MG52E Cellular Dipole Antenna Datasheet
Note - Do not mix MG52E dipole antennas with other MG antennas
The dipole antennas (MA-ANT-C2-B) are included with the MG52E. When in use the dipoles have a spherical coverage in comparison to a patch antenna. The dipole antennas will excel at allowing users to place the MG in areas where a directional patch antenna cannot be mounted. The dipoles can be directly attached to the MG52E and require no additional mounting hardware.
Specifications
| Category | Specifications |
| Physical and Environmental |
             Dimensions 144mm x 26.5mm x 12.3mm Material of Radiator PCB Material of Plastic PC Operational Temperature -40°C to +65°C (-40°F to 149°F) Storage Temperature -40°C to +80°C (-40°F to 176°F) Connector RP-SMA (female)  |
| Warranty | 1 year hardware warranty included |
| Ordering Information | MA-ANT-C2-B |
| Regulatory |
             Certified for use with the MG52E MA-ANT-C2-B  |
ANT0
ANT1
ANT2
ANT3
