MG52 Internal Antenna Datasheet
MG52 also has a GPS antenna but the GPS functionality is not supported yet.
The internal antenna on the MG52 are enclosed inside for a sleek look while maintaining excellent performance. When in use the internal antenna has a bias towards the front face. The dipole shape of coverage the antennas generally excel at allowing users to place the MG in areas where a directional patch antenna cannot be mounted. A benefit of the internal antenna is the smaller footprint where it will be mounted.
Radiation Pattern (ANT0)
Radiation Pattern (ANT1)
Radiation Pattern (ANT2)
Radiation Pattern (ANT3)
