How to Resolve Low Power Mode on Cisco Switches
Overview
Understanding low power mode
When you connect a Cisco Meraki MR access point (AP) to several switch models that provide power to the AP, you may sometimes run into an insufficient power scenario if the switch uses Cisco Discovery Protocol (CDP) defaults only. Low power mode is the name for the insufficient power scenario.
For low power mode situations on APs that connect to Catalyst switches, make sure the switch has Link Layer Discovery Protocol (LLDP) enabled. For instructions, go to the Enable LLDP on a Cisco Catalyst switch section in this article.
PoE standards
| Industry Standard | IEEE Standard | Description |
PoE |
802.3af | Original PoE standard, which provides up to 15.4 W. Now also known as Legacy PoE. |
| PoE+ | 802.3at | Provides up to 30 W. Requires LLDP working together with PoE+ when providing more than 15.4 W. |
| UPoE | Cisco proprietary (802.3bt based - Type 3) | Universal PoE (UPoE). Cisco proprietary technology that extends the IEEE 802.3 PoE standard to provide the capability to source up to 60 W of power per port over CDP or LLDP. |
| PoE++ | 802.3bt | At the moment, 802.3bt is the latest standard. Provides up to 100 W. Requires LLDP working together with PoE++ when providing more than 30 W. |
Low power mode examples
As a general best practice, check the AP and switch datasheets to make sure both comply with the same or compatible standards.
Scenario one
An MR44 can operate at different power levels:
30 W maximum (PoE+)
15 W maximum (PoE)
The MR44 prefers to operate in PoE+. If the MR44 connects to a switch that supports neither CDP nor LLDP, the MR44 falls back to PoE. CDP is not mandatory in PoE+ per IEEE standards, but LLDP negotiation is generally used to negotiate power allocation above 15.4 W. Therefore, a low power mode scenario occurs in this case.
Low power mode can occur because MR access points may need to use LLDP in addition to CDP, while some Cisco switches do not enable LLDP by default. You must ensure that the switch supports LLDP and that you enable LLDP on the switch and on the Ethernet port that connects to the AP.
Scenario two
An MR57 can operate between PoE++ and PoE+ power levels. The MR57 requires extra power to perform additional features, such as USB support, that elevate power consumption above 30 W.
The MR57 prefers to operate at the PoE++ level but falls back to PoE+ if the MR57 connects to a switch that does not support both CDP and LLDP. CDP is also not mandatory in PoE++ per the IEEE standard. However, the same standard requires LLDP to negotiate power levels above 30 W.
If an MR57 connects to a switch that does not support both CDP and LLDP, the MR57 operates in low power mode.
Step-by-step instructions
How to enable LLDP in a Cisco Catalyst switch
Step 1: Enable LLDP globally on a switch running IOS:
Switch# configure terminal Switch(config)# lldp run Switch(config)# end
Step 2: Enable LLDP on the specific interfaces where you will connect the access points. Use the following example for IOS devices, and replace interface_id with the actual designation for the interface:
Switch# configure terminal Switch(config)# interface interface_id Switch(config-if)# lldp transmit Switch(config-if)# lldp receive Switch(config-if)# end
Step 3: To renegotiate power, use one of the following methods:
- Reboot the AP in the Meraki dashboard.
- Shut down the port on the switch and then re-enable the port:
Switch# configure terminal Switch(config)# interface interface_id Switch(config)# shutdown Switch(config)# no shutdown Switch(config)# end
- Disable and then re-enable PoE without shutting down the port itself, using the power inline command:
Switch# configure terminal Switch(config)# interface interface_id Switch(config)# power inline never Switch(config)# power inline auto Switch(config)# end
Verification
After you complete the previous steps, the switch and AP should be able to negotiate up to the required power level.
Troubleshooting
If the switch and AP still do not negotiate the required power level, make sure the switch port allows up to 30 W of power for the connected device:
Switch# configure terminal Switch(config)# interface interface_id Switch(config-if)# power inline max 30000 Switch(config-if)# end
On newer Cisco switches, substitute power inline max 30000 for power inline static max.
For more information, refer to Low Power Mode.
