Switch Overview and Statistics
The Meraki Dashboard provides information and data which can be found by navigating to the switch overview page (Monitor > Switches) and selecting the desired switch.
Learn more with this free online training course on the Networking Learning Hub:
Switch Overview
This page is a jump page which contains all of your switches that were added to the specific network you are viewing. From here, you can search for or otherwise select an particular switch. You can also see the connection state of each switch, both live and over the past 24 hours by viewing the connectivity bar.
Jump Page for all switches in the dashboard network
This page also allows for you to modify, add or remove switches. For example you can select one or more switches. Then, from the action buttons at the top you can choose to add "Tags", clone, or move the selected switch(es) to another network.
Switch Details View
Once you have selected a particular switch from the overview page (monitor >> switches), you will be presented with information and statistics of that particular switch.
Configuration
This section allows for you to name the switch as well as add notes, an address and optional tags. To modify these settings, click on the switch you want to change the settings for, and click on the pencil(s).
Individual switch - configuration UI
You can also choose to remove the switch from this menu.
Status
This section displays the switch status details. It includes the following details about your switch:
LAN IP
This field displays the current IP address assigned to the switch and how it was allocated (DHCP or STATIC IP). You will also find an option to Set IP Address. Selecting this will allow for you to change the IP assignment and specify an IP address and Management VLAN. This option is only available if the switch is online and checking into dashboard. For static IP assignment without a currently connected state, see Local Configuration.
Gateway
This field displays the currently configured default gateway address of the switch.
Public IP
This field displays the detected public IP address and may also display the reverse DNS lookup information of the public address.
Serial
The field shows the serial number of the switch.
RSTP root
This field displays the currently elected RSTP Root switch, the winning priority and via what port the root path is available. If it is an MS Series switch in the same network or organization, this field will also provide you with a direct link to the switch. Note: This information will only be displayed if you have RSTP enabled on your switch network.
Firmware
This field shows whether the switch's firmware is up to date.
Config
This field shows whether the switch's configuration is up to date and when the last fetch occurred.
VLAN Profile
This field shows the VLAN Profiles assigned to the switch.
Device uptime
This field shows the switch's uptime, the last boot reason, and a link to the event log for additional details.
