MS390 Datasheet
Overview
The Meraki MS390 addresses the most demanding enterprise applications by combining the simplicity of the Meraki dashboard with powerful switching hardware. To satisfy high-bandwidth applications and the deployment of high-speed 802.11ax/wifi-6 access points, the MS390 provides multigigabit ports, 480G stacking, and modular 10/40G uplinks. The MS390 delivers resiliency with fast stack convergence and StackPower. The MS390 provides Adaptive Policy using an over-the-wire tag which segments traffic into security groups to deliver scalable security. The MS390 is integrated under the Meraki dashboard to provide a simply powerful solution to the most demanding wired access applications.
Adaptive Policy provides simple & scalable security policies to segment traffic using Security Groups. Security Groups are created in the dashboard using natural language such as “IOT device” & “Guest.” The security policy intent (e.g., Permit or Deny) is then simply provisioned between Security Groups which results in the segmentation of each group’s traffic. By making security policy management intuitive and scalable relative to legacy IP-address based Access Control Lists, Adaptive Policy empowers operators to confidently secure their network traffic independent of future network changes.
By pooling & distributing power across MS390s using a series of StackPower cables, StackPower provides simple and resilient power distribution across the stack.
Image of a MS390 front Panel
Models
Number of Ports Model Description
24 Ports
MS390-24-HW 24-port GbE switch
MS390-24P-HW 24-port GbE PoE+ switch
MS390-24U-HW 24-port GbE UPoE/802.3bt switch
MS390-24UX-HW 24-port mGbE UPoE/802.3bt switch
48 Ports
MS390-48-HW 48-port GbE switch
MS390-48P-HW 48-port GbE PoE+ switch
MS390-48U-HW 48-port GbE UPoE/802.3bt switch
MS390-48UX-HW 36-port 2.5GbE + 12-port mGbE UPoE/802.3bt switch
MS390-48UX2-HW 48-port 5GbE UPoE/802.3bt switch
Features
MS390 Licensing
MS390 license structure includes two feature tiers:  Enterprise and Advanced. The MS390 also introduces a new and simpler license to hardware mapping, specifically 24-port or 48-port licenses. As with all MS, every MS390 license is available in 1, 3, 5, 7, and 10 year terms.
Meraki Support is unable to upgrade licensing from Enterprise to Advanced for the MS390 model. This upgrade must be purchased as a new license.
MS390 License Structure 24-Port Model 48-port Model
Advanced Features LIC-MS390-24A LIC-MS390-48A
Enterprise Features LIC-MS390-24E LIC-MS390-48E
The features available with advanced licensing are:
In the Co-term licensing model (most existing Organizations), an Organization must either have all MS390 Enterprise or all MS390 Advanced licenses - they cannot be mixed. In the Per-device licensing model, a mix of Enterprise and Advanced can be added to a single Organization, but certain features may require all devices in a Network to have Advanced licenses, e.g. Adaptive Policy.
Note: Catalyst 9300-M series existing in the same co-term Organization will require the same license edition (either Enterprise or Advanced) as the MS390. License types cannot be mixed and will result in an incompatible license error.
MS130, MS150, MS390, C9300 require the same license tier (either Enterprise of Advanced) across the entire Organization.
For more information on licensing, refer to Meraki Licensing Models article.
Subscription licensing is also available for the MS390 switches.
Technical Breakdown
Interfaces Specifications
Model Interfaces
Uplink 10/40GbE
(SFP+, QSFP+)
120G Hardware Stack Port
Dedicated Management
Interface
PoE/ UPoE
Capabilities
MS390-24-HW 24 x 1GbE RJ45 Modular 2 1 n/a
MS390-24P-HW 24 x 1GbE RJ45 Modular 2 1 PoE
MS390-24U-HW 24 x 1GbE RJ45 Modular 2 1 UPoE/802.3bt
MS390-24UX-HW 24 x 100M/1G/2.5G/5G/10G RJ45 Modular 2 1 UPoE/802.3bt
MS390-48-HW 48 x 1GbE RJ45 Modular 2 1 n/a
MS390-48P-HW 48 x 1GbE RJ45 Modular 2 1 PoE
MS390-48U-HW 48 x 1GbE RJ45 Modular 2 1 UPoE/802.3bt
MS390-48UX-HW
36 x 100M/1G/2.5G +
12 x 100M/1G/2.5G/5G/10G
MS390-48UX2-HW 48 x 100M/1G/2.5G/5G Modular 2 1 UPoE/802.3bt
All models are available with modular uplinks that have been listed under the Accessories list. For supported SFP modules please refer the SFP Datasheet.
Cabling Best Practices for Multi-Gigabit operations: While Category-5e cables can support multigigabit data rates upto 2.5/5 Gbps, external factors such as noise, alien crosstalk coupled with longer cable/cable bundle lengths can impede reliable link operation. Noise can originate from cable bundling, RFI, cable movement, lightning, power surges and other transient event. It is recommended to use Category-6a cabling for reliable multigigabit operations as it mitigates alien crosstalk by design.
Physical Specifications
Model
Dimensions (h x w x d)
W/ Default Power Supply
Weight Mount Type Hot Swap Fans Operating Temperature  Humidity
MS390-24-HW
1.73” x 17.5” x17.7”
(4.4 x 44.5 x 44.9cm)
16.03 lb (7.27 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
MS390-24P-HW
16.33 lb (7.4 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
MS390-24U-HW
1.73” x 17.5” x 19.2”
(4.4 x 44.5 x 44.8cm)
16.63 lb (7.54 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
MS390-24UX-HW
1.73” x 17.5” x 20.2”
(4.4 x 44.5 x 51.3cm)
18.18 lb (8.25 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
MS390-48-HW
16.43 lb (7.45 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
MS390-48P-HW
16.73 lb (7.59 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
MS390-48U-HW
(4.4 x 44.5 x 48.8cm)
17.03 lb (7.72 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
MS390-48UX-HW
1.73” x 17.5” x 22.2”
(4.4 x 44.5 x 56.4cm)
20.50 lb (9.34 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
MS390-48UX2-HW
20.05 lb (9.09 kg) 1U Rack Mount Yes, 3x -5°C to 45°C 5 to 90%
Performance
Model
Switching Capacity Stacking Bandwidth Forwarding rate
MS390-24-HW 208 Gbps 480 Gbps 154.76 Mpps
MS390-24P-HW 208 Gbps 480 Gbps 154.76 Mpps
MS390-24U-HW 208 Gbps 480 Gbps 154.76 Mpps
MS390-24UX-HW 640 Gbps 480 Gbps 476.19 Mpps
MS390-48-HW 256 Gbps 480 Gbps 190.48 Mpps
MS390-48P-HW 256 Gbps 480 Gbps 190.48 Mpps
MS390-48U-HW 256 Gbps 480 Gbps 190.48 Mpps
MS390-48UX-HW 580 Gbps 480 Gbps 431.54 Mpps
MS390-48UX2-HW 640 Gbps 480 Gbps 476.19 Mpps
Power Options and Specifications
Model
Default Power Supply Hot Swap Power Supply Available PoE W/ Primary PS Max Available PoE W/ Secondary PS***
Power Load
(idle/max)
MS390-24-HW MA-PWR-350WAC** Yes, Dual n/a n/a 79.2 / 99 W
MS390-24P-HW MA-PWR-715WAC** Yes, Dual 445W 720W 84.1 / 554.4 W
MS390-24U-HW MA-PWR-1100WAC Yes, Dual 830W 1440W 85.4 / 990.3 W
MS390-24UX-HW MA-PWR-1100WAC Yes, Dual 560W 1440W 162.7 / 809.9 W
MS390-48-HW MA-PWR-350WAC** Yes, Dual n/a n/a 83.9 / 109.9 W
MS390-48P-HW MA-PWR-715WAC** Yes, Dual 437W 1152W 92.6 / 555 W
MS390-48U-HW MA-PWR-1100WAC Yes, Dual 822W 1800W 145 / 844.9 W
MS390-48UX-HW MA-PWR-1100WAC Yes, Dual 490W 1590W 218.5 / 785.5 W
MS390-48UX2-HW MA-PWR-1100WAC Yes, Dual 645W 1745W 157.9 / 843.8 W
** Upgrade options to 715W and 1100W PSU are available.
*** The PoE values are provided considering the secondary PS to be the default power supply of  the respective model.
Note: For Japan, the recommendation is to deploy the switch with 200V+ outlets. The 1100WAC power supply will not operate on 100V. Please reference Table 13. AC Power Cords for the appropriate 250VAC power cable.
PSU configuration and PoE budgets
Model
Primary PSU
PoE
With 350W Secondary PSU
With 715W Secondary PSU
With 1100W Secondary PSU
MS390-24P
MA-PWR-715WAC 445W 720W 2 720W 2 720W 2
MA-PWR-1100WAC 1 720W 2 720W 2 720W 2 720W 2
MS390-24U MA-PWR-1100WAC 830W 1180W 2 1440W 2 1440W 2
MS390-24UX MA-PWR-1100WAC 560W 910W 1275W 1440W 2
MS390-48P
MA-PWR-715WAC 437W 787W 1152W 1440W 2
MA-PWR-1100WAC 1 822W 1172W 1440W 2 1440W 2
MS390-48U MA-PWR-1100WAC 822W 1172W 1537W 1800W 3
MS390-48UX MA-PWR-1100WAC 490W 840W 1205W 1590W
MS390-48UX2 MA-PWR-1100WAC 645W 995W 1360W 1745W
 1 Using upgraded power supply option.
 2 Limited by port density and per-port PoE capacity.
 3  Limited by design.
What's included
Model Package Contents
MS390-24-HW 1 x Power Supply (MA-PWR-350WAC), Rack mount brackets and screw kit, 3 x Pre-Installed Fans, Cable guide
MS390-24P-HW 1 x Power Supply (MA-PWR-715WAC), Rack mount brackets and screw kit, 3 x Pre-Installed Fans, Cable guide
MS390-24U-HW 1 x Power Supply (MA-PWR-1100WAC), Rack mount brackets and screw kit, 3 x Pre-Installed Fans, Cable guide
MS390-24UX-HW 1 x Power Supply (MA-PWR-1100WAC), Rack mount brackets and screw kit, 3 x Pre-Installed Fans, Cable guide
MS390-48-HW 1 x Power Supply (MA-PWR-350WAC), Rack mount brackets and screw kit, 3 x Pre-Installed Fans, Cable guide
MS390-48P-HW 1 x Power Supply (MA-PWR-715WAC), Rack mount brackets and screw kit, 3 x Pre-Installed Fans, Cable guide
MS390-48U-HW 1 x Power Supply (MA-PWR-1100WAC), Rack mount brackets and screw kit, 3 x Pre-Installed Fans, Cable guide
MS390-48UX-HW 1 x Power Supply (MA-PWR-1100WAC), Rack mount brackets and screw kit, 3 x Pre-Installed Fans, Cable guide
MS390-48UX2-HW 1 x Power Supply (MA-PWR-1100WAC), Rack mount brackets and screw kit, 3 x Pre-Installed Fans, Cable guide
Optional Accessories
Accessory Description  Supported Models
MA-PWR-350WAC 350W AC Power Supply MS390-24-HW, MS390-48-HW
MA-PWR-715WAC 715W AC Power Supply All Models
MA-PWR-1100WAC 1100W AC Power Supply All Models
MA-MOD-2X40G 2 x 40G Uplink Module All Models
MA-MOD-4X10G * 4 x 10G Uplink Module All Models
MA-MOD-8X10G 8 x 10G Uplink Module All Models
MA-CBL-120G-50CM Meraki 120G Stacking Cable, 0.5 Meter All Models
MA-CBL-120G-1M Meraki 120G Stacking Cable, 1 Meter All Models
MA-CBL-120G-3M Meraki 120G Stacking Cable, 3 Meter All Models
MA-CBL-SPWR-30CM Meraki MS390 30CM StackPower Cable All Models
MA-CBL-SPWR-150CM Meraki MS390 150CM StackPower Cable All Models
MA-FAN-16K2 System Fan All Models
MA-RCKMNT Meraki MS390 Rack Mount Kit All Models
* MA-MOD-4X10G reached end-of-sale on November 1, 2021. Please refer to its end-of-sale announcement for further details.
Regulations and Compliance
Electromagnetic Compatibility
Certifications
FCC Part 15 (CFR 47) Class A, ICES-003 Class A, CISPR22 Class A, CNS13438, EN 300 386 V1.6.1,  EN 55022 Class A, EN 61000-3-2, EN61000-3-3, KN 32, TCVN 7189 Class A, EN 55032 , CISPR 32 Class A, V-2/2015.04, V-3/2015.04, VCCI-CISPR 32 Class A, CISPR24, EN 300 386 V1.6.1, EN 55024, KN35, TCVN 7317
Safety
CAN/CSA-C22.2 No. 60950-1, UL 60950-1, EN 60950-1, IEC 60950-1, AS/NZS 60950.1
Environmental Reduction of Hazardous Substances (RoHS)
Warranty Full lifetime hardware warranty with next-day advanced replacement included
MTBF Rating
Model
MTBF at 25°C
MS390-24-HW
314,790
MS390-24P-HW
299,000
MS390-24U-HW
238,410
MS390-24UX-HW
214,760
MS390-48-HW
305,870
MS390-48P-HW
277,770
MS390-48U-HW
227,410
MS390-48UX-HW
202,160
MS390-48UX2-HW
198,647
Installation Guide
For instructions on how to install and configure the MS390 series switch please refer the MS390 Series Installation Guide
  • Was this article helpful?
