Catalyst 9200L-M Datasheet
Overview
The Catalyst 9200L-M meets the demands of enterprise applications by combining the simplicity of the Meraki dashboard with powerful switching hardware. It supports high-bandwidth applications and high-speed Wi-Fi access points with multigigabit ports and 80GB stacking. It offers either four fixed 1G/10G or two fixed 25G uplinks. The switch delivers resiliency through fast stack convergence. It uses Adaptive Policy with an over-the-wire tag to segment traffic into security groups, providing scalable security. Integrated with the Meraki dashboard, the Catalyst 9200L-M offers a simple yet powerful solution for demanding wired access applications.
Adaptive Policy provides simple & scalable security policies to segment traffic using Security Groups. Security Groups are created in the dashboard using natural language such as “IOT device” & “Guest.” The security policy intent (e.g., Permit or Deny) is then simply provisioned between Security Groups which results in the segmentation of each group’s traffic. By making security policy management intuitive and scalable relative to legacy IP-address based Access Control Lists, Adaptive Policy empowers operators to confidently secure their network traffic independent of future network changes.
The image illustrates how Adaptive Policy uses Security Groups to create simple, scalable security policies that segment network traffic for easier and more effective management.
A Catalyst 9200L switch can also be migrated to a Meraki-managed persona, where it would function as its Catalyst Meraki 9200L-M equivalent. For details on the migration process, refer to our Getting started: Cisco Catalyst 9200 with Meraki Dashboard guide.
Models
Number of Ports Model Description
24 Ports
C9200L-24T-4G-M 24-port 1 GbE Data with 4x 1G fixed uplinks,
PWR-C5-125WAC
C9200L-24P-4G-M 24-port 1GbE PoE+ with 4x 1G fixed uplinks,
PWR-C5-600WAC
C9200L-24T-4X-M
24-port 1 GbE Data with 4x  1G/10G fixed uplinks,
PWR-C5-125WAC
C9200L-24P-4X-M
24-port 1GbE PoE+ with 4x 1G/10G fixed uplinks,
PWR-C5-600WAC
C9200L-24PXG-4X-M
24-port PoE+, 8 mGig(10G/5G/2.5G/1G/100M) with 4x 1G/10G fixed uplinks,  PWR-C5-600WAC
C9200L-24PXG-2Y-M
24-port PoE+, 8 mGig(10G/5G/2.5G/1G/100M) with 2x 1G/10G/25G fixed uplinks,
PWR-C5-600WAC
48 Ports
C9200L-48T-4G-M
48-port 1 GbE Data with 4x 1G fixed uplinks,
PWR-C5-125WAC
C9200L-48P-4G-M
48-port 1GbE PoE+ with 4x 1G fixed uplinks,
PWR-C5-1KWAC
C9200L-48PL-4G-M
48-port 1GbE partial PoE+ with 4x 1G fixed uplinks,
PWR-C5-600WAC
C9200L-48T-4X-M
48-port 1 GbE Data with 4x  1G/10G fixed uplinks,
PWR-C5-125WAC
C9200L-48P-4X-M
48-port 1GbE PoE+ with 4x 1G/10G fixed uplinks,
PWR-C5-1KWAC
C9200L-48PL-4X-M
48-port 1GbE partial PoE+ with 4x 1G/10G fixed uplinks,
PWR-C5-600WAC
C9200L-48PXG-4X-M
48-port PoE+, 12 mGig(10G/5G/2.5G/1G/100M) with 4x 1G/10G fixed uplinks,
PWR-C5-1KWAC
C9200L-48PXG-2Y-M
48-port PoE+, 8 mGig(10G/5G/2.5G/1G/100M) with 2x 1G/10G/25G fixed uplinks,
PWR-C5-1KWAC
Features
Category Features
Highlights
  • Layer-3
  • Four SFP+(10G/1G) fixed uplinks on 4X models
  • Two SFP28(25G/10G/1G) fixed uplinks on 2Y models
  • mGig support on XG models
  • 80G Dual Dedicated Hardware Stacking Ports
  • PoE+ (30W per port) & IEEE 802.3at
  • Redundant hotswappable power supplies
Management
  • Managed via Cisco Meraki Dashboard
  • Zero-touch remote provisioning (no staging needed)
  • Basic configuration capability via local management page
  • Detailed historical per-port and per-client usage statistics
  • Operating System, device, and hostname fingerprinting
  • Automatic firmware upgrades with scheduling control
  • SNMP and SYSLOG support for integration with other network management solutions
Remote Diagnostics
  • Email, SMS and Mobile push notification alerts
  • Ping, traceroute, cable testing, and link failure detection with alerting
  • Remote packet capture
  • Dynamic and interactive network discovery and topology
  • Combined event and configuration change logs with instant search
Stacking**
  • Optional stacking kit allowing 8 switches in a stack with 80Gbps of stacking bandwidth
  • Virtual stacking supports thousands of switch ports in a single logical stack for unified management, monitoring, and configuration
  • Faster convergence
Ethernet Switching Capabilities
  • 802.1p Quality of Service, 8 queues (w/ 6 configurable for DSCP-to-CoS mapping)
  • 802.1Q VLAN and trunking support for up to 1024 active VLANs with STP disabled. This is reduced to 512 active VLANs when utilizing MST and 128 active VLANs when using PVST+.
  • Single Instance of 802.1s Multiple Spanning Tree Protocol (interoperable with RSTP, STP, PVST, RPVST)
  • STP Enhancements: BPDU guard, Root guard, Loop guard, UDLD
  • Broadcast storm control
  • 802.1ab Link Layer Discovery Protocol (LLDP) and Cisco Discovery Protocol (CDP)
  • 802.3ad Link aggregation with up to 8 ports per aggregate, multi-chassis aggregates supported on stacked switches
  • Port mirroring
  • IGMP snooping for multicast filtering
  • MAC Forwarding Entries: 16K
Layer 3
  • Static routing, OSPFv2
  • Multicast routing (ASM: PIM-SM)
  • Warm Spare (VRRP) *
  • DHCP Server, DHCP Relay
Security
  • Integrated multi-factor authentication for Dashboard management
  • Role-based access control (RBAC) with granular device and configuration control
  • Corporate wide password policy enforcement
  • IEEE 802.1X RADIUS and MAB, hybrid authentication and RADIUS server testing
  • Single-Host/Multi-Domain/Multi-Host/Multi Authentication
  • Port security: Sticky MAC, MAC Allow listing *
  • DHCP snooping, detection and blocking, Dynamic ARP Inspection
  • IPv4 and IPv6 ACLs
  • Secure Connect *
  • Adaptive Policy
* Available in a future software release
**Stacking Limit for C9200L(-M): C9200L series models running Cloud Management with IOS XE 17.15+ support stacking configurations of up to 5 members. Please ensure your stacks for these models adhere to this limit. Exceeding 5 members may lead to unexpected behavior. This will be resolved in a future release.
Catalyst 9200L-M Licensing
The Catalyst 9200L-M license applies to all C9200L hardware platforms. Catalyst 9200L-M license structure includes two feature tiers:  Enterprise and Advanced.  As with all Meraki managed switches, every Catalyst 9200L-M license is available in 1, 3, and 5 year terms.
Catalyst 9200L-M License Structure 24-Port 48-port
Advanced Features LIC-C9200L-24A LIC-C9200L-48A
Enterprise Features LIC-C9200L-24E LIC-C9200L-48E
The features available with advanced licensing are:
In the Co-term licensing model (most existing Organizations), an Organization must either have all Catalyst 9200L-M Enterprise or all Catalyst 9200L-M Advanced licenses - they cannot be mixed. In the Per-device licensing model, a mix of Enterprise and Advanced can be added to a single Organization, but certain features may require all devices in a Network to have Advanced licenses, e.g. Adaptive Policy.
MS390s and or Catalyst 9300/L/X-M existing in the same co-term Organization will require the same license edition (either Enterprise or Advanced) as the Catalyst 9200L-M. License types cannot be mixed and will result in an incompatible license error.
For more information on licensing, refer to Meraki Licensing Models article.
Subscription licensing is also available for the Catalyst 9200L-M switches
Technical Breakdown
Interfaces Specifications
Model Interfaces
Fixed Uplinks
(SFP+/SFP28)
80G Hardware Stack Ports
Dedicated Management
Interface
PoE
Capabilities
C9200L-24T-4G-M
24 1G ports data
4x 1G SFP
2 1 n/a
C9200L-24P-4G-M
24 1G ports full PoE+
4x 1G SFP 2 1 30W PoE+
C9200L-24T-4X-M
24 1G ports data 4x 10G/1G SFP+ 2 1 n/a
C9200L-24P-4X-M
24 1G ports full PoE+ 4x 10G/1G SFP+ 2 1 30W PoE+
C9200L-24PXG-4X-M
24 ports full PoE+ (8 mGig ports up to 10G, 16 ports up to 1G)
C9200L-24PXG-2Y-M
2x 25G/10G/1G SFP28 2 1 30W PoE+
C9200L-48T-4G-M
48 1G ports data
4x 1G SFP 2 1 n/a
C9200L-48P-4G-M
48 1G ports full POE+
C9200L-48PL-4G-M
48 1G ports partial PoE+
C9200L-48T-4X-M
48 1G ports data
C9200L-48P-4X-M
48 1G ports full PoE+
4x10G/1G SFP+ 2 1 30W PoE+
C9200L-48PL-4X-M
C9200L-48PXG-4X-M
48 ports full POE+ (12 mGig ports up to 10G, 36 ports up to 1G)
C9200L-48PXG-2Y-M
48 ports full POE+ (8 mGig ports up to 10G, 40 ports up to 1G)
For supported SFP modules refer the SFP Datasheet.
Cabling Best Practices for Multi-Gigabit operations: While Category-5e cables can support multigigabit data rates upto 2.5/5/10 Gbps, external factors such as noise, alien crosstalk coupled with longer cable/cable bundle lengths can impede reliable link operation. Noise can originate from cable bundling, RFI, cable movement, lightning, power surges and other transient event. It is recommended to use Category-6a cabling for reliable multigigabit operations as it mitigates alien crosstalk by design.
Physical Specifications
Model
Dimensions (h x w x d)
W/ Default Power Supply
Weight
w/ Default Power Supply
Mount Type Hot Swap Fans Operating Temperature  Humidity
C9200L-24T-4G-M
1.73 x 17.5 x 12.9”
(4.4 x 44.5 x 32.9cm)
9.59 lb (4.35 kg) 1U Rack Mount No, 2x -5°C to 45°C 5 to 90%
C9200L-24P-4G-M
1.73 x 17.5 x 12.9”
10.38 lb (4.71 kg) 1U Rack Mount No, 2x -5°C to 45°C 5 to 90%
C9200L-24T-4X-M
1.73 x 17.5 x 12.9”
C9200L-24P-4X-M
1.73 x 17.5 x 12.9”
C9200L-24PXG-4X-M
1.73 x 17.5 x 15.4”
(4.4 x 44.5 x 39.1cm)
12 lb (5.44 kg) 1U Rack Mount No, 2x -5°C to 45°C 5 to 90%
C9200L-24PXG-2Y-M
1.73 x 17.5 x 15.4”
C9200L-48T-4G-M
1.73 x 17.5 x 12.9”
9.97 lb (4.53 kg) 1U Rack Mount No, 2x -5°C to 45°C 5 to 90%
C9200L-48P-4G-M
1.73 x 17.5 x 12.9”
10.58 lb (4.80 kg) 1U Rack Mount No, 2x -5°C to 45°C 5% to 90%
C9200L-48PL-4G-M
1.73 x 17.5 x 12.9”
C9200L-48T-4X-M
1.73 x 17.5 x 12.9”
9.97 lb (4.53 kg) 1U Rack Mount No, 2x -5°C to 45°C 5% to 90%
C9200L-48P-4X-M
1.73 x 17.5 x 12.9”
C9200L-48PL-4X-M
1.73 x 17.5 x 12.9”
C9200L-48PXG-4X-M
1.73 x 17.5 x 15.4”
12.6 lb (5.71 kg) 1U Rack Mount No, 2x -5°C to 45°C 5% to 90%
C9200L-48PXG-2Y-M
1.73 x 17.5 x 15.4”
Performance
Model
Switching Capacity Switching Capacity with Stacking Forwarding rate
Single / Stack
C9200L-24T-4G-M 56 Gbps 136 Gbps 41.67 Mpps / 101 Mpps
C9200L-24P-4G-M 56 Gbps 136 Gbps 41.67 Mpps / 101 Mpps
C9200L-24T-4X-M 128 Gbps 208 Gbps 95.23 Mpps / 155 Mpps
C9200L-24P-4X-M 128 Gbps 208 Gbps 95.23 Mpps / 155 Mpps
C9200L-24PXG-4X-M 272 Gbps 352 Gbps 214.28 Mpps / 262 Mpps
C9200L-24PXG-2Y-M 292 Gbps 372 Gbps 229.16 Mpps / 277 Mpps
C9200L-48T-4G-M 104 Gbps 184 Gbps 77.38 Mpps / 137 Mpps
C9200L-48P-4G-M 104 Gbps 184 Gbps 77.38 Mpps / 137 Mpps
C9200L-48PL-4G-M 104 Gbps 184 Gbps 77.38 Mpps / 137 Mpps
C9200L-48T-4X-M 176 Gbps 256 Gbps 130.95 Mpps / 190 Mpps
C9200L-48P-4X-M 176 Gbps 256 Gbps 130.95 Mpps / 190 Mpps
C9200L-48PL-4X-M 176 Gbps 256 Gbps 130.95 Mpps / 190 Mpps
C9200L-48PXG-4X-M 392 Gbps 472 Gbps 291.66 Mpps / 351 Mpps
C9200L-48PXG-2Y-M 340 Gbps 420 Gbps 252.97 Mpps / 313 Mpps
Power Supply and Specifications
Model
Default Power Supply Hot Swap Power Supply Available PoE W/  Primary PS PoE W/ Secondary PS**
Power Load
(idle/max)
C9200L-24T-4G-M PWR-C5-125WAC Yes, Dual n/a n/a 27.39 / 36.23 W
C9200L-24P-4G-M PWR-C5-600WAC Yes, Dual 370W 740W 39.59 / 466.34 W
C9200L-24T-4X-M PWR-C5-125WAC Yes, Dual n/a n/a 27.82 / 38.6 W
C9200L-24P-4X-M PWR-C5-600WAC Yes, Dual 370W 740W 39.48 / 434.06 W
C9200L-24PXG-4X-M PWR-C5-600WAC Yes, Dual 370W 740W 64.54 / 472.39 W
C9200L-24PXG-2Y-M PWR-C5-600WAC Yes, Dual 370W 740W 65.58 /489.62 W
C9200L-48T-4G-M PWR-C5-125WAC Yes, Dual n/a n/a 33.85 / 47.33 W
C9200L-48P-4G-M PWR-C5-1KWAC Yes, Dual 740W 1440W 45.82 / 933.03 W
C9200L-48PL-4G-M PWR-C5-600WAC Yes, Dual 370W 740W 39.59 / 466.34 W
C9200L-48T-4X-M PWR-C5-125WAC Yes, Dual n/a n/a 36.08 / 53.60 W
C9200L-48P-4X-M PWR-C5-1KWAC Yes, Dual 740W 1440W 50.31 / 872.6 W
C9200L-48PL-4X-M PWR-C5-600WAC Yes, Dual 370W 740W 40.17 / 445.35
C9200L-48PXG-4X-M PWR-C5-1KWAC Yes, Dual 740W 1440W 72.14 / 930.11 W
C9200L-48PXG-2Y-M PWR-C5-1KWAC Yes, Dual 740W 1440W 71.45 / 934.08 W
* Limited by port number and port rating (e.g. 24 PoE+ 30W ports = 720W)
** The PoE values are provided considering the secondary PS to be the default power supply of  the respective model.
C6 variant is not supported in C9200L.  Please refer to Unsupported Power Supplies on Catalyst 9200 and 9200L switches
Package contents
In addition to the MS switch, each shipment includes the following.
  • 1 x default power supply unit for the switch model (please refer to the Power Supply and Specifications section)
  • Rack mount brackets
  • 2 x Pre-installed fans.
  • STACKING NOTE: The C9200L does NOT include stacking ports by default. Please order the C9200L-STAK-KIT-M with every C9200L switch that you plan to deploy in a stack. That kit includes two stacking ports and a 50cm stacking cable.
The following power cables are compatible with the C9200L:
  • CAB-TA-NA= - AC power cord for Cisco Catalyst (North America)
  • CAB-TA-AP= - AC power cord for Cisco Catalyst (Australia)
  • CAB-TA-AR= - AC power cord for Cisco Catalyst (Argentina)
  • CAB-TA-SW= - AC power cord for Cisco Catalyst (Switzerland)
  • CAB-TA-UK= - AC power cord for Cisco Catalyst (United Kingdom)
  • CAB-TA-JP= - AC power cord for Cisco Catalyst (Japan)*
  • CAB-TA-250V-JP= - Japan 250VAC power cord for Cisco Catalyst (Japan)
  • CAB-TA-125V-JP= - Japan 125V AC Type A Power Cable (Japan – 48 port only)
  • CAB-TA-EU= - AC power cord for Cisco Catalyst (Europe)
  • CAB-TA-IT= - AC power cord for Cisco Catalyst (Italy)
  • CAB-TA-IN= - AC power cord for Cisco Catalyst (India)
  • CAB-TA-CN= - AC power cord for Cisco Catalyst (China)
  • CAB-TA-DN= - AC power cord for Cisco Catalyst (Denmark)
  • CAB-TA-IS= - AC power cord for Cisco Catalyst (Israel)
  • CAB-ACBZ-12A= - AC power cord for Cisco Catalyst (Brazil), 12A/125V BR-3-20 plug up to 12A
  • CAB-ACBZ-10A= - AC power cord for Cisco Catalyst (Brazil), 10A/250V BR-3-10 plug up to 10A
  • CAB-C15-CBN - Cabinet jumper power cord, 250VAC 13A, C14 -C15 connectors
* The MA-PWR-CORD-JP is not recommended because its 12A rating does not meet the 14A maximum input requirement of the power supply.
The list above can be found in the Cisco Catalyst 9200 Series Switches Data Sheet
Optional Accessories
Accessory Description
PWR-C5-125WAC-M 125W AC Power Supply
PWR-C5-600WAC-M 600W AC Power Supply
PWR-C5-1KWAC-M 1000W AC Power Supply
C9200L-STAK-KIT-M Stack Kit for 9200L. Includes
two adapters and one 50cm stack cable
STACK-T4-50CM-M 50 cm Stacking Cable Spare
STACK-T4-1M-M 1m Stacking Cable Spare
STACK-T4-3M-M 3M Stacking Cable Spare
SFP Modules
The following SFP/Fiber transceivers are supported. For detailed SFP specifications, refer to the Meraki SFP datasheet.
For information about Cisco Optics compatibility, please click here
Transceiver Model Standard
1 Gbps
MA-SFP-1GB-SX
MA-SFP-1GB-LX10
1000BASE-SX over OM1/2/3/4 up to distances of 1KM
1000BASE-LX10 over OS1/0S2 up to distances of 10KM
10 Gbps
MA-SFP-10GB-SR
MA-SFP-10GB-LR
MA-SFP-10GB-ER
MA-SFP-10GB-ZR
10GBASE-SR over OM1/2/3/4 up to distances of 400 M
10GBASE-LR over OS1/2 up to distances of 10 KM
10GBASE-ER over OS1/2 up to distances of 40 KM
10GBASE-ZR over OS1/2 up to distances of 80 KM
Direct Attach
MA-CBL-TA-1M
MA-CBL-TA-3M
10GSFP+Cu Passive Twinax
Regulations and Compliance
Electromagnetic Compatibility
Certifications
FCC Part 15 (CFR 47) Class A ICES-003 Class A EN 55032 Class A CISPR 32 Class A AS/NZS 3548 Class A BSMI Class A VCCI Class A CISPR 35 EN 55035, EN300 386* , EN 61000-3-2, EN 61000-3-3
Safety  UL 60950-1/62368-1, CAN/CSA-C22.2 No. 60950-1/62368-1, EN 60950-1/62368-1, IEC 60950-1/62368-1, CCC, CE Marking
Environmental Reduction of Hazardous Substances (ROHS) 5
Warranty Full lifetime hardware warranty with next-day advanced replacement included
MTBF Rating
Model
MTBF
C9200L-24T-4G-M 531,030
C9200L-24P-4G-M 392,210
C9200L-24T-4X-M 525,990
C9200L-24P-4X-M 390,310
C9200L-24PXG-4X-M 379,410
C9200L-24PXG-2Y-M 374,730
C9200L-48T-4G-M 508,700
C9200L-48P-4G-M 347,760
C9200L-48PL-4G-M 347,760
C9200L-48T-4X-M 503,400
C9200L-48P-4X-M 346,270
C9200L-48PL-4X-M 346,270
C9200L-48PXG-4X-M 379410
C9200L-48PXG-2Y-M 337,360
Installation Guide
For instructions on how to install and configure the C9200L series switch refer the C9200L Series Installation Guide
  • Was this article helpful?
