MG21 Internal Antenna Datasheet
The internal antenna on the MG21 are enclosed inside for a sleek look while maintaining excellent performance. When in use the internal antenna has a bias towards the front face. The dipole shape of coverage the antennas generally excel at allowing users to place the MG in areas where a directional patch antenna cannot be mounted. A benefit of the internal antenna is the smaller footprint where it will be mounted.
Specifications
Category Specifications
Electrical
Antenna Type
Planar Inverted F Antenna (PIFA)
Main Antenna
Frequency Range
  • 829 (698 - 960) MHz
  • 1940 (1710 - 2170) MHz
  • 2495 (2300 - 2690) MHz
Peak Gain (per range)
  • 829 @ 2.9dBi
  • 1940 @ 4.8dBi
  • 2495 @ 3.8dBi
Polarization
Linear, vertical
Auxiliary Antenna
Frequency Range
  • 829 @ 2.7dBi
  • 1940 @ 3.8dBi
  • 2495 @ 3.3dBi
Polarization
Linear, vertical
Physical and Environmental
MG21 Dimensions
160.45 x 160.45 x 34.45mm
MG21 Operating Temperature
-30°C to 50°C (-22°F to 122°F)
Material of Radiator
Sheet metal
Regulatory Certified for use in the MG21
Radiation Patterns
Main Antenna
829 (698 - 960) MHz
Auxiliary Antenna
829 (698 - 960) MHz
