MT30 Datasheet - Smart Automation Button
Overview
Organizations are turning toward digital technologies to streamline processes, create new customer experiences, and adapt to evolving business challenges.
The Cisco Meraki MT30, part of the Meraki MT sensor portfolio, is a smart automation button designed to automate common tasks or trigger specific actions at the press of a button. MT30 comes with an automation builder feature on the Meraki dashboard that makes it easy to build workflows custom to your business needs, including native integrations with other Meraki products.
With the click of a button, MT30 can alert staff members when a customer needs assistance, turn off Wi-Fi to help students focus in school, replenish material on a manufacturing line, or control office lighting to decrease energy consumption. With MT30 and the cloud-first Meraki platform, anything is possible.
Smart sensors. Smarter businesses
Meraki MT accelerates deployment, simplifies management, and provides data-driven business outcomes. Wire-free installation, flexible mounting options, and automatic pairing make it easy to provision thousands of sensors in a short amount of time. Centralized cloud management and open APIs enable MT sensors to be managed alongside other networked devices or integrated with any business system.
Product highlights
Empowering automations
Gain value from existing infrastructure by remotely automating MV, MR, and MS features
Automate from anywhere with events triggered directly from the Meraki mobile app
Build applications custom for your business through the vast partner ecosystem
Custom alerts and analytics
Never miss an event with real-time alerts via email, SMS, push notification, or webhook
Analyze data your way with .csv, .xls, API, or MQTT export options
Cloud-first architecture
Cloud-based management eliminates the need for on-premises servers
Visibility alongside other Meraki products on the dashboard empowers lean teams
Simple and secure connectivity
Streamline deployment with automatic wireless connectivity to MR/MV gateways
Secure device authentication and encryption with the Cisco Trust Anchor module
Technical specifications:
Sensor details
Trigger events with customizable button presses on MT30 |
Dashboard Automation Builder features
Wireless capabilities
Bluetooth® Low Energy |
Operating frequency |
2.400–2.4835 GHz |
IEEE standard |
802.15.1 (Bluetooth Low Energy 4.2) |
Data logging
Data sampling |
Data reporting to gateway every 20 minutes, or immediately upon threshold violation or button press |
Onboard data storage |
Up to five days of data storage |
Security |
Secure Bluetooth Low Energy messaging using long-term key (LTK) |
Note: While we aim for reliable operation, the performance characteristics of any connected system may be influenced by various environmental and network factors. We recommend customers use their best judgment, thoroughly evaluate the MT30's suitability for their specific operational requirements and conduct comprehensive testing to ensure it meets their desired outcomes, especially in time-critical use cases.
Power
One AA battery or USB-C power adapter |
Battery life up to five years |
Power ratings: 5V; 0.1A |
Physical characteristics
Dimensions: 117.1 mm (L) x 65.9 mm (W) x 26.0 mm (H) Weight (excluding batteries): 102g Battery compartment Multicolor, multifunction status LED General-purpose button Reset button USB-C port (receptacle connector) |
Operating environment
Temperature: -18°C to +55°C (0°F to +131°F) |
Relative humidity: 0 to 95% RH |
Warranty
Three-year hardware warranty with advanced replacement |
Ratings
IP55 rated |
Ordering information
MT30-HW |
Meraki smart automation button |
LIC-MT-XY |
Meraki MT Enterprise License (X = 1, 3, 5, 7 years) |
MA-PWR-USB-XX |
External power adapter |
| MA-PWR-ETH | USB-C to Ethernet adapter |
Note: Each Meraki MT sensor requires a license to operate, however every dashboard organization comes standard with five free MT licenses to help get started.
In the box
MT30-HW |
Quick-start and installation guide |
One AA battery |
Mounting equipment |
Wall-mount backplate Magnet VHB tape Two mounting screws Two drywall anchors |
