Using the MR Live Tools
Live tools on the Monitor > Access Points page can provide important information and assist with troubleshooting. The Live tools will be supported on both Cloud Managed Access Points and Catalyst Access Points that are joined to a WLC that is in Cloud-Managed Hybrid Operating Mode.
IOS XE 17.18.1 is required for AP Live Tools.
To use Live Tools, select the access point of interest from the Monitor > Access points page. This article is an overview of the available services associated with this feature.
  • Current clients
  • Ping
  • ARP table
  • Traceroute
  • Throughput
  • Blink LEDs
  • Reboot APs
  • Splash pages
Learn more with these free online training courses on the Networking Learning Hub:
Summary Tab
Current clients
The Current clients tool loads automatically by default and shows the number of clients connected, data usage for the AP in total and per user, as well as how well and how long the user has been associated. You may also ping each currently connected client.
Screenshot shows the number of clients connected, data usage for the AP and user, how long the user has been associated and the Signal strength. You can also ping each connected client.
Historical Clients
The Historical Clients section shows clients and their recorded usage for the selected time range. Connection details are based on available records for this access point during that range.
  • Description: The client description.
  • Usage: The client’s recorded data usage.
  • IP Address: The client’s IP address.
  • MAC Address: The client’s MAC address.
  • Last SSID: The most recent SSID the client used.
  • Last SSID: The SSID associated with the client’s most recent recorded connection to this AP within the selected time range.
  • First seen: When the client first connected to this AP within the selected time range, based on available connection records.
  • Last seen: When this AP last recorded activity from the client, based on traffic or connection events. The client may no longer be connected.
  • Last connected: When the client’s most recent recorded connection to this AP started within the selected time range.
  • Connection time: The duration of that most recent recorded connection, measured from Last connected until the recorded disconnection, or until the end of the selected time range if no disconnection was recorded. This value describes the latest connection only.
  • Adaptive policy group: The adaptive policy group associated with the client, when listed.
Some fields may be unavailable when the connection of a client happens outside of the selected time range.
The AP Details Historical Clients table now shows each client’s last SSID, first and last seen times, last connected time, and connection duration. Use these details to trace a client’s recent presence and session history when troubleshooting unexpected disconnects or intermittent connectivity. Use the pagination controls to view more clients.
Tools Tab
The following tools can be accessed by navigating to the Tools tab of the MR's status page.
Ping
Run a Ping test to any client that is connected wirelessly to the AP or to any client that should be reachable over the wired network. You can also run a ping test from Meraki dashboard to the AP by clicking Ping AP.
Screenshot shows Ping tool for MR
Reboot Device
If the AP is checking into the cloud and you would like to perform a reboot without unplugging the device you can click on Reboot AP to reboot the device.
Screenshot shows on how to reboot the MR device from Tools section
Blink LEDs
This tool helps find the AP. Also, if you are running in Dark Mode where the LEDs are not on, this tool will blink the LEDs so that you can see if the device is functioning or not. This tool flashes all the LEDs on the device in unison
Screenshot shows on how to Blink LEDs on MR device from Tools section
Note: For some MR models (e.g., MR45/MR46), the LED may take up to 60 seconds to stop blinking when this operation is suspended.
Dashboard throughput
This tool allows a throughput test to be performed between the AP and Meraki dashboard.  For more information, review the article on the Throughput live tool.
Note: This is not meant as a tool to test the overall throughput available from an AP to the Internet.
Screenshot shows how to run dashboard throughput test on MR from Tools Tab
Traceroute
Run a traceroute from the AP to any host upstream.  This lets you know the route information from the AP to the specific host.  Learn more about using traceroute here .
Screenshot shows how to run traceroute on MR from Tools Tab
ARP table
The ARP table live tool can be used to view the AP's ARP table. This will display a list of IP addresses and the MAC addresses they are mapped to.
Screenshot shows ARP table. ARP table gives a list of clients connected with their IP and MAC addresses
Splash Pages
The Splash Pages tool will allow the admin to verify functionality of the configured Splash Pages for the Access Point that is currently selected. This will simulate the client experience and can be used to verify Splash operation directly from Dashboard. Please note that if there are no Splash profiles assigned to this Access Point, no Splash Pages to test will be present. Clicking any of the Splash pages hyperlinks will open the splash page in a new tab in your browser.
These tools will only work with APs that are online and communicating with the Dashboard. If you are trying to use one of these tools and they are taking a long time to load, this can be due to a few reasons:
  1. If the AP is currently working at capacity due to large number of clients or data passing through the device, these tools will take time to load because the AP’s resources are taxed
  2. If the AP is having problems connecting to the cloud controller, these tools will either not load or load slowly. Learn more about troubleshooting this here .
  3. If there is a problem on your local lan that is impeding traffic or your connection is slow, this can cause long load times as well.
Learn how to troubleshoot interference issues in the following articles:
Meraki for Events and high density deployments
Tools for Troubleshooting Poor Wireless Performance
Common Source of Wireless Interference
