Conversion from CLI-managed IOS XE Catalyst Switches to Cloud Management with Cloud Configuration
Click 日本語 for Japanese
Attempting to migrate unsupported models may result in an unusable switch. Please review the list of supported models below before proceeding with the upgrade.If you intend to migrate your Catalyst switches to the legacy container-based management solution (any CS firmware version), please refer to the “ Getting Started: Cisco Catalyst 9300 Management with Meraki Dashboard” documentation.
This article covers the migration of Catalyst switches from CLI or DNA-managed mode to cloud operating mode on the Meraki dashboard, supported by the Cloud Management with IOS XE 17.15+.
Check out our latest Cloud Entitlement for DNA offer. Eligible devices can migrate to cloud management using your existing DNA license - no additional license migration or transfer required until February 1, 2029.
Overview
With the release of cloud management with IOS XE 17.15+, we are introducing cloud management with cloud configuration on IOS XE. This brings several enhancements to your Cisco cloud-managed Catalyst switches. Notably, you will experience improved boot times, especially for stacks compared to previous versions of cloud management. Additionally, you can now access the CLI through the dashboard to run show commands for troubleshooting.
IOS XE 17.15+ release comes with the capability to convert the supported Catalyst 9000 switches (including the 9200L for the first time ever) from DNA management mode to cloud management with cloud configuration on the Meraki dashboard. This functionality migrates the switch or switch stack to become fully managed by Meraki dashboard. During the migration process the switch's configuration, flash, USB-flash, and all storage will be formatted and reconfigured to the Meraki runtime.
This document gives you a step-by-step explanation on how to migrate your existing supported Catalyst switch to Cloud Management mode. For details on the cloud management with IOS XE architecture and software capabilities of this new release, please refer to the firmware release highlights or the FAQ document.
Prerequisites
Supported Models
Migration is available for the following Catalyst 9000 models.
Full encryption IOS-XE is required for migration. No Payload Encryption (NPE) versions are not supported for this purpose. For example, the NPE version of cat9k_lite_iosxe_npe.17.15.03.SPA.bin is unsupported. Furthermore, install mode is required, attempting to migrate using bundle mode will result in an error.
ATTEMPTING TO CONVERT UNSUPPORTED MODELS WITHOUT MEETING MINIMUM FIRMWARE REQUIREMENT MAY RESULT IN A UNUSABLE SWITCH. PLEASE REVIEW THE LIST OF SUPPORTED MODELS BEFORE PROCEEDING WITH THE UPGRADE.
| Family | Models | Minimum Required Version |
| C9200L | C9200L-24T-4X , C9200L-24P-4X, C9200L-48T-4X , C9200L-48P-4X , C9200L-48PL-4X , C9200L-24PXG-4X , C9200L-48PXG-4X , C9200L-24PXG-2Y , C9200L-48PXG-2Y , C9200L-24T-4G , C9200L-24P-4G , C9200L-48T-4G , C9200L-48P-4G , C9200L-48 PL-4G | 17.15+ |
| C9300-M | C9300-24T-M, C9300-24P-M, C9300-24U-M , C9300-24UX-M , C9300-48T-M , C9300-48P-M , C9300-48U-M , C9300-48UXM-M , C9300-48UN-M , C9300-24S-M, C9300-48S-M , C9300X-12Y-M, C9300X-24Y-M, C9300X-48HXN-M, C9300X-24HX-M, C9300X-48HX-M, C9300X-48TX-M, C9300L-24P-4X-M, C9300L-24T-4X-M, C9300L-24UXG-4X-M, C9300L-48P-4X-M, C9300L-48PF-4X-M, C9300L-48T-4X-M, C9300L-48UXG-4X-M, and its corresponding Catalyst switch SKUs for migration. | |
| Remaining C9300 models | C9300-24UB, C9300-24UXB, C9300-48UB, C9300-24H, C9300-48H, C9300L-24T-4G, C9300L-48T-4G, C9300L-24P-4G, C9300L-48P-4G, C9300L-48PF-4G, C9300L-24UXG-2Q, C9300L-48UXG-2Q, C9300LM-48UX-4Y, C9300LM-48U-4Y, C9300LM-24U-4Y, C9300LM-48T-4Y | 17.18+ |
| C9200 | C9200-24T, C9200-24P, C9200-24PB, C9200-24PXG, C9200-48T, C9200-48P, C9200-48PL, C9200-48PB, C9200-48PXG | |
| C9200CX | C9200CX-12T-2X2G, C9200CX-12P-2X2G, C9200CX-8P-2X2G, C9200CX-8UXG-2X, C9200CX-12P-2XGH, C9200CX-8P-2XGH, C9200CX-8UXG-2XH | |
C9500H: high-performance switch with 100G Uplink |
C9500-48Y4C, C9500-24Y4C, C9500-32C, C9500-32QC | |
Supported Firmware
For the migration to Meraki cloud operating mode, switches are required to be on IOS-XE 17.15+. The special firmware release can be downloaded from the software download page.
| Firmware Version | Software Download Page |
| 17.15 | For C9300/L/X, please use image cat9k_iosxe.17.15.xx.SPA.bin that can be downloaded from the software download page. |
| For C9200L, please use image cat9k_lite_iosxe.17.15.xx.SPA.bin that can be downloaded from the software download page. | |
| 17.18 | For C9300/C9500H, please use image cat9k_iosxe.17.18.xx.SPA.bin that can be downloaded from the software download page. |
| For C9200/L/CX, please use image cat9k_lite_iosxe.17.18.xx.SPA.bin that can be downloaded from the software download page. |
Conversion Steps from DNA Management Mode to Cloud Management with Cloud Configuration
To convert to Meraki cloud management with cloud configuration, follow the steps below:
- Validate compatibility of the hardware and upgrade to the required minimum IOS-XE release.
- Initiate Meraki registration of the Catalyst switch.
- Claim the switch to a Meraki organization using the cloud ID.
- Add the switch to the respective dashboard network for management.
The following image shows the migration process:
The migration steps are explained in detail in the following sections:
Note: For C9350 switches, please reference the Smart Switch onboarding guide.
Step 1: Validate Compatibility and Upgrade to the Minimum IOS-XE Release
To validate that your Catalyst switch has the hardware and software configuration compatible with the Meraki cloud operating mode, run the following command from the IOS-XE CLI.
show meraki compatibility
Switch#show meraki compatibility ================================================== Compatibility Check Status -------------------------------------------------- Boot Mode INSTALL - Compatible Stackwise Virtual Disabled - Compatible -------------------------------------------------- ------------------------------------------------------------------------------------------- Switch# SKU Bootloader Version Network Modules ------------------------------------------------------------------------------------------- 1 C9300-48U - Compatible 17.10.1r - Compatible C9300-NM-8X - Compatible ---------------------------------------------------------------------------------------------------------------------- Compatible SKUs: C9300-24P, C9300-24T, C9300-24U, C9300-24UX, C9300-48P, C9300-48T, C9300-48U, C9300-48UN, C9300-48UXM Compatible NMs : C3850-NM-2-40G, C3850-NM-4-10G, C3850-NM-8-10G, C9300-NM-2Q, C9300-NM-8X, MA-MOD-2X40G, MA-MOD-4X10G, MA-MOD-8X10G ----------------------------------------------------------------------------------------------------------------------
Note: Before attempting to migrate any switch and included network modules, run the Meraki compatibility check first. Ensure the compatibility check passes and that your switch is one of the supported models. Do not attempt to migrate any switches that are not in the supported models list. Failure to follow supported models list may result in an unusable switch. Please review the list of supported models before proceeding with the upgrade.
Step 2: Initiate Registration with the Cloud
Ensure that the Catalyst switch is able to connect to the internet and resolving dashboard.meraki.com.
To resolve DNS names and communicate with the Meraki Dashboard, the Catalyst switch will need the following configuration.
- A layer 3 interface with an IP address that has connectivity to the internet.
- A next-hop or default gateway IP which the switch can use to send traffic to the internet.
- A DNS server which can resolve dashboard.meraki.com.
- "internet bound" vlan configured as http client source-interface
Example script while in global configuration mode:
vlan {vlan used for cloud connectivity}
exit
interface vlan {VLAN where DHCP is present}
ip address dhcp
no shutdown
exit
ip route 0.0.0.0 0.0.0.0 dhcp
ip http client source-interface {vlan-interface}
ip name-server 8.8.8.8
You can check whether the switch is configured correctly by pinging dashboard.meraki.com
Note:
- Do not use the out-of-band (Gig0/0) management port on the rear of the switch for internet connectivity. Front facing ports only.
- SVIs only, no routed port support at this time.
Once you have validated that the switch can reach the Meraki Dashboard, use the following command within the configure terminal to register the switch(es) unit or stack member with dashboard:
Single Member or Stack Active member:
Switch# configure terminal Switch(config)# service meraki connect
During the registration process, the switch will communicate with the Meraki Dashboard to register itself and receive its Meraki ID or Cloud ID. Each switch, including switches in a stack1 will receive an individual Meraki ID. The Catalyst serial number and Meraki ID mapping, along with the registration status, will be displayed on the CLI terminal, as shown in the following image:
.png?revision=1)
1 C9500s cannot be onboarded as a stack. Please remove the StackWise Virtual configuration, reboot the switches, and onboard as standalone switches.
You can also issue the show meraki connect command to view the status of the registration and its details as shown below. Once the output of show meraki connect indicates that the meraki tunnel config fetch has succeeded, the switch is ready to be claimed on the Meraki dashboard.
Switch# show meraki connect
Step 3: Claim the Switch to Meraki Dashboard Using Cloud ID
Once the output of show meraki connect indicates that the config fetch has succeeded, the switch is ready to be claimed on the Meraki dashboard. The cloud ID generated as part of the registration process above will be needed to claim the devices to your Meraki dashboard. Navigate to the Organization>Inventory page on the Meraki dashboard and claim the switch.
If you need information on creating a Meraki Dashboard account, refer to our documentation on Creating a Dashboard Account and Organization.
Step 4: Add the switch to the dashboard network
When you are ready to convert the device to cloud operating mode, add the device to a dashboard network. Conversion to cloud management with cloud configuration will not happen until the device has been added to a dashboard network.
After choosing an eligible Catalyst switch to add to a network, you will be prompted to select which Dashboard network you would like to use. Then, you can select the operating mode.
After the device has been added to a dashboard network (while still connected to an uplink and able to resolve the cloud), conversion to Meraki cloud operating mode will begin , initiating a factory reset procedure and restricting the console to read-only mode.
The switch may take up to 15 minutes to factory reset, and reboot, and connect to the dashboard in Meraki cloud operating mode.
DO NOT power cycle the switches during the factory reset process. The console connection remains in read-only mode and can be used to monitor the process.
Once the migration has been successful, use the local status page to make basic configuration updates. For information on how to access and use the local status page please refer to our documentation on Using Cisco Meraki Device Local Status Page.
The conversion process will erase all configuration and files stored locally, or on any attached USB devices. Be sure to back up all necessary data from the local or connected storage, prior to initiating the conversion. It is recommended that USB storage devices be disconnected, as they will not be accessible in Meraki cloud operating mode.
During conversion, the switch or switch stack may reboot one or more times to enable 802.3bt. Once the switch has rebooted console access will be restricted to read-only mode, only showing log events. The switch will boot up with default configurations for connecting to Meraki dashboard. Refer to our documentation on MS390 Deployment Best Practices for more information on how zero-touch deployment works and the best practice configurations.
If an RMA is done for a migrated Cisco Catalyst 9300 switch, the replacement will come in the management mode for which the unit was originally purchased.
Conversion to DNA management mode
To convert your Catalyst switch(es) to DNA management mode, contact Meraki Support. To be converted, a switch must be online and connected to the Meraki dashboard.
Migration will factory default the switch and all configuration.
When operating in the Meraki cloud management mode with cloud configuration, Catalyst switches use firmware customized for cloud connectivity.
Once the migration to DNA or CLI managed mode is complete, please be sure to install a supported Cloud Management with IOS XE software version on the switches before deploying them in production networks in order to support cloud management with device configuration.
