VM Sizing for Teleworker VPN
Based on the deployment requirements for the number of teleworker APs and the total anticipated throughput, you can choose the appropriate hardware specifications for your VM Concentrator server:
| Minimum CPU specs | # of Remote APs | VPN Throughput |
| 1 GHz CPU, 500 MB RAM, 1 GB Hard Drive | 1000 | 250 Mbps |
| 2 GHz CPU, 1 GB RAM, 5 GB Hard Drive | 3000 | 500 Mbps |
| 4 GHz CPU, 2GB RAM, 10 GB Hard Drive | 10000 | 1 Gbps |
More information on the VPN Teleworker and VM Concentrator solution is available at http://meraki.cisco.com/lib/pdf/meraki_datasheet_vpn.pdf
