Catalyst 9300L-M Datasheet
Overview
The Catalyst 9300L-M integrates Meraki dashboard management with high-performance switching hardware for enterprise applications. To satisfy high-bandwidth applications and the deployment of high-speed wifi access points, the Catalyst 9300L-M provides multigigabit ports, 320GB stacking with four fixed 10G uplinks. The Catalyst 9300L-M provides resiliency through fast stack convergence. The Catalyst 9300L-M provides Adaptive Policy using an over-the-wire tag which segments traffic into security groups to deliver scalable security. The Catalyst 9300L-M integrates with the Meraki dashboard for streamlined management of wired access applications.
Adaptive Policy provides simple & scalable security policies to segment traffic using Security Groups. Adaptive Policy segments traffic using Security Groups for security policy management. Security Groups are created in the dashboard using descriptive terms like 'IoT device' and 'Guest.' Security policy intent (e.g., Permit or Deny) is provisioned between Security Groups, segmenting each group’s traffic. This method of security policy management offers an alternative to legacy IP-address based Access Control Lists, allowing operators to manage network traffic security independent of future network changes.
C9300L-24T-4X-M
C9300L-48T-4X-M
Front of the C9300L-M switch, 48 ports with 4 SFP modules.
A Catalyst 9300L switch can also be migrated to a Meraki-managed persona, where it would function as its Catalyst Meraki 9300L-M equivalent. For details on the migration process, please refer to our Getting started: Cisco Catalyst 9300 with Meraki Dashboard guide.
Models
Number of Ports Model Description
24 Ports
C9300L-24T-4X-M 24-port 1 GbE Data with 4x 10G/1G fixed uplinks
C9300L-24P-4X-M 24-port 1GbE PoE+ with 4x 10G/1G fixed uplinks
C9300L-24UXG-4X-M
24-port UPOE, 8 mGig(10G/5G/2.5G/1G/100M) + 16 GbE(1G/100M/10M) with 4x 10G/1G fixed uplinks
48 Ports
C9300L-48T-4X-M 48-port 1 GbE Data with 4x 10G/1G fixed uplinks
C9300L-48P-4X-M 48-port 1GbE PoE+ with 4x 10G/1G fixed uplinks, 715WAC
C9300L-48PF-4X-M 48-port 1GbE PoE+ with 4x 10G/1G fixed uplinks, 1100WAC
C9300L-48UXG-4X-M
48-port UPOE, 12 MGig(10G/5G/2.5G/1G/100M) + 36 GbE(1G/100M/10M) with 4x 10G/1G fixed uplinks
Features
Category Features
Highlights
  • Layer 3 Capabilities
  • Four SFP+(10G/1G) fixed uplinks on all models
  • mGig support on UPOE models
  • 320G Dual Dedicated Hardware Stacking Ports
  • UPOE (60W per port) & IEEE 802.3bt type3
  • Redundant hot-swappable power supplies and replaceable fans
Management
  • Managed via Cisco Meraki Dashboard
  • Zero-touch remote provisioning (no staging needed)
  • Basic configuration capability via local management page
  • Detailed historical per-port and per-client usage statistics
  • Operating System, device, and hostname fingerprinting
  • Automatic firmware upgrades with scheduling control
  • SNMP and Syslog support for integration with other network management solutions
Remote Diagnostics
  • Email, SMS and Mobile push notification alerts
  • Ping, traceroute, cable testing, and link failure detection with alerting
  • Remote packet capture
  • Dynamic and interactive network discovery and topology
  • Combined event and configuration change logs with instant search
Stacking
  • Optional stacking kit allowing 8 switches in a stack with 320Gbps of switching capacity with stacking
  • Virtual stacking supports thousands of switch ports in a single logical stack for unified management, monitoring, and configuration
  • Faster convergence
Ethernet Switching Capabilities
  • 802.1p Quality of Service, 8 queues (w/ 6 configurable for DSCP-to-CoS mapping)
  • 802.1Q VLAN and trunking support for up to 4,094 VLANs (1000 active VLANs with STP enabled)
  • Single Instance of 802.1s Multiple Spanning Tree Protocol (interoperable with RSTP, STP, PVST, RPVST)
  • STP Enhancements: BPDU guard, Root guard, Loop guard, UDLD
  • Broadcast storm control
  • 802.1ab Link Layer Discovery Protocol (LLDP) and Cisco Discovery Protocol (CDP)
  • 802.3ad Link aggregation with up to 8 ports per aggregate; multi-chassis aggregates supported on stacked switches
  • Port mirroring
  • IGMP snooping for multicast filtering
  • MAC Forwarding Entries: 32K
Layer 3
  • Static routing, OSPFv2
  • Multicast routing (ASM: PIM-SM)
  • Warm Spare (VRRP) *
  • DHCP Server, DHCP Relay
Security
  • Integrated multi-factor authentication for Dashboard management
  • Role-based access control (RBAC) with granular device and configuration control
  • Corporate wide password policy enforcement
  • IEEE 802.1X RADIUS and MAB, hybrid authentication and RADIUS server testing
  • Single-Host/Multi-Domain/Multi-Host/Multi Authentication
  • Port security: Sticky MAC, MAC Allow listing *
  • DHCP snooping, detection and blocking, Dynamic ARP Inspection
  • IPv4 and IPv6 ACLs
  • Secure Connect *
  • Adaptive Policy
* Available in a future software release
Catalyst 9300/L/X-M Licensing
The Catalyst 9300-M license applies to all C9300 hardware platforms (C9300 / C9300L / C9300X) excluding the MS390. Catalyst 9300-M license structure includes two feature tiers:  Enterprise and Advanced. Catalyst 9300-M license are available in 1, 3, 5, 7, and 10 year terms.
Catalyst 9300X-M License Structure 12/24-Port 48-port
Advanced Features LIC-C9300-24A LIC-C9300-48A
Enterprise Features LIC-C9300-24E LIC-C9300-48E
The features available with advanced licensing are:
In the Co-term licensing model (most existing Organizations), an Organization must either have all Catalyst 9300/L/X-M Enterprise or all Catalyst 9300/L/X-M Advanced licenses - they cannot be mixed. In the Per-device licensing model, a mix of Enterprise and Advanced can be added to a single Organization, but certain features may require all devices in a Network to have Advanced licenses, e.g. Adaptive Policy.
Note: MS390s existing in the same co-term Organization will require the same license edition (either Enterprise or Advanced) as the Catalyst 9300/L/X-M. License types cannot be mixed and will result in an incompatible license error.
For more information on licensing, refer to Meraki Licensing Models article.
Subscription licensing is also available for the Catalyst 9300-M switches
Technical Breakdown
Interfaces Specifications
Model/Persona Interfaces
Fixed Uplinks
(SFP+)
320G Hardware Stack Ports
Dedicated Management
Interface
PoE/ UPoE
Capabilities
C9300L-24T-4X-M 24 x 1GbE Data 4x 10G/1G SFP+ 2 1 n/a
C9300L-24P-4X-M 24 x 24-port 1GbE PoE+ 4x 10G/1G SFP+ 2 1 30W PoE+
C9300L-24UXG-4X-M 24-port UPOE, 8 mGig(10G/5G/2.5G/1G/100M) + 16 GbE(1G/100M/10M) 4x 10G/1G SFP+ 2 1 60W UPOE
C9300L-48T-4X-M 48-port 1 GbE Data with 4x 10G/1G fixed uplinks 4x 10G/1G SFP+ 2 1 n/a
C9300L-48P-4X-M 48-port 1GbE PoE+ with 4x 10G/1G fixed uplinks 4x 10G/1G SFP+ 2 1 30W PoE+
C9300L-48PF-4X-M 48-port 1GbE PoE+ with 4x 10G/1G fixed uplinks 4x 10G/1G SFP+ 2 1 30W PoE+
C9300L-48UXG-4X-M 48-port UPOE, 12 MGig(10G/5G/2.5G/1G/100M) + 36 GbE(1G/100M/10M) 4x 10G/1G SFP+ 2 1 60W UPOE
For supported SFP modules please refer the SFP Datasheet.
Cabling Best Practices for Multi-Gigabit operations: While Category-5e cables can support multigigabit data rates up to 2.5/5 Gbps. External factors such as noise and alien crosstalk, coupled with longer cable/cable bundle lengths, can impede reliable link operation. Noise can originate from cable bundling, Radio Frequency Interference(RFI), cable movement, lightning, power surges and other transient event. It is recommended to use Category-6a cabling for reliable multigigabit(mGig) operations, as it mitigates alien crosstalk by design.
Physical Specifications
Model
Dimensions (h x w x d)
W/ Default Power Supply
Weight
w/ Default Power Supply
Mount Type Hot Swap Fans Operating Temperature  Humidity
C9300L-24T-4X-M
1.73” x 17.5” x 17.7”
(4.4 x 44.5 x 44.9cm)
14.93 lb (6.78 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
C9300L-24P-4X-M
16.2 lb (7.35 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
C9300L-24UXG-4X-M
1.73” x 17.5” x 19.2”
(4.4 x 44.5 x 48.8cm)
15.73 lb (7.13 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
C9300L-48T-4X-M
15.41 lb (7.0 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
C9300L-48P-4X-M
15.46 lb (7.03 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
C9300L-48PF-4X-M
15.48 lb (7.03 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
C9300L-48UXG-4X-M
16.86 lb (7.65 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
Performance
Model
Switching Capacity Switching Capacity with Stacking Forwarding rate
Single / Stack
C9300L-24T-4X-M 128 Gbps 448 Gbps 95.23 / 333.33 Mpps
C9300L-24P-4X-M 128 Gbps 448 Gbps 95.23 / 333.33 Mpps
C9300L-24UXG-4X-M 272 Gbps 592 Gbps 202.38 / 440.47 Mpps
C9300L-48T-4X-M 176 Gbps 496 Gbps 130.95 / 369.05 Mpps
C9300L-48P-4X-M 176 Gbps 496 Gbps 130.95 / 369.05 Mpps
C9300L-48PF-4X-M 176 Gbps 496 Gbps 130.95 / 369.05 Mpps
C9300L-48UXG-4X-M 392 Gbps 712 Gbps 291.66 / 529.76 Mpps
Power Supply and Specifications
Model
Default Power Supply Hot Swap Power Supply Available PoE W/  Primary PS PoE W/ Secondary PS** PoE W/ 1100W Secondary PS
Power Load
(idle/max)
C9300L-24T-4X-M PWR-C1-350WAC-P-M Yes, Dual n/a n/a n/a 56.85 / 73.54 W
C9300L-24P-4X-M PWR-C1-715WAC-P-M Yes, Dual 505W 720W* 720W* 139.6 / 243.7 W
C9300L-24UXG-4X-M PWR-C1-1100WAC-P-M Yes, Dual 880W 1440W* 1440W* 68.98 / 1049.47 W
C9300L-48T-4X-M PWR-C1-350WAC-P-M  Yes, Dual n/a n/a n/a 60.97 / 86.77 W
C9300L-48P-4X-M PWR-C1-715WAC-P-M Yes, Dual 505W 1220W 1440W* 67.40 / 598.6 W
C9300L-48PF-4X-M PWR-C1-1100WAC-P-M Yes, Dual 890W 1440W* 1440W* 67.38 / 1023.56 W
C9300L-48UXG-4X-M PWR-C1-1100WAC-P-M Yes, Dual 675W 1775W 1775W 104.56 / 875.3 W
* Limited by port number and port rating (e.g. 24 PoE+ 30W ports = 720W)
** The PoE values are provided considering the secondary PS to be the default power supply of  the respective model.
Note: For Japan, the recommendation is to deploy the switch with 200V+ outlets. The 1100WAC power supplies will not operate on 100V and requires input power range 115V to 240 VAC, 50 to 60 Hz. Please reference Table 13. AC Power Cords for the appropriate 250VAC power cable.
Package contents
In addition to the Catalyst 9300L-M switch, each shipment includes the following.
  • 1 x default power supply unit for the switch model (please refer to the power supply and specifications section)
  • Rack mount brackets (rack screws not included)
  • 3 x Pre-installed fans.
  • STACKING NOTE: The C9300L does not include stacking ports by default. Order the C9300L-STAK-KIT2-M with each C9300L switch intended for a stack. This kit includes two stacking ports and a 50cm stacking cable.
Optional Accessories
Please refer to power supply models table here for details.
Accessory Description  Supported Models
PWR-C1-350WAC-P-M 350W AC Power Supply C9300, C9300L, C9300X
PWR-C1-715WAC-P-M 715W AC Power Supply C9300, C9300L, C9300X
PWR-C1-1100WAC-P-M 1100W AC Power Supply C9300, C9300L, C9300X
C9300L-STAK-KIT2-M Stack Kit for 9300L. Includes
two adapters and one 50cm stack cable
C9300L Models Only
STACK-T3A-50CM-M 50 cm Stacking Cable Spare C9300L Models Only
STACK-T3A-1M-M 1m Stacking Cable Spare C9300L Models Only
STACK-T3A-3M-M 3M Stacking Cable Spare C9300L Models Only
FAN-T2-M System Fan C9300, C9300L, C9300X
4PT-KIT-T2-M Catalyst 9300-M Rack Mount Kit C9300, C9300L, C9300X
SFP Modules
The following SFP/Fiber transceivers are supported. For detailed SFP specifications, refer to the Meraki SFP datasheet. C9300L and C9300 share the same transceiver support.
For information about Cisco Optics compatibility, please click here
Transceiver Model Standard Supported C9300-M platform
1 Gbps
MA-SFP-1GB-SX
MA-SFP-1GB-LX10
1000BASE-SX over OM1/2/3/4 up to distances of 1KM
1000BASE-LX10 over OS1/0S2 up to distances of 10KM
10 Gbps
MA-SFP-10GB-SR
MA-SFP-10GB-LR
MA-SFP-10GB-ER
MA-SFP-10GB-ZR
10GBASE-SR over OM1/2/3/4 up to distances of 400 M
10GBASE-LR over OS1/2 up to distances of 10 KM
10GBASE-ER over OS1/2 up to distances of 40 KM
10GBASE-ZR over OS1/2 up to distances of 80 KM
MA-SFP-10GB-LRM
10GBASE-LRM over OM1/2/3, OS1/2 up to distances of 300 M
C9300, C9300L
40 Gbps
MA-QSFP-40G-CSR4
MA-QSFP-40G-SR-BD
QSFP-MPO12 over OM2/3/4 up to distances of 400 M
QSFP Duplex LC over OM2/3/4 up to distances of 150 M
100 Gbps
MA-QSFP-100G-LR4
MA-QSFP-100G-SR4
100GBASE-LR4 over OS1/2 up to distances of 10 KM
100GBASE-SR4 over OM3/4/5 up to distances of 100 M
Direct Attach
MA-CBL-TA-1M
MA-CBL-TA-3M
10GSFP+Cu Passive Twinax
NOTE: Catalyst 9300X switches do not support LRM modules.
Regulations and Compliance
Electromagnetic Compatibility
Certifications
FCC Part 15 (CFR 47) Class A, ICES-003 Class A, CISPR22 Class A, CNS13438, EN 300 386 V1.6.1,  EN 55022 Class A, EN 61000-3-2, EN61000-3-3, KN 32, TCVN 7189 Class A, EN 55032, CISPR 32 Class A, V-2/2015.04, V-3/2015.04, VCCI-CISPR 32 Class A, CISPR24, EN 300 386 V1.6.1, EN 55024, KN35, TCVN 7317
Safety
CAN/CSA-C22.2 No. 60950-1, UL 60950-1, EN 60950-1, IEC 60950-1, AS/NZS 60950.1
Environmental Reduction of Hazardous Substances (RoHS)
Warranty Full lifetime hardware warranty with next-day advanced replacement included
MTBF Rating
Model
MTBF at 25°C
C9300L-24T-4X-M
387,700
C9300L-24P-4X-M
340,710
C9300L-24UXG-4X-M
332,640
C9300L-48T-4X-M
380,080
C9300L-48P-4X-M
309,020
C9300L-48PF-4X-M
298,880
C9300L-48UXG-4X-M 273,820
Installation Guide
For instructions on how to install and configure the C9300X series switch please refer the C9300/L/X Series Installation Guide
