input cameras.csv --output results.csv
import csv
import sys
import argparse
import json
try:
    import requests
except ImportError:
    sys.exit(1)
# CONFIGURATION
class Colors:
    CYAN = '\033[96m'
    GREEN = '\033[92m'
    YELLOW = '\033[93m'
    RED = '\033[91m'
    GRAY = '\033[90m'
    RESET = '\033[0m'
    BOLD = '\033[1m'
# API CONFIGURATION FUNCTION
def set_axis_remote_service(ip_address: str, username: str, password: str) -> Dict:
    Enable remote service on Axis device.
    Args:
    Returns:
        Dictionary with 'success' (bool) and 'message' (str)
    try:
        # Construct the Remote Service API endpoint URL
        url = f"http://{ip_address}/axis-cgi/remoteservice.cgi"
        # Prepare JSON request body
        # This enables the remote service feature on the Axis camera
        payload = {
            "method": "setConfig",
            "params": {
                "state": "enabled"
        headers = {
            url,
            json=payload,
            headers=headers,
        # Check if API returned an error
        if "error" in data:
            error_code = data["error"].get("code", "unknown")
            error_message = data["error"].get("message", "Unknown error")
            return {
                "success": False,
                "message": f"API Error: {error_message} (Code: {error_code})"
        else:
            # Success - remote service enabled
            return {
                "success": True,
                "message": "Remote service enabled successfully"
        return {
            "success": False,
            "message": f"Request timeout for {ip_address}"
    except requests.exceptions.HTTPError as e:
        return {
            "success": False,
            "message": f"HTTP Error: {e}"
        return {
            "success": False,
            "message": f"Request failed: {e}"
        return {
            "success": False,
            "message": "Invalid JSON response from device"
# MAIN CONFIGURATION FUNCTION
def configure_device(ip_address: str, username: str, password: str, index: int, total: int) -> Dict:
    Configure a single Axis device to enable remote service.
    Args:
    Returns:
        Dictionary containing configuration result
    print(f"{Colors.YELLOW}[{index}/{total}] Configuring: {ip_address} (User: {username}){Colors.RESET}")
    # Enable remote service
    print(f"  Setting remote service to 'enabled'...", end=" ", flush=True)
    result = set_axis_remote_service(ip_address, username, password)
    if result["success"]:
        print(f"{Colors.GRAY}  {result['message']}{Colors.RESET}")
    else:
        print(f"{Colors.RED}  {result['message']}{Colors.RESET}")
    return {
        "Status": "Success" if result["success"] else "Failed",
        "Message": result["message"],
# CSV I/O FUNCTIONS
    Args:
    Returns:
    Raises:
    try:
            if not devices:
            if missing_columns:
            return devices
    Args:
    fieldnames = [
        "IPAddress",
        "Username",
        "Status",
        "Message",
        "Timestamp"
    # Write CSV file
        # Write header row
# MAIN PROGRAM
def main():
        description="Enable remote service on Axis cameras using CSV input",
        epilog="""
CSV Input Format:
Examples:
        '--input', '-i',
        '--output', '-o',
    # Print banner
    print()
    print(f"{Colors.CYAN}  Axis Remote Service Configuration{Colors.RESET}")
    print()
    if not input_csv:
        print()
    try:
        sys.exit(1)
    print()
    if not output_csv:
        default_output = f"axis-remoteservice-results-{datetime.now().strftime('%Y%m%d-%H%M%S')}.csv"
    print()
    print(f"{Colors.CYAN}Starting configuration changes...{Colors.RESET}")
    print()
    # Configure each device from the CSV
    results = []
        result = configure_device(
            index=index,
            total=len(devices)
    print()
    print()
    print(f"{'IP Address':<16} {'Status':<10} {'Message':<40}")
    print("-" * 70)
        # Truncate message if too long
        message = result['Message'][:37] + "..." if len(result['Message']) > 40 else result['Message']
        print(f"{result['IPAddress']:<16} {status_color}{result['Status']:<10}{Colors.RESET} {message:<40}")
    try:
        print()
        print()
    print()
    print(f"{Colors.CYAN}Summary: {success_count} of {len(results)} devices configured successfully{Colors.RESET}")
    print()
    main()
 Set-AxisRemoteService (Powershell)
.SYNOPSIS
    Enable Remote Service on Axis devices via VAPIX API
.DESCRIPTION
    Reads camera information from CSV file and enables remote service configuration
    CSV Input Format:
.EXAMPLE
    .\Set-AxisRemoteService.ps1 -InputCSV "cameras.csv"
.EXAMPLE
    .\Set-AxisRemoteService.ps1 -InputCSV "cameras.csv" -OutputCSV "results.csv"
param(
    [string]$InputCSV,
    [string]$OutputCSV
# Display banner
Write-Host ""
Write-Host "  Axis Remote Service Configuration" -ForegroundColor Cyan
Write-Host ""
    Write-Host ""
    exit 1
    $defaultOutput = "axis-remoteservice-results-$(Get-Date -Format 'yyyyMMdd-HHmmss').csv"
    } else {
Write-Host ""
# Import CSV
try {
catch {
    exit 1
        exit 1
Write-Host ""
Write-Host "Starting configuration changes..." -ForegroundColor Cyan
Write-Host ""
# Function to enable remote service
function Set-AxisRemoteService {
    param(
        [string]$DeviceIP,
        [PSCredential]$Cred
    try {
        $url = "http://$DeviceIP/axis-cgi/remoteservice.cgi"
        $body = @{
            apiVersion = "1.0"
            method = "setConfig"
            params = @{
                state = "enabled"
        } | ConvertTo-Json -Compress
        $response = Invoke-RestMethod -Uri $url -Method Post `
        # Check response for success
        if ($response.error) {
            return @{
                Success = $false
                Message = "API Error: $($response.error.message) (Code: $($response.error.code))"
        else {
            return @{
                Success = $true
                Message = "Remote service enabled successfully"
    catch {
        return @{
            Success = $false
            Message = "Request failed: $($_.Exception.Message)"
# Process each device
$results = @()
$counter = 1
    Write-Host "[$counter/$($devices.Count)] Configuring: $ip (User: $username)" -ForegroundColor Yellow
    Write-Host "  Setting remote service to 'enabled'..." -NoNewline
    $result = Set-AxisRemoteService -DeviceIP $ip -Cred $credential
    if ($result.Success) {
        Write-Host "  $($result.Message)" -ForegroundColor Gray
    } else {
        Write-Host "  $($result.Message)" -ForegroundColor Red
    $resultObj = [PSCustomObject]@{
        IPAddress = $ip
        Status    = if ($result.Success) { "Success" } else { "Failed" }
        Message   = $result.Message
    $results += $resultObj
    $counter++
    Write-Host ""
# Display results
Write-Host ""
Write-Host ""
# Export to CSV
if ($OutputCSV) {
    try {
    catch {
# Summary
Write-Host ""
Write-Host "Summary: $successCount of $($results.Count) devices configured successfully" -ForegroundColor Cyan
Write-Host ""
  • Was this article helpful?
