Quick Walls
Overview
- Quick Walls provide a fast and flexible way to create temporary, multi-camera views for investigations and monitoring within the Vision Portal.
- Intended use: Temporary, ad-hoc video monitoring.
- Place in network: Accessed and used within the Vision Portal.
Use Case
Why might you need this?
To quickly view footage from multiple cameras that aren't part of a pre-configured video wall, or when you need a temporary video wall for a specific incident.
What kind of person might need this?
Security personnel, IT staff, or anyone responsible for monitoring video feeds.
What situation might call for this?
A security breach, a suspicious event, or a need to monitor a specific area temporarily.
Features
- Quick Creation: Create a video wall in just a few clicks.
- Multi-Camera View: Supports up to 16 tiles for viewing multiple camera feeds simultaneously.
- Local Storage: Quick Walls are saved locally within your browser for temporary use.
- Templates: Adaptable and easy to use templates for all Quick Wall layouts.
- Convert to Video Walls: Network Admins can easily convert a Quick Wall into a network Video Wall in a couple of clicks.
Configuration
Steps to configure a Quick Wall
- Log in to the Meraki Vision Portal.
- Navigate to the single camera view.
- Click the "Create Quick Wall" button, or "Add Camera to a Quick Wall" button.
- Select the cameras you want to include in the Quick Wall.
- Arrange the camera tiles as desired, use templates, name and save.
- The Quick Wall is now active.
Steps to Edit a Quick Wall
- Click the Three button drop down on the Quick Wall card you see in the Left Camera List panel.
- Click "Edit".
- Rearrange and edit your Quick Wall.
- Save the Quick Wall
Steps to Delete a Quick Wall
- Click "Delete".
- Confirm the deletion of your Quick Wall.
Steps to save a Quick Wall to a Video Wall (Must be a full network admin):
- Click "Save to Video Wall".
- Name your Quick Wall.
- Click "Save".
- You'll be redirected to the Network-Wide Video Walls tab where you can see your new wall.
Context and Comparisons
- Quick Wall vs. Traditional Video Wall: Quick Walls offer a more flexible and temporary solution compared to traditional video walls, which require network administrator access and are designed for permanent monitoring.
Quick Wall |
Video Wall |
Supported interfaces |
Available in Vision Portal only |
Available in Vision Portal and Dashboard |
Not available on the mobile app |
Available for viewing only in the mobile app |
Not displayed in Meraki Display |
Displayed in Meraki Display |
Role-based Access |
Can be created and deleted by any user |
Can only be created by network admins |
Availability |
Only you can see your quick walls |
Anyone with access to your network can see video walls. |
Lifetime |
Available on the device you created it on in your browser's local storage. |
Always available, on all your devices. |
Your quick walls can become permanent, if you are a network admin as you can convert your quick wall into a video wall to be shared with everyone in your network. To do this, click the 3 dots on the Quick Wall card in the Camera List and click "Save to Video Wall".
Troubleshooting
Common Troubleshooting Steps
- Verify that the cameras are online and streaming video.
- Ensure that you have the necessary permissions to view the cameras.
- Clear your browser cache and cookies.
- Try a different browser.
Event Log: Quick Walls do not generate specific event log messages. Camera connection issues will be logged separately.
FAQ
Can I share a Quick Wall with another user?
No, Quick Walls are stored locally and are specific to the user and browser that created them. Network Admins can convert Quick Walls into Network Video Walls via the 3 dot drop down on the Quick Wall in the left bar/camera list.
How long will my Quick Wall last?
A Quick Wall will remain available as long as you use the same browser on the same device and do not clear your browser data.
Can I access Quick Walls on the Meraki mobile app?
No, Quick Walls are only available within the Vision Portal.
