MT12 Datasheet - Water Detection
MT12 Sensors
Cloud-Managed Sensors that help you have complete visibility across your business environment
Overview
Businesses need a complete view of data to make sound decisions. Businesses need to have visibility into their network availability metrics, capex & opex, and customer satisfaction levels to deliver on their mission. While businesses have a good grip on embracing and utilizing data in the business world, they are yet to fully visualize the physical world.
Current solutions are complicated to install, do not scale and are difficult to use. Hence businesses do not have a simple and reliable way to have visibility into their critical assets to maximize their network uptimes, reduce equipment failure, reduce unnecessary site visits, and deliver best-in-class customer service.
So, Meraki is introducing a range of sensors to prevent loss and increase operational efficiency with ease. Our sensors are simple, scalable and secure. Our sensors also connect to the dashboard using the MV/MR which removes the need for expensive gateways. Customers can now gain real-time visibility into their critical business environment form a single pane of glass.
CLOUD MANAGED SENSORS | INDUSTRY LEADING CLOUD MANAGEMENT |
The Cisco Meraki MT12 sensors provide water presence monitoring for network closets across industries using BLE (Bluetooth Low Energy) beacons on the MR and MV. The sensor can detect the presence of at least 3 mL of water Our sensors are built from the ground up to be easy to manage without compromising on power and flexibility All Meraki sensors are managed through an elegant, intuitive cloud-based interface Meraki’s centralized management gives administrators granular visibility into their network |
Cloud management has a number of benefits that make it easier to build networks large and small: Automatic alerts based on customizable thresholds through SMS, Email and Mobile push notifications Enterprise-grade security which the Cisco Trustworthy Systems seal of approval Role-based administration Firmware upgrades and enhancements from the Meraki cloud Zero-touch provisioning for rapid deployment across sites |
Product Highlights
Technical Specifications
Sensors
Water Leak | Detect the presence of at least 3 mL of water making contact with the cable or cradle |
Wireless Capabilities
Bluetooth 4.2 Low Energy BLE | Compatible MV smart cameras and MR access points |
Operating Frequency | 2.400–2.4835 GHz |
IEEE Standard | 802.15.1 (BLE 4.2) |
Data Logging
Data polling frequency |
Event Driven Wake up every 20 minutes to report |
Onboard data storage | 4000 data points |
Security | Secure BLE messaging using LTK(Long-Term Key) |
Physical Characteristics
Dimensions | 117.1(L)X65.9(W)x 26.0(H)mm |
Weight (excluding batteries) | 113g |
Protection | IPX5 Rated |
Battery Compartment | 2xAA Battery with upto 5 year battery life |
Operating Environment |
Temperature: 0°C - 55°C (32F - 131F) Relative Humidity: 0 - 95% RH |
Hardware |
Multicolor, multifunction status LED General purpose button Reset button USB-C port Water Leak Detection Plug(Female) |
Warranty | 3 Years |
Ordering Information
Meraki MT Water Leak Sensor | MT12-HW |
Water Leak Detection Cable (8 ft / 2.4m) | MA-CBL-LEAK-1 |
Spot Leak Detection Cradle | MA-CBL-LEAK-2 |
LIC-MT-XY |
Meraki Things Enterprise License (X = 1, 3, 5, 7, 10 years) |
Accessories | External Power Adapter(Sold Separately): MA-PWR-USB-US MA-PWR-USB-UK MA-PWR-USB-EU MA-PWR-USB-AU MA-PWR-ETH (USB-C to Ethernet adapter) |
MA-CBL-LEAK-1 and MA-CBL-LEAK-2 are sold separately, but at least one is required for operation.
Note: Each Meraki MT sensor requires a license to operate, however every dashboard organization comes standard with five free MT licenses to get started.
In the Box
Unit | MT12-HW |
Guides | QIGs |
Battery | 2 AA Batteries |
Mounting equipment | Backplate, Mounting magnet, 3M tape, 2 Mounting Screws, 2 drywall anchors, 1 security screw, 8 cable clips |
