Verifying Voice and Data VLAN tags with LLDP phones
When a VoIP phone is attached to an MS switch, it may be seen operating on the regular VLAN and not the port's configured Voice VLAN. When this happens, verify that the phone is running LLDP (with LLDP-MED support for PoE) or CDP to communicate with the switch. If the phone is running a different layer 2 discovery protocol, then the port will need to be configured manually to use the desired voice VLAN as its default VLAN. If using the appropriate protocol, the switch will tell the VoIP device what VLANs to use for voice and data traffic. If the phone is running LLDP or CDP and is not being recognized, the switch may need to be updated. Please refer to our documentation to ensure your switch's firmware is up to date.
Packet capture is a powerful tool that can help narrow down issues with phones picking up an IP address on the wrong VLAN.
In the example below, we have a Cisco Meraki switch connected to a router that has two VLANs, Data on VLAN 20 and Voice on VLAN 40.
Each of the phones is connected to an access port configured for data VLAN 20 and voice 40 as shown below
However, the phones are picking up an IP address on the data VLAN "20" which could indicate that either the phone isn't snooping for LLDP/CDP, or the switch port isn't configured properly.
The capture below was taken from a port where a phone that supports LLDP is connected to, using the Wireshark display filter "LLDP" we can clearly see the Cisco Meraki switch sending multicast LLDP specifying the correct voice VLAN-ID.
The LLDP-MED Network Policy with VLAN-ID in it is sent (visible as TIA - Network Policy in Wireshark within the LLDP-packet)
The same is true about CDP. The Cisco Meraki switch will send a CDP packet with the Data and Voice VLAN info
The screenshot below shows a packet capture taken from a switch that has a phone connect on port 6, and is configure for data VLAN 100 and Voice VLAN 200.
The screenshot shows the switch sending VLAN 200 tag for voice in the CDP packet
When a device land into Voice VLAN, the dashboard adds a "Phone" tag next to the CDP/LLDP discovery item. To view, navigate to the Network-wide > Monitor > Clients page and add the CDP/LLDP column as shown below:
