Cloud-Managed Hybrid Operating Mode for Wireless Controllers LAN Controllers Requirements
Supported Wireless Controllers
Cloud-Managed Hybrid Operating Mode for Catalyst Wireless LAN Controllers (WLCs) supports the following wireless controller models:
Model Minimum Software Release
CW9800H1 / CW9800H2 IOS XE 17.15.3
CW9800M
C9800-80 IOS XE 17.12.3 / IOS XE 17.15.1
C9800-40
C9800-L-C / C9800-L-F
17.15.1 and later is required for Cloud CLI and CLI terminal
Supported Access Points
Cloud-Managed Hybrid Operating Mode for Catalyst Wireless LAN Controllers supports the following access point models when joined to a supported wireless controller:
Wi-Fi 7 Access Points
CW9178I IOS XE 17.15.3
CW9176I / CW9176D1
CW9172I / CW9172H IOS XE 17.17.1
1 Multi-Link Operation (MLO) information will not shown at launch. This will be built into later IOS XE releases.
Wi-Fi 6E Access Points
C9136I IOS XE 17.12.3 / IOS XE 17.15.1
CW9166I / CW9166D1
CW9164I
CW9163E
CW9162I
Wi-Fi 6 Access Points
C9130AXI IOS XE 17.12.3 / IOS XE 17.15.1
C9124AXI / C9124AXD / C9124AXE
C9120AXI / C9120AXE
C9117AXI
C9115AXI
C9105AXI / C9105AXW
Wi-Fi 5 (802.11ac Wave 2) Access Points
AIR-AP4800 IOS XE 17.12.3 / IOS XE 17.15.1
AIR-AP3802I / AIR-AP3802E
AIR-AP2802I / AIR-AP2802E
AIR-AP1562I / AIR-AP1562D / AIR-AP1562E
Licensing
Cloud-Managed Hybrid Operating Mode for Catalyst Wireless LAN Controllers requires a Cisco DNA software license. Access points require a Cisco DNA Essentials or Advantage license and the Catalyst WLC license level add-on enabled for DNA Essentials or Advantage. Dashboard Client traffic analytics powered IOS XE AVC is available only with a Cisco DNA Advantage license.
Supported Dashboard Clusters
Catalyst Wireless LAN Controllers are supported in the following Meraki dashboard clusters:
Wireless Controller Dashboard Scale
When Catalyst WLCs are connected to the dashboard, the monitoring feature of the dashboard supports a maximum number of concurrently connected access points and clients at the following scales:
Model
Number of access points
Number of clients
C9800-L (F or C)
250
3,000
C9800-40 / CW9800M
1,300
10,000
C9800-80 / CW9800H1 / CW9800H2
2,000
20,000
If any wireless controller model exceeds 2,000 access points joined, the dashboard will stop collecting telemetry data until the AP joined count is lowered to under 2,000. An alert will be logged for the wireless controller if dashboard is unable to continue to collect telemetry data.
Increased scale for all Catalyst WLC appliances may be available in future IOS XE releases.
Cloud Connectivity
In order to connect and monitor a Catalyst Wireless LAN Controllers with dashboard, it must be able to communicate with the Cisco Meraki cloud over a secure tunnel.  Because the dashboard is located on the public internet, the tunnel is always initiated outbound from the Catalyst WLC and any upstream firewalls or access controls must permit wireless controllers and access points to access dashboard IP addresses. Once a connection is established, the wireless controller maintains the connection by occasionally sending and receiving keep-alive packets.
In addition to permitting wireless controllers to access dashboard IP addresses, access points must also be permitted outbound through the firewall so they can be registered with the dashboard. After an access point completes its registration, it will no longer contact the dashboard.
When a firewall or gateway exists in the data path between the wireless controller, access points and dashboard, Cisco Meraki cloud IP addresses and ports must be permitted outbound through the firewall for the secure tunnel to function.
Access points only communicate with the dashboard to register at which point they cease contact.
Destination IP
Port
Protocol
209.206.48.0/20
443
TCP
216.157.128.0/20
443
TCP
158.115.128.0/19
443
TCP
AVC Enablement for Traffic Analytics (Web UI and CLI)
In order for Traffic Analytics data to display in the dashboard, the Application Visibility must be enabled on the Catalyst WLC. Client traffic analytics powered IOS XE AVC is available only with a Cisco DNA Advantage license.
  1. In the wireless controller web interface, navigate to Configuration > Services > Application Visibility:
Enable AVC in Cisco DNA for Catalyst AP
  1. Select Configured Profiles, apply application visibility on them and enable local collector (external collector not required for dashboard to display traffic analytics).
  2. The dashboard requires an additional profile configuration that is NOT configured by the web UI and must be done in the command line.
Wireless profile policy must be SHUTDOWN before adding the following commands. Clients connected to SSIDs using this Policy Profile will be disconnected when the policy is shut down.
wireless profile policy <Your Policy Profile Name>
 ip nbar protocol-discovery
Enable NBAR protocol-discovery on other policy profiles as needed.
AVC Enablement for Traffic Analytics (CLI Only)
  1. To enable Application Visibility, first configure a local destination flow exporter:
flow exporter wireless-local-exporter
 destination local wlc
  1. Next, configure two flow monitors, one for IPv4 and one for IPv6 records.
flow monitor wireless-avc-basic
 cache timeout active 60
 record wireless avc basic
flow monitor wireless-avc-basic-ipv6
 record wireless avc ipv6 basic
Wireless profile policy must be SHUTDOWN before adding the following commands. Clients connected to SSIDs using this Policy Profile will be disconnected when the Policy is shutdown.
 shut
 ipv4 flow monitor wireless-avc-basic input
 ipv4 flow monitor wireless-avc-basic output
 ipv6 flow monitor wireless-avc-basic-ipv6 input
 ipv6 flow monitor wireless-avc-basic-ipv6 output
 no shut
Enable these commands on other policy profiles as needed.
Device Classification Enablement (Web UI)
In order for Device type and OS data for clients to display in Dashboard, the Device Classification must be enabled on the Catalyst WLC.
  1. In the wireless controller web interface, navigate to Configuration > Wireless > Wireless Global:
  1. Select Device Classification and click Apply.
  2. After enabling device classification globally, client profiling can be enabled on  Policy Profiles by navigating to Configuration > Tags & Profiles > Policy > Edit Policy Profile > Access Polices:
Cisco DNA, enabling client profiling in the access policies.
  1. Select HTTP TLV Caching and DHCP TLV Caching and click Update and Apply to Device.
Dashboard Sizing Best Practices
Please see Meraki Cloud Sizing and Scaling Considerations and Best Practices for recommendations on inventory & per-network device limits
