Video Clip API
Applies to: MV Gen 2 and Gen 3 Cameras (firmware 7.2+)
Overview
The Video Clip API allows you to programmatically retrieve specific video segments from your MV cameras using timestamps. Instead of continuous streaming, you can request precise clips on-demand—perfect for integrating camera footage with security events, access control systems, analytics alerts, and custom applications.
Key Benefits
  • Event-Driven: Request clips only when you need them (after an alert, incident, or detection event)
  • Precise Timestamps: Retrieve exact time windows down to the second
  • Simple REST API: Use your existing Meraki Dashboard API key
  • Flexible Duration: Request clips from 1 second to 5 minutes
Common Use Cases
Organizations use the Video Clip API to:
  • Capture video evidence when security systems trigger alerts
  • Link video footage to badge-in/badge-out events from access control systems
  • Retrieve clips when License Plate Recognition (LPR) detects specific vehicles
  • Document point-of-sale transactions for loss prevention
  • Build custom investigation and timeline tools
  • Correlate video with IoT sensor events (door sensors, temperature alarms, etc.)
Requirements
Camera Requirements
  • Model: MV Gen 2 or Gen 3 camera
    • Gen 2: MV12WE, MV12W, MV12N, MV22 Series, MV72 Series, MV32, MV2, MV52
    • Gen 3: MV63, MV63M, MV63X, MV93, MV93M, MV93X, MV13, MV13M, MV33, MV33M, MV23M, MV23X, MV73M, MV73X, MV53X
  • Firmware: Version 7.2 or higher
To check camera firmware:
  1. Navigate to Cameras > [Camera Name] > Settings
  2. View the Firmware field under Camera Information
To upgrade firmware:
  1. Navigate to Cameras > Monitor > Cameras
  2. Select camera(s) and click Upgrade
API Access
You'll need:
  • Dashboard API access enabled for your organization
  • A valid API key with read access to the camera's organization
To enable API access and generate a key:
  1. Navigate to Organization > Settings
  2. Enable Dashboard API access
  3. Go to API Keys and click Generate new API key
  4. Securely store your API key (shown only once)
How It Works
Basic Workflow
  1. Determine the time window for your clip (start and end timestamps in UTC)
  2. Make an API request with the camera serial number and timestamps
  3. Receive a temporary URL to download the video clip
  4. Download the clip immediately (URLs expire after a few minutes)
API Request Format
GET https://api.meraki.com/api/v1/devices/{serial}/camera/clip
Parameters:
  • serial: Camera serial number (e.g., Q2XX-XXXX-XXXX)
  • startTimestamp: Start time in ISO8601 UTC format (e.g., 2026-03-23T14:30:00.000Z)
  • endTimestamp: End time in ISO8601 UTC format (max 5 minutes after start)
Headers:
  • Authorization: Bearer {YOUR_API_KEY}
  • Accept: application/json
Response:
  "url": "https://spn49.meraki.com/stream/jpeg/snapshot/v2/..."
The url field contains a temporary link to download the video clip in MPEG-TS (.ts) format.
Simple Example (cURL)
curl --request GET \
  --url 'https://api.meraki.com/api/v1/devices/Q2XX-XXXX-XXXX/camera/clip?startTimestamp=2026-03-23T14:30:00.000Z&endTimestamp=2026-03-23T14:32:00.000Z' \
  --header 'Authorization: Bearer YOUR_API_KEY'
Important Considerations
Timing and Latency
Allow some lag: There's a delay between live video and when clips become available due to encoding and cloud upload. Always request clips for times that are at least 20 seconds in the past.
Add buffer time: For event-triggered clips, add 30 seconds before and after the event for full context (pre-roll and post-roll).
Clip Duration
  • Minimum: 1 second
  • Maximum: 5 minutes per request
  • For longer periods, chain multiple requests back-to-back
Retention Period
Clips can only be retrieved for footage within your camera's retention period. Requests outside this window will fail.
Check retention: Cameras > [Camera Name] > Settings > Video Settings
Video Format
The API returns video in MPEG-TS (.ts) format, which:
  • Works with VLC, QuickTime, and most players
  • Can be played in browsers using HLS.js
  • Can be converted to MP4 using FFmpeg if needed
Rate Limits
Standard Dashboard API rate limits apply: 5 requests per second per organization. Implement retry logic with exponential backoff if you hit rate limits (429 errors).
Security
Never expose API keys in client-side code. Use a backend service to proxy requests to the Meraki API and keep your keys secure.
Common Integration Patterns
Pattern 1: Event Alert → Video Clip
When your security system triggers an alert:
  1. Receive alert with timestamp
  2. Request clip with 30s pre-roll and 30s post-roll
  3. Download and store clip with incident record
Pattern 2: LPR Detection → Video Clip
When LPR detects a license plate:
  1. Receive LPR MQTT event with plate number and timestamp
  2. Request 30-second clip centered on detection time
  3. Send video clip link to security team via Webex/email
See also: MV License Plate Recognition Documentation
Pattern 3: Access Control → Video Clip
When someone badges in:
  1. Receive badge-in event from access control system
  2. Request clip: 10s before badge, 20s after
  3. Store clip in employee access log for audit purposes
Pattern 4: Multi-Camera Timeline
For incident investigation:
  1. Request clips from multiple cameras for the same time window
  2. Download all clips in parallel (respecting rate limits)
  3. Build timeline view for investigators
Troubleshooting
400 Bad Request
  • Check timestamp format: must be YYYY-MM-DDTHH:MM:SS.000Z (UTC)
  • Ensure duration is 5 minutes or less
  • Verify endTimestamp is after startTimestamp
404 Not Found
  • Verify camera serial number
  • Ensure API key has access to the camera's organization
  • Confirm camera is an MV model (not MS, MR, etc.)
422 Unprocessable Entity
  • Timestamps may be outside retention period
  • Timestamps may be too recent (within 60-second latency window)
  • Camera may have been offline during requested time
429 Rate Limit Exceeded
  • Implement exponential backoff
  • Spread requests over time
  • Use the Retry-After header value
Video Won't Play
  • MPEG-TS has limited browser support—use HLS.js or convert to MP4
  • Ensure file downloaded completely (check file size)
Next Steps
Ready to start building? Check out these resources:
For Developers
For Integration Use Cases
Community and Support
Questions or feedback? Visit the Meraki Community Forums or contact Meraki Support.
  • Was this article helpful?
