MG52E Patch Antenna Datasheet
The Cellular Patch Antenna (MA-ANT-DUAL-C3) is ideal for situations that require higher directional gain towards a cellular tower. When mounted high up on a pole for a clearer line of site toward a cellular tower, the MG cellular gateway will have higher signal quality and power. The patch antenna can be used to help increase signal strength if the dipole antennas are not giving you a signal quality you need. This antenna can help boost coverage due to its unique cone shape coverage pattern when pointed towards the correct cellular tower for your preferred carrier.
The MG52E dipole antenna datasheet mentions the Antenna naming convention as ANT0, ANT1, ANT2 and ANT3 and the patch antenna below references ANT1, ANT2, ANT3 and ANT4. For connecting patch antenna ports to MG52E, ANT1 port of the patch antenna needs to be connected to ANT0 port of the MG52E and ANT2 (patch antenna port) <-> ANT1 (MG52E) and so on.
Antenna Profile
Top View Bottom View Left side view Right side view
Front side Back side
Specifications
| Category | Specifications |
| Ordering Information |
MA-ANT-DUAL-C3 (Please use this SKU name when ordering patch antenna set) |
| Dimensions | 350mm x 350mm x 77.6mm |
| Type | Sub6 4x4 full band directional antenna |
| Connector | RP SMA PLUG 4x4 |
| Cable | NFC-200 L:36 Inch |
| Frequency(MHz) | P1 | P2 | P3 | P4 | |
| 3dB Beamwidth H and V 50˚+-10˚ |
617-960 | H:80 V:80 | H:83 V:89 | H:72 V:81 | H:74 V:58 |
| 1432-1518 | H:62 V:70 | H:74 V:79 | H:42 V:74 | H:67 V:57 | |
| 1710-2700 | H: 64 V:45 | H: 53 V:45 | H: 54 V:47 | H: 67 V:56 | |
| 3300-5925 | H: 61 V:67 | H: 55 V:59 | H: 53 V:64 | H: 64 V:57 | |
| Gain<8 | 617-960 | 4.18~5.71 | 4.14~5.47 | 4.13~5.26 | 4.14~5.22 |
| 1432-1518 | 5.09~6.11 | 5.09~6.39 | 4.79~5.84 | 4.19~5.12 | |
| 1710-2700 | 5.85~7.59 | 6.00~7.97 | 6.30~7.81 | 5.04~7.13 | |
| 3300-5925 | 5.91~7.29 | 5.90~7.86 | 5.69~7.07 | 6.09~7.46 | |
| Gain Ripple <3 | 617-960 | 1.6 | 1.3 | 1.1 | 1.1 |
| 1432-1518 | 1.1 | 1.3 | 1.0 | 1.0 | |
| 1710-2700 | 1.7 | 1.9 | 1.5 | 2.1 | |
| 3300-5925 | 1.4 | 1.9 | 1.4 | 1.4 | |
| Isolation > -20 | 617-960 | -14 | -13 | -14 | -13 |
| 1432-1518 | -20 | -20 | -20 | -20 | |
| 1710-2700 | -20 | -20 | -20 | -20 | |
| 3300-5925 | -25 | -25 | -25 | -25 | |
| Efficiency > 60% (-2.2 db) | 617-960 | 50.21~55.89 | 50.17~55.46 | 48.74~54.26 | 50.99~58.36 |
| 1432-1518 | 54.35~59.54 | 53.30~60.18 | 50.06~57.20 | 50.17~58.73 | |
| 1710-2700 | 50.01~61.28 | 53.65~60.35 | 51.41~64.60 | 51.12~65.81 | |
| 3300-5925 | 45.98~54.94 | 44.52~56.60 | 42.21~54.44 | 42.91~54.10 | |
| VSWR<1.9:1 | 617-960 | 2.5 | 2.5 | 2.5 | 2.5 |
| 1432-1518 | 1.9 | 1.9 | 1.9 | 1.9 | |
| 1710-2700 | 1.9 | 1.9 | 1.9 | 1.9 | |
| 3300-5925 | 1.9 | 1.9 | 1.9 | 1.9 | |
| Front to Back >15dbr | 617-960 | 13 | 13 | 13 | 13 |
| 1432-1518 | 13 | 14 | 13 | 14 | |
| 1710-2700 | 13 | 15 | 15 | 15 | |
| 3300-5925 | 15 | 15 | 15 | 15 |
Install Guide
Wall Mounting
Pole Mounting
Radiation Patterns
| Ant 1 | ||||||||||||||
| Band | Link type | Frequency (MHz) | 3D | V+H Avg. Gain | V+H Peak Gain | Beamwidth | ||||||||
| Efficiency | Avg. Gain | Peak Gain | XY-plane | YZ-plane | ZX-plane | XY-plane | YZ-plane | ZX-plane | XY-plane | YZ-plane | ZX-plane | |||
| 71 | RX | 617.00 | 50.21 | -2.99 | 4.54 | -6.18 | -1.79 | -2.29 | -3.21 | 3.97 | 2.31 | 52.30 | 108.41 | |
| 71 | RX | 652.00 | 51.57 | -2.88 | 4.18 | -6.82 | -2.17 | -2.86 | -0.75 | 3.65 | 3.95 | 95.51 | 59.35 | |
| 71 | RX | 663.00 | 54.49 | -2.64 | 4.50 | -5.65 | -1.44 | -2.14 | 0.64 | 3.82 | 4.49 | 107.94 | 61.24 | |
| 71 | TX | 698.00 | 55.33 | -2.57 | 4.38 | -7.40 | -2.58 | -1.77 | -1.35 | 3.73 | 4.31 | 75.55 | 64.19 | |
| 17 | TX | 710.00 | 54.71 | -2.62 | 5.58 | -7.84 | -1.73 | -1.39 | -2.54 | 5.02 | 5.53 | 68.36 | 59.56 | |
| 12 17 | TX | 716.00 | 55.89 | -2.53 | 5.71 | -8.53 | -1.80 | -1.47 | -3.76 | 4.90 | 5.68 | 67.50 | 58.91 | |
| 17 | RX | 734.00 | 55.25 | -2.58 | 5.59 | -7.49 | -2.22 | -1.68 | -2.87 | 3.86 | 4.60 | 75.93 | 73.16 | |
| 13 | RX | 751.00 | 55.74 | -2.54 | 4.27 | -7.07 | -2.59 | -2.67 | -1.69 | 2.81 | 3.34 | 97.45 | 77.07 | |
| 14 | RX | 768.00 | 52.23 | -2.82 | 4.36 | -5.69 | -1.94 | -1.91 | -1.73 | 3.62 | 3.59 | 100.29 | 92.02 | |
| 14 | TX | 798.00 | 55.89 | -2.53 | 4.51 | -6.56 | -2.71 | -1.69 | -3.01 | 3.87 | 4.24 | 64.04 | 80.13 | |
| 5 | TX | 824.00 | 52.65 | -2.79 | 4.82 | -5.49 | -2.60 | -1.88 | -1.55 | 3.83 | 3.95 | 62.34 | 83.35 | |
| 5 26 | TX | 849.00 | 55.10 | -2.59 | 4.55 | -4.87 | -1.25 | -2.50 | -1.40 | 3.89 | 3.51 | 106.48 | 71.13 | |
| 5 | RX | 869.00 | 52.76 | -2.78 | 4.20 | -5.35 | -2.43 | -1.84 | -2.03 | 2.98 | 3.28 | 88.96 | 113.80 | |
| 5 26 | RX | 894.00 | 56.02 | -2.52 | 4.89 | -4.25 | -1.05 | -0.40 | -1.23 | 4.35 | 4.47 | 88.33 | 116.25 | |
| 8 | RX | 925.00 | 54.75 | -2.62 | 4.80 | -5.68 | -1.31 | -1.43 | -1.78 | 4.48 | 3.84 | 85.30 | 99.15 | |
| 8 | RX | 960.00 | 50.51 | -2.97 | 4.69 | -5.54 | -1.75 | -1.38 | -1.81 | 4.06 | 4.57 | 79.16 | 68.08 | |
| 53.95 | 4.72 | |||||||||||||
| 75 | RX | 1432.00 | 54.35 | -2.65 | 5.09 | -5.73 | -2.00 | -3.21 | -1.32 | 4.85 | 2.63 | 62.94 | 64.01 | |
| 32 | RX | 1452.00 | 58.12 | -2.36 | 5.34 | -5.78 | -1.86 | -2.65 | -0.01 | 4.62 | 4.15 | 64.54 | 55.49 | |
| 32 | RX | 1474.00 | 57.80 | -2.38 | 5.53 | -6.56 | -2.23 | -1.85 | -2.79 | 4.41 | 4.31 | 75.23 | 70.84 | |
| 75 | RX | 1474.50 | 57.82 | -2.38 | 5.55 | -6.57 | -2.23 | -1.83 | -2.83 | 4.42 | 4.32 | 75.16 | 70.75 | |
| 32 | RX | 1496.00 | 58.47 | -2.33 | 5.93 | -7.06 | -1.51 | -1.22 | -3.06 | 5.68 | 5.90 | 70.27 | 56.60 | |
| 75 | RX | 1517.00 | 59.54 | -2.25 | 6.11 | -7.26 | -0.80 | -1.08 | -2.54 | 6.02 | 6.04 | 72.34 | 55.01 | |
| 57.68 | 5.59 | |||||||||||||
| 3 4 66 | TX | 1710.00 | 53.82 | -2.69 | 5.88 | -6.73 | -0.98 | -1.33 | -1.53 | 5.70 | 5.35 | 59.62 | 72.65 | |
| 3 | RX | 1805.00 | 61.28 | -2.13 | 6.76 | -7.03 | -0.55 | -0.11 | -3.20 | 6.24 | 6.53 | 56.46 | 68.28 | |
| 3 39 | RX | 1880.00 | 52.09 | -2.83 | 5.51 | -6.82 | -2.17 | -1.07 | -2.24 | 4.16 | 4.49 | 61.66 | 99.12 | |
| 1 | TX | 1920.00 | 55.78 | -2.54 | 6.54 | -8.03 | -1.31 | -0.25 | -2.41 | 6.25 | 6.14 | 43.75 | 62.31 | |
| 1 4 | RX | 2110.00 | 60.54 | -2.18 | 7.27 | -7.95 | -1.98 | 0.90 | -3.95 | 6.82 | 7.25 | 35.81 | 75.89 | |
| 1 | RX | 2170.00 | 58.69 | -2.31 | 6.86 | -7.15 | -2.62 | 0.60 | -1.77 | 5.92 | 6.17 | 33.95 | 91.54 | |
| 66 | RX | 2200.00 | 56.65 | -2.47 | 6.50 | -5.93 | -2.70 | -0.39 | -0.90 | 5.34 | 5.64 | 32.06 | 79.30 | |
| 40 | RX | 2300.00 | 61.87 | -2.09 | 6.56 | -5.38 | -2.03 | -0.49 | -0.07 | 5.67 | 6.53 | 47.15 | 51.59 | |
| 30 40 | RX | 2350.00 | 61.21 | -2.13 | 7.59 | -5.68 | -1.97 | -0.36 | 0.70 | 5.24 | 7.26 | 49.27 | 58.41 | |
| 40 | RX | 2400.00 | 57.97 | -2.37 | 7.13 | -6.15 | -2.27 | -0.41 | -0.91 | 5.02 | 7.13 | 38.09 | 53.29 | |
| 7 | TX | 2500.00 | 55.24 | -2.58 | 6.22 | -5.73 | -3.10 | -3.05 | -0.80 | 5.21 | 4.81 | 38.03 | 33.97 | |
| 38 | RX | 2595.00 | 50.01 | -3.01 | 5.85 | -5.47 | -2.41 | -4.44 | -2.33 | 4.74 | 2.95 | 42.00 | 46.01 | |
| 7 | RX | 2690.00 | 51.96 | -2.84 | 5.92 | -4.79 | -2.49 | -4.31 | 0.18 | 3.38 | 2.60 | 57.98 | 44.92 | |
| 56.70 | 6.51 | |||||||||||||
| n77 n78 | RX | 3300.00 | 51.59 | -2.87 | 7.33 | -9.12 | -0.18 | -1.41 | -3.64 | 7.32 | 6.52 | 60.87 | 54.79 | |
| 42 | RX | 3400.00 | 51.84 | -2.85 | 7.08 | -10.37 | -0.14 | -1.59 | -4.07 | 7.07 | 6.41 | 61.02 | 52.30 | |
| 48 n78 | RX | 3550.00 | 56.07 | -2.51 | 7.27 | -8.93 | -0.29 | -1.31 | -4.84 | 6.64 | 5.56 | 65.56 | 61.57 | |
| 42 43 | RX | 3600.00 | 52.69 | -2.78 | 7.29 | -9.82 | -0.49 | -1.18 | -5.51 | 6.75 | 5.92 | 60.80 | 61.97 | |
| 43 48 | RX | 3700.00 | 52.87 | -2.77 | 6.53 | -10.36 | -1.05 | -1.01 | -5.51 | 6.21 | 6.04 | 58.04 | 58.97 | |
| n78 | RX | 3800.00 | 53.27 | -2.74 | 6.53 | -9.77 | -0.95 | -1.58 | -3.86 | 5.71 | 5.14 | 67.30 | 53.78 | |
| n77 | RX | 4200.00 | 54.94 | -2.60 | 7.61 | -10.25 | -0.81 | -1.06 | -5.47 | 7.38 | 7.44 | 70.30 | 63.94 | |
| n79 | RX | 4400.00 | 53.03 | -2.76 | 7.45 | -10.44 | -0.46 | -0.63 | -3.79 | 7.45 | 7.15 | 72.26 | 58.67 | |
| n79 | RX | 4700.00 | 49.30 | -3.07 | 7.24 | -7.95 | -1.72 | -1.78 | -2.81 | 6.13 | 6.98 | 65.60 | 58.51 | |
| n79 | RX | 5000.00 | 46.77 | -3.30 | 5.96 | -8.01 | -2.03 | -2.87 | -3.17 | 5.96 | 4.43 | 73.06 | 65.63 | |
| 46 | RX | 5150.00 | 45.55 | -3.42 | 5.90 | -8.27 | -2.99 | -3.16 | -2.51 | 4.22 | 4.73 | 67.61 | 69.77 | |
| 46 | RX | 5537.50 | 45.77 | -3.39 | 5.93 | -6.49 | -2.44 | -3.36 | -0.51 | 4.40 | 3.94 | 58.96 | 74.36 | |
| 46 | RX | 5925.00 | 45.98 | -3.37 | 5.91 | -5.57 | -3.73 | -3.85 | 0.71 | 3.75 | 3.31 | 95.56 | 61.70 | |
| 50.74 | 6.77 | |||||||||||||
| Ant 2 | ||||||||||||||
| 71 | RX | 617.00 | 50.93 | -2.93 | 4.63 | -6.16 | -1.55 | -0.82 | -2.34 | 4.55 | 4.60 | 72.98 | 87.83 | |
| 71 | RX | 652.00 | 51.26 | -2.90 | 4.57 | -4.90 | -1.46 | -1.45 | 0.72 | 4.53 | 4.46 | 77.49 | 83.29 | |
| 71 | RX | 663.00 | 50.17 | -3.00 | 4.87 | -7.32 | -1.73 | -1.45 | -2.12 | 4.75 | 4.83 | 69.48 | 75.81 | |
| 71 | TX | 698.00 | 50.98 | -2.93 | 4.48 | -5.59 | -1.35 | -1.55 | -0.61 | 4.38 | 4.02 | 85.65 | 88.97 | |
| 17 | TX | 710.00 | 52.01 | -2.84 | 4.48 | -6.11 | -1.01 | -1.74 | -2.04 | 4.19 | 4.25 | 96.41 | 82.25 | |
| 12 17 | TX | 716.00 | 51.68 | -2.87 | 4.63 | -6.88 | -1.08 | -1.78 | -2.99 | 4.59 | 4.21 | 91.11 | 80.83 | |
| 17 | RX | 734.00 | 54.58 | -2.63 | 5.47 | -7.33 | -1.38 | -1.24 | -2.23 | 5.20 | 4.93 | 71.96 | 78.04 | |
| 13 | RX | 751.00 | 50.80 | -2.94 | 4.98 | -6.45 | -1.48 | -1.42 | -1.19 | 4.18 | 4.97 | 85.11 | 72.13 | |
| 14 | RX | 768.00 | 52.44 | -2.80 | 5.28 | -7.50 | -1.47 | -1.37 | -3.01 | 4.76 | 5.28 | 76.29 | 64.94 | |
| 14 | TX | 798.00 | 51.17 | -2.91 | 4.19 | -6.57 | -1.71 | -1.91 | -2.19 | 3.36 | 3.99 | 105.79 | 80.18 | |
| 5 | TX | 824.00 | 52.68 | -2.78 | 4.57 | -5.62 | -0.81 | -1.78 | -0.04 | 3.55 | 4.33 | 124.88 | 75.78 | |
| 5 26 | TX | 849.00 | 50.90 | -2.93 | 5.16 | -5.59 | -1.36 | -1.23 | -1.71 | 3.59 | 5.06 | 101.81 | 61.28 | |
| 5 | RX | 869.00 | 55.46 | -2.56 | 4.85 | -5.28 | -1.80 | -0.83 | -1.41 | 3.64 | 4.85 | 87.00 | 99.90 | |
| 5 26 | RX | 894.00 | 52.04 | -2.84 | 4.23 | -5.61 | -1.27 | -1.05 | -2.28 | 3.69 | 3.83 | 101.99 | 104.04 | |
| 8 | RX | 925.00 | 51.19 | -2.91 | 4.46 | -5.88 | -1.31 | -1.59 | -2.99 | 4.40 | 3.64 | 87.27 | 97.56 | |
| 8 | RX | 960.00 | 51.76 | -2.86 | 4.14 | -4.67 | -2.24 | -0.91 | -0.29 | 3.16 | 3.89 | 88.71 | 110.79 | |
| 51.88 | 4.69 | |||||||||||||
| 75 | RX | 1432.00 | 53.30 | -2.73 | 5.09 | -6.46 | -2.19 | -2.14 | -2.50 | 4.13 | 4.89 | 85.27 | 63.12 | |
| 32 | RX | 1452.00 | 54.27 | -2.65 | 5.11 | -6.07 | -2.08 | -1.51 | -1.86 | 4.24 | 5.05 | 85.04 | 71.61 | |
| 32 | RX | 1474.00 | 58.18 | -2.35 | 5.35 | -6.13 | -1.88 | -1.12 | -1.31 | 4.35 | 5.19 | 83.26 | 72.62 | |
| 75 | RX | 1474.50 | 58.28 | -2.34 | 5.37 | -6.12 | -1.88 | -1.11 | -1.27 | 4.35 | 5.21 | 83.18 | 72.44 | |
| 32 | RX | 1496.00 | 58.87 | -2.30 | 5.29 | -5.74 | -2.56 | -1.11 | 0.24 | 3.50 | 4.82 | 78.66 | 100.84 | |
| 75 | RX | 1517.00 | 60.18 | -2.21 | 6.39 | -6.30 | -0.87 | -0.59 | -1.41 | 6.35 | 6.13 | 60.67 | 67.42 | |
| 57.18 | 5.43 | |||||||||||||
| 3 4 66 | TX | 1710.00 | 60.26 | -2.20 | 6.00 | -4.73 | -0.70 | -0.70 | 0.17 | 5.96 | 5.46 | 39.66 | 79.35 | |
| 3 | RX | 1805.00 | 60.35 | -2.19 | 6.85 | -7.97 | 0.06 | 0.11 | -1.85 | 6.83 | 6.73 | 63.32 | 61.78 | |
| 3 39 | RX | 1880.00 | 55.13 | -2.59 | 6.96 | -8.34 | -0.44 | -0.50 | -3.37 | 6.95 | 6.63 | 50.80 | 57.81 | |
| 1 | TX | 1920.00 | 54.34 | -2.65 | 7.97 | -8.52 | -0.27 | -0.56 | -3.40 | 7.44 | 7.17 | 48.08 | 57.00 | |
| 1 4 | RX | 2110.00 | 56.59 | -2.47 | 6.49 | -8.03 | -0.68 | -1.03 | -4.28 | 6.49 | 6.11 | 51.90 | 66.56 | |
| 1 | RX | 2170.00 | 55.11 | -2.59 | 6.54 | -7.65 | -1.57 | -1.01 | -2.82 | 5.17 | 5.99 | 52.85 | 71.11 | |
| 66 | RX | 2200.00 | 59.13 | -2.28 | 6.92 | -8.37 | -2.24 | -0.80 | -4.54 | 5.13 | 6.13 | 46.15 | 72.19 | |
| 40 | RX | 2300.00 | 63.46 | -1.98 | 6.30 | -5.82 | -2.48 | -1.34 | -0.89 | 5.15 | 6.02 | 31.05 | 53.44 | |
| 30 40 | RX | 2350.00 | 59.70 | -2.24 | 7.67 | -6.43 | -1.67 | -1.29 | -0.66 | 5.97 | 7.67 | 38.40 | 25.18 | |
| 40 | RX | 2400.00 | 59.12 | -2.28 | 7.03 | -5.15 | -0.49 | -1.73 | -0.24 | 6.79 | 7.03 | 38.10 | 30.07 | |
| 7 | TX | 2500.00 | 59.52 | -2.25 | 6.33 | -4.55 | -2.26 | -2.04 | -1.29 | 3.96 | 4.79 | 44.36 | 45.85 | |
| 38 | RX | 2595.00 | 57.98 | -2.37 | 6.70 | -5.42 | -2.09 | -2.08 | -1.04 | 6.70 | 5.73 | 44.32 | 43.18 | |
| 7 | RX | 2690.00 | 53.65 | -2.70 | 6.67 | -6.92 | -2.51 | -2.16 | -2.92 | 6.66 | 6.47 | 46.78 | 32.97 | |
| 58.03 | 6.80 | |||||||||||||
| n77 n78 | RX | 3300.00 | 51.57 | -2.88 | 7.15 | -10.67 | 0.09 | -1.78 | -6.05 | 7.14 | 5.59 | 58.30 | 56.32 | |
| 42 | RX | 3400.00 | 50.85 | -2.94 | 6.20 | -8.37 | -1.46 | -2.12 | -4.21 | 5.56 | 4.89 | 60.11 | 51.71 | |
| 48 n78 | RX | 3550.00 | 52.67 | -2.78 | 7.22 | -8.38 | -0.47 | -0.78 | -3.69 | 7.00 | 6.12 | 69.76 | 54.08 | |
| 42 43 | RX | 3600.00 | 56.60 | -2.47 | 7.12 | -9.21 | -0.48 | -0.86 | -4.37 | 6.47 | 6.47 | 73.55 | 56.48 | |
| 43 48 | RX | 3700.00 | 53.14 | -2.75 | 6.73 | -9.96 | -0.73 | -1.48 | -4.50 | 6.73 | 6.60 | 77.46 | 61.01 | |
| n78 | RX | 3800.00 | 52.04 | -2.84 | 7.68 | -10.37 | -0.25 | -0.94 | -6.22 | 7.67 | 7.53 | 73.19 | 56.32 | |
| n77 | RX | 4200.00 | 54.28 | -2.65 | 7.67 | -8.97 | 0.45 | -0.66 | -4.50 | 7.65 | 6.82 | 55.64 | 55.18 | |
| n79 | RX | 4400.00 | 53.14 | -2.75 | 7.86 | -10.19 | -0.03 | -1.02 | -5.74 | 7.71 | 6.96 | 60.74 | 58.25 | |
| n79 | RX | 4700.00 | 51.28 | -2.90 | 6.95 | -7.82 | -0.90 | -2.22 | -2.65 | 6.58 | 6.62 | 52.69 | 64.01 | |
| n79 | RX | 5000.00 | 48.58 | -3.14 | 6.61 | -7.28 | -2.34 | -3.17 | -1.18 | 5.39 | 5.29 | 46.62 | 54.03 | |
| 46 | RX | 5150.00 | 44.52 | -3.51 | 6.23 | -7.26 | -2.58 | -3.60 | 0.78 | 4.62 | 3.75 | 42.13 | 57.88 | |
| 46 | RX | 5537.50 | 50.19 | -2.99 | 6.19 | -5.55 | -2.62 | -3.29 | 1.46 | 4.69 | 3.19 | 55.89 | 42.96 | |
| 46 | RX | 5925.00 | 48.09 | -3.18 | 5.90 | -5.67 | -3.68 | -5.18 | -1.18 | 4.50 | 4.65 | 49.29 | 56.94 | |
| 51.30 | 6.89 | |||||||||||||
| Ant 3 | ||||||||||||||
| 71 | RX | 617.00 | 51.84 | -2.85 | 4.13 | -6.30 | -1.51 | -2.11 | -2.08 | 4.05 | 3.55 | 79.81 | 85.00 | |
| 71 | RX | 652.00 | 54.70 | -2.62 | 4.29 | -2.84 | -1.70 | -1.34 | 0.79 | 4.21 | 3.76 | 73.92 | 85.20 | |
| 71 | RX | 663.00 | 53.39 | -2.73 | 4.43 | -5.44 | -2.26 | -1.14 | -2.32 | 4.21 | 4.13 | 65.92 | 88.96 | |
| 71 | TX | 698.00 | 58.18 | -2.35 | 4.47 | -4.97 | -1.74 | -0.70 | -1.26 | 4.19 | 4.40 | 69.43 | 90.21 | |
| 17 | TX | 710.00 | 51.85 | -2.85 | 4.29 | -3.47 | -0.16 | -1.76 | 0.47 | 4.18 | 4.10 | 115.04 | 61.72 | |
| 12 17 | TX | 716.00 | 54.26 | -2.65 | 4.38 | -5.86 | -1.26 | -2.99 | -1.55 | 4.34 | 3.41 | 85.22 | 64.75 | |
| 17 | RX | 734.00 | 52.52 | -2.80 | 5.19 | -7.24 | -1.44 | -1.58 | -3.97 | 4.69 | 4.98 | 74.86 | 66.32 | |
| 13 | RX | 751.00 | 55.01 | -2.60 | 5.26 | -7.17 | -1.70 | -1.37 | -3.35 | 4.87 | 5.17 | 61.97 | 64.75 | |
| 14 | RX | 768.00 | 52.39 | -2.81 | 4.74 | -7.23 | -1.74 | -1.70 | -3.61 | 4.73 | 4.52 | 56.25 | 70.34 | |
| 14 | TX | 798.00 | 50.11 | -3.00 | 4.44 | -7.09 | -2.52 | -2.12 | -3.86 | 2.36 | 4.44 | 107.47 | 58.87 | |
| 5 | TX | 824.00 | 50.54 | -2.96 | 4.22 | -6.23 | -2.83 | -1.97 | -3.22 | 2.19 | 4.20 | 104.55 | 65.32 | |
| 5 26 | TX | 849.00 | 48.74 | -3.12 | 4.34 | -5.52 | -1.75 | -2.40 | -1.44 | 3.74 | 4.06 | 61.50 | 63.11 | |
| 5 | RX | 869.00 | 51.20 | -2.91 | 4.28 | -5.58 | -1.89 | -1.89 | -2.90 | 3.02 | 4.21 | 103.48 | 63.32 | |
| 5 26 | RX | 894.00 | 51.13 | -2.91 | 4.62 | -4.01 | -0.71 | -0.90 | -0.57 | 4.01 | 4.62 | 97.46 | 85.53 | |
| 8 | RX | 925.00 | 51.65 | -2.87 | 4.31 | -6.07 | -2.83 | -2.25 | -3.04 | 3.14 | 3.43 | 62.40 | 85.57 | |
| 8 | RX | 960.00 | 51.07 | -2.92 | 4.70 | -5.24 | -4.26 | -1.41 | -1.21 | 1.46 | 4.61 | 81.03 | 57.16 | |
| 52.41 | 4.51 | |||||||||||||
| 75 | RX | 1432.00 | 50.06 | -3.01 | 5.07 | -8.01 | -2.43 | -4.01 | -3.24 | 3.16 | 2.12 | 96.36 | 68.15 | |
| 32 | RX | 1452.00 | 53.81 | -2.69 | 4.79 | -7.84 | -1.73 | -2.35 | -1.74 | 3.76 | 3.82 | 88.09 | 30.28 | |
| 32 | RX | 1474.00 | 53.17 | -2.74 | 5.70 | -7.69 | -0.59 | -1.43 | -1.46 | 5.52 | 5.44 | 76.84 | 42.06 | |
| 75 | RX | 1474.50 | 53.30 | -2.73 | 5.75 | -7.69 | -0.56 | -1.41 | -1.50 | 5.58 | 5.48 | 76.48 | 41.73 | |
| 32 | RX | 1496.00 | 55.95 | -2.52 | 5.81 | -8.64 | -0.92 | -1.75 | -4.41 | 5.73 | 5.73 | 62.06 | 36.62 | |
| 75 | RX | 1517.00 | 57.20 | -2.43 | 5.84 | -8.76 | -1.47 | -1.72 | -3.17 | 5.84 | 5.70 | 46.39 | 37.57 | |
| 53.91 | 5.49 | |||||||||||||
| 3 4 66 | TX | 1710.00 | 62.39 | -2.05 | 6.71 | -6.48 | -0.52 | -1.14 | -0.14 | 6.40 | 6.11 | 62.78 | 58.27 | |
| 3 | RX | 1805.00 | 59.80 | -2.23 | 6.34 | -9.41 | -0.81 | -1.02 | -4.73 | 6.25 | 5.69 | 40.10 | 70.98 | |
| 3 39 | RX | 1880.00 | 60.51 | -2.18 | 6.65 | -10.62 | -0.95 | -0.89 | -7.14 | 6.47 | 6.31 | 52.14 | 61.07 | |
| 1 | TX | 1920.00 | 60.86 | -2.16 | 7.21 | -10.25 | -0.92 | -0.86 | -6.82 | 6.62 | 6.80 | 51.96 | 55.13 | |
| 1 4 | RX | 2110.00 | 63.58 | -1.97 | 6.61 | -8.77 | -1.82 | -0.97 | -4.28 | 5.76 | 6.60 | 50.96 | 60.80 | |
| 1 | RX | 2170.00 | 61.08 | -2.14 | 6.77 | -8.24 | -2.42 | -0.57 | -3.11 | 5.70 | 6.77 | 49.55 | 64.12 | |
| 66 | RX | 2200.00 | 58.84 | -2.30 | 6.54 | -8.48 | -2.87 | -1.01 | -2.28 | 5.46 | 5.95 | 49.02 | 66.64 | |
| 40 | RX | 2300.00 | 64.60 | -1.90 | 7.65 | -6.77 | -1.95 | -0.92 | -1.63 | 6.39 | 7.13 | 43.68 | 47.59 | |
| 30 40 | RX | 2350.00 | 62.88 | -2.02 | 7.81 | -6.67 | -1.75 | -0.51 | -2.32 | 6.32 | 7.80 | 43.41 | 29.62 | |
| 40 | RX | 2400.00 | 59.50 | -2.25 | 7.46 | -7.01 | -1.45 | -1.05 | -3.09 | 6.79 | 7.43 | 42.30 | 39.25 | |
| 7 | TX | 2500.00 | 59.76 | -2.24 | 6.98 | -6.17 | -1.28 | -2.11 | -1.47 | 6.93 | 6.33 | 40.35 | 32.27 | |
| 38 | RX | 2595.00 | 58.20 | -2.35 | 6.30 | -6.26 | -3.25 | -1.98 | -0.53 | 5.91 | 5.09 | 41.45 | 59.37 | |
| 7 | RX | 2690.00 | 51.41 | -2.89 | 6.57 | -5.87 | -2.73 | -1.84 | -0.89 | 6.55 | 4.71 | 47.68 | 63.91 | |
| 60.26 | 6.89 | |||||||||||||
| n77 n78 | RX | 3300.00 | 50.80 | -2.94 | 7.02 | -9.72 | -0.66 | -2.58 | -4.66 | 6.88 | 4.89 | 68.59 | 46.42 | |
| 42 | RX | 3400.00 | 53.07 | -2.75 | 6.44 | -9.95 | -0.02 | -1.12 | -6.09 | 6.44 | 5.47 | 74.21 | 74.85 | |
| 48 n78 | RX | 3550.00 | 51.67 | -2.87 | 6.37 | -9.77 | -0.55 | -1.71 | -3.23 | 6.19 | 5.29 | 76.58 | 65.69 | |
| 42 43 | RX | 3600.00 | 54.44 | -2.64 | 6.57 | -9.88 | -0.44 | -1.25 | -2.67 | 6.53 | 5.76 | 75.19 | 69.94 | |
| 43 48 | RX | 3700.00 | 54.13 | -2.67 | 6.57 | -8.55 | -0.64 | -1.64 | -2.14 | 5.62 | 6.00 | 78.88 | 49.25 | |
| n78 | RX | 3800.00 | 54.05 | -2.67 | 5.69 | -9.25 | -0.83 | -1.99 | -2.64 | 5.40 | 5.35 | 87.21 | 56.62 | |
| n77 | RX | 4200.00 | 51.39 | -2.89 | 6.89 | -11.87 | -0.64 | -0.89 | -6.69 | 6.76 | 6.27 | 60.27 | 58.67 | |
| n79 | RX | 4400.00 | 51.24 | -2.90 | 7.07 | -11.00 | -0.23 | -1.62 | -6.03 | 7.07 | 6.20 | 57.51 | 49.32 | |
| n79 | RX | 4700.00 | 47.86 | -3.20 | 6.71 | -9.05 | -1.00 | -2.21 | -4.28 | 6.04 | 6.00 | 48.56 | 44.08 | |
| n79 | RX | 5000.00 | 47.58 | -3.23 | 6.55 | -7.36 | -2.22 | -3.10 | -1.80 | 4.17 | 4.52 | 82.67 | 54.40 | |
| 46 | RX | 5150.00 | 42.21 | -3.75 | 6.20 | -6.47 | -1.93 | -3.31 | 0.33 | 5.81 | 4.96 | 42.52 | 44.79 | |
| 46 | RX | 5537.50 | 46.26 | -3.35 | 5.98 | -3.96 | -1.47 | -3.64 | 2.52 | 5.31 | 5.27 | 54.78 | 28.94 | |
| 46 | RX | 5925.00 | 45.07 | -3.46 | 5.90 | -4.47 | -2.63 | -3.85 | 0.71 | 5.27 | 3.57 | 30.33 | 46.68 | |
| 49.98 | 6.46 | |||||||||||||
| Ant 4 | ||||||||||||||
| 71 | RX | 617.00 | 51.71 | -2.86 | 4.14 | -4.16 | -1.32 | -1.06 | -0.27 | 3.81 | 1.69 | 82.68 | 98.64 | |
| 71 | RX | 652.00 | 52.72 | -2.78 | 4.32 | -6.10 | -2.08 | -2.08 | -0.92 | 3.15 | 4.07 | 108.38 | 54.13 | |
| 71 | RX | 663.00 | 53.63 | -2.71 | 4.66 | -6.26 | -1.94 | -1.37 | -0.41 | 3.80 | 4.62 | 96.80 | 65.24 | |
| 71 | TX | 698.00 | 53.69 | -2.70 | 4.79 | -7.55 | -2.14 | -2.63 | -2.49 | 3.55 | 4.79 | 94.15 | 53.84 | |
| 17 | TX | 710.00 | 53.62 | -2.71 | 4.75 | -7.72 | -1.99 | -2.50 | -2.74 | 3.93 | 4.34 | 85.73 | 63.47 | |
| 12 17 | TX | 716.00 | 58.36 | -2.34 | 4.50 | -8.38 | -2.36 | -2.85 | -4.17 | 3.70 | 4.07 | 82.33 | 61.52 | |
| 17 | RX | 734.00 | 51.63 | -2.87 | 4.34 | -7.54 | -2.32 | -3.29 | -2.89 | 3.00 | 3.76 | 106.45 | 52.11 | |
| 13 | RX | 751.00 | 51.66 | -2.87 | 4.48 | -7.06 | -2.26 | -2.60 | -3.26 | 2.44 | 4.05 | 115.41 | 61.65 | |
| 14 | RX | 768.00 | 52.89 | -2.77 | 4.66 | -6.31 | -1.77 | -1.82 | -1.58 | 3.08 | 4.44 | 115.96 | 79.13 | |
| 14 | TX | 798.00 | 56.90 | -2.45 | 4.43 | -6.10 | -1.96 | -1.71 | -1.13 | 3.30 | 4.24 | 108.19 | 86.47 | |
| 5 | TX | 824.00 | 58.89 | -2.30 | 4.35 | -5.94 | -1.74 | -2.23 | -1.04 | 3.77 | 3.35 | 102.85 | 89.71 | |
| 5 26 | TX | 849.00 | 50.99 | -2.93 | 4.66 | -4.63 | -0.53 | -2.02 | -0.28 | 4.20 | 4.35 | 117.39 | 69.74 | |
| 5 | RX | 869.00 | 55.48 | -2.56 | 4.92 | -5.08 | -1.22 | -1.47 | -1.31 | 4.19 | 4.84 | 92.22 | 68.91 | |
| 5 26 | RX | 894.00 | 52.86 | -2.77 | 5.14 | -4.74 | -0.92 | -0.88 | -0.48 | 4.59 | 5.13 | 85.11 | 73.66 | |
| 8 | RX | 925.00 | 51.53 | -2.88 | 5.22 | -4.26 | -0.45 | -0.81 | 1.06 | 4.25 | 4.61 | 104.81 | 99.05 | |
| 8 | RX | 960.00 | 53.03 | -2.76 | 4.35 | -4.67 | -0.74 | -1.29 | 0.45 | 4.31 | 4.29 | 97.63 | 89.01 | |
| 53.72 | 4.61 | |||||||||||||
| 75 | RX | 1432.00 | 50.17 | -3.00 | 4.28 | -6.23 | -3.94 | -3.95 | -0.94 | 1.78 | 2.16 | 50.93 | 80.91 | |
| 32 | RX | 1452.00 | 57.50 | -2.40 | 4.66 | -4.62 | -1.55 | -1.36 | 0.10 | 4.52 | 4.60 | 75.57 | 85.47 | |
| 32 | RX | 1474.00 | 56.67 | -2.47 | 5.12 | -5.37 | -1.68 | -1.15 | 0.28 | 4.64 | 5.12 | 78.42 | 71.79 | |
| 75 | RX | 1474.50 | 56.50 | -2.48 | 5.11 | -5.40 | -1.70 | -1.16 | 0.29 | 4.63 | 5.11 | 78.24 | 71.72 | |
| 32 | RX | 1496.00 | 58.73 | -2.31 | 4.22 | -5.55 | -3.54 | -2.16 | 1.61 | 2.47 | 3.89 | 81.76 | 64.15 | |
| 75 | RX | 1517.00 | 53.96 | -2.68 | 4.19 | -4.80 | -4.23 | -3.20 | 0.68 | 1.28 | 2.30 | 91.31 | 61.93 | |
| 55.59 | 4.60 | |||||||||||||
| 3 4 66 | TX | 1710.00 | 65.81 | -1.82 | 6.23 | -7.27 | -0.46 | -0.52 | -2.44 | 6.14 | 6.21 | 64.19 | 72.91 | |
| 3 | RX | 1805.00 | 59.29 | -2.27 | 5.04 | -5.25 | -1.50 | -1.63 | -0.99 | 4.87 | 4.45 | 57.31 | 64.76 | |
| 3 39 | RX | 1880.00 | 58.65 | -2.32 | 6.40 | -7.17 | -0.78 | -0.68 | -2.39 | 6.01 | 6.05 | 72.61 | 61.64 | |
| 1 | TX | 1920.00 | 58.90 | -2.30 | 7.13 | -6.16 | 0.35 | -0.77 | -1.67 | 7.13 | 6.59 | 55.86 | 51.19 | |
| 1 4 | RX | 2110.00 | 58.45 | -2.33 | 6.58 | -6.99 | -1.51 | 0.05 | -2.40 | 6.54 | 6.48 | 44.87 | 67.99 | |
| 1 | RX | 2170.00 | 60.51 | -2.18 | 7.01 | -6.78 | -1.43 | -0.30 | -2.17 | 6.55 | 7.01 | 47.52 | 62.94 | |
| 66 | RX | 2200.00 | 58.29 | -2.34 | 6.58 | -6.36 | -1.69 | -0.16 | -2.78 | 6.47 | 6.49 | 44.20 | 64.83 | |
| 40 | RX | 2300.00 | 60.89 | -2.15 | 7.07 | -5.19 | -1.89 | -0.36 | -0.29 | 5.23 | 6.56 | 57.88 | 74.43 | |
| 30 40 | RX | 2350.00 | 56.87 | -2.45 | 8.00 | -6.56 | -1.92 | -0.71 | -0.45 | 5.42 | 7.74 | 53.39 | 49.05 | |
| 40 | RX | 2400.00 | 58.04 | -2.36 | 6.91 | -6.34 | -1.70 | -1.57 | -0.55 | 5.40 | 6.11 | 61.05 | 46.79 | |
| 7 | TX | 2500.00 | 54.16 | -2.66 | 6.28 | -5.71 | -2.32 | -2.50 | -1.27 | 4.70 | 5.61 | 61.77 | 49.15 | |
| 38 | RX | 2595.00 | 52.87 | -2.77 | 6.60 | -6.09 | -2.55 | -3.17 | -1.99 | 5.04 | 4.23 | 47.33 | 47.51 | |
| 7 | RX | 2690.00 | 51.12 | -2.91 | 5.50 | -6.47 | -3.57 | -5.29 | -1.83 | 2.09 | 1.61 | 46.13 | 41.23 | |
| 57.99 | 6.56 | |||||||||||||
| n77 n78 | RX | 3300.00 | 50.19 | -2.99 | 6.57 | -10.92 | -0.78 | -1.50 | -6.69 | 6.35 | 6.29 | 58.29 | 57.48 | |
| 42 | RX | 3400.00 | 51.63 | -2.87 | 6.64 | -10.90 | -0.26 | -1.83 | -5.62 | 6.61 | 6.55 | 58.17 | 53.19 | |
| 48 n78 | RX | 3550.00 | 54.10 | -2.67 | 7.15 | -9.44 | -0.87 | -1.12 | -5.13 | 6.33 | 6.77 | 61.43 | 69.34 | |
| 42 43 | RX | 3600.00 | 52.51 | -2.80 | 7.13 | -10.21 | -0.74 | -0.81 | -5.41 | 6.86 | 7.07 | 58.37 | 66.54 | |
| 43 48 | RX | 3700.00 | 53.44 | -2.72 | 6.77 | -9.77 | -1.31 | -1.16 | -5.06 | 6.67 | 6.77 | 66.54 | 66.14 | |
| n78 | RX | 3800.00 | 55.52 | -2.56 | 6.85 | -10.47 | -1.22 | -1.25 | -6.34 | 6.85 | 6.85 | 74.66 | 67.63 | |
| n77 | RX | 4200.00 | 53.43 | -2.72 | 7.27 | -10.46 | -0.14 | -1.45 | -6.33 | 6.66 | 6.95 | 39.20 | 62.59 | |
| n79 | RX | 4400.00 | 51.03 | -2.92 | 7.46 | -11.01 | -0.64 | -0.86 | -6.49 | 7.22 | 7.40 | 82.63 | 66.57 | |
| n79 | RX | 4700.00 | 50.55 | -2.96 | 6.65 | -9.58 | -1.64 | -1.88 | -4.19 | 6.65 | 6.37 | 77.08 | 63.51 | |
| n79 | RX | 5000.00 | 47.17 | -3.26 | 6.57 | -8.53 | -2.93 | -2.80 | -1.76 | 4.12 | 5.15 | 90.02 | 64.86 | |
| 46 | RX | 5150.00 | 42.91 | -3.67 | 6.83 | -8.90 | -3.95 | -3.11 | -1.60 | 3.37 | 5.02 | 52.91 | 66.16 | |
| 46 | RX | 5537.50 | 52.39 | -2.81 | 6.62 | -7.77 | -4.36 | -4.57 | -1.42 | 2.86 | 2.86 | 62.98 | 61.00 | |
| 46 | RX | 5925.00 | 46.14 | -3.36 | 6.09 | -6.68 | -4.48 | -4.83 | 0.16 | 3.92 | 2.57 | 52.16 | 70.92 | |
| 50.85 | 6.81 | |||||||||||||
