MG21E Cellular Patch Antenna Datasheet
The Cellular Patch Antenna (MA-ANT-C1-B) is ideal for situations that require higher directional gain towards a cellular tower. When mounted high up on a pole for a clearer line of site toward a cellular tower, the MG cellular gateway will have higher signal quality and power.
Specifications
Category Specifications
Electrical
Antenna Type: Narrow Patch
Frequency Range:
  • 700 (698 - 791) MHz
  • 960 (824 - 960) MHz
  • 2170 (1710 - 2170) MHz
  • 2690 (2570 - 2690) MHz
Peak Gain (per range):
  • 700 @ 4dBi
  • 960 @ 4dBi
  • 2170 @ 8dBi
  • 2690 @ 7dBi
Polarization:  Linear, Horizontally (left) and Vertically (right)
Beamwidth (horizontal): 60°
Beamwidth (vertical): 60°
Cables Length: 100cm
Mounting Mounts to walls and poles
Physical and Environmental
Dimensions: 220mm x 220mm x 46mm
Weight: 550g
Material: PC-ABS
Temperature: -40°C  to +85°C (-40°F to 185°F)
Humidity: 95% at 55°C (131°F)
Connector: RP-SMA
Warranty 1 year hardware warranty included
Ordering Information MA-ANT-C1-B (works with MG21E only)
Regulatory Certified for use with the MG21E: MA-ANT-C1-B
The mounting hardware bracket is included with the patch antenna. No other accessories are required to mount.
Install Guide
Below are the step-by-step instructions.
Radiation Patterns
H-Port (Left, port 2): H-plane & V-plane
700 (698 - 791) MHz
960 (824 - 960) MHz
V-Port (Right, port 1): H-plane & V-plane
700 (698 - 791) MHz
960 (824 - 960) MHz
