Meraki Vision Portal Changelog
Introduction
This summarizes the changes on the Meraki Vision Portal which was publicly launched on November 16th, 2021.
Change log
v1.26.2
November 7th, 2025
  • Quick Walls has now exited beta and is officially in General Availability.
    • Quick Walls offers a flexible and temporary video wall solution available exclusively in the Vision Portal.
    • If you haven't tried Quick Walls yet, check it out here.
v1.26.1
October 9th 2025
  • [NEW] Added motion search to the MV84X 4 camera view.
  • [Fix] Addressed visual issues and made improvements to attribute search results.
v1.26.0
September 19th 2025
  • [NEW] Earliest available video option now available for multi-imager cameras
  • [General] Stability and performance improvements
v1.25.7
August 14th 2025
  • [General] Under the hood stability improvements
v1.25.6
August 11th 2025
  • [Fix] Updated calendar styling for when there is no video available
v1.25.5
August 4th 2025
  • [NEW] Earliest Available Video available in Single Camera View time picker (progressive rollout)
  • [General] Added magnetic styling for Time Picker and Motion Event view
  • [Fix] Original Go button functionality restored for Time Picker, clock time selection will no longer auto-seek
  • [Fix] Video wall export list scroll fix added
v1.25.3
July 16th 2025
  • [Fix] Changed behaviour when creating a video wall to not auto-load all Organization cameras initially - cameras will now load when network is changed in the drop down.
  • [Fix] Updated Quick Walls camera names to link to the single camera.
v1.25.2
July 10th 2025
  • [New] Exports added to Quick Walls
  • [Fix] Fixed a bug where offline cameras with Cloud Archive footage would fail to stream.
  • [General] Improved stability for continuous video wall monitoring.
  • [General] Under the hood platform stability and testing improvements
v1.25.1
June 26th 2025
  • [General] Quick wall save option disabled for non-org admins
  • [General] Timeline historical seek improvements
  • v1.25.0
June 6th 2025
  • [NEW] Quick Walls Released (Learn More)
  • [NEW] Vision Portal Training in "Help" tab.
  • [General] Time Picker retention improvements between pages
  • [General] Timeline Time Picker auto-seek functionality on time selection
  • [General] Timeline Time Picker remove seconds from picker
  • [General] Set Video Wall Export to use same time range as default.
v1.24.6
May 19th 2025
  • [General] Magnetic styling added to camera list
  • [General] Icon button for camera details added to camera list
v1.24.5
May 2nd 2025
  • [General] Updated Video Wall Exports to limit selection to 1 per tile
    v1.24.4
    April 16th 2025
    • [General] Updated Magnetic styling.
    • [New] Support for the new MV84X
    v1.24.2
    March 18th 2025
    v1.24.1
    March 11th 2025
    • [Fix] Fixed a bug where full screen video wall rotation would exit full screen view.
    v1.24.0
    March 6th 2025
    • [General] Improved behaviour for handling streams when peeking in and out of video wall tiles.
    • [General] Updated styling for Camera List
    • [General] Updated styling for Navigation bar
    • [General] Updated styling for theme
    v1.23.11
    February 20th 2025
    • [Fix] Fixed a bug related to export page checklist
    v1.23.9
    February 6th 2025
    • [Fix] Allow whitespace in Export Name
    • [Fix] Fixed a bug where a loading spinner would continue to show after the stream was loaded successfully.
    v1.23.8
    January 29th 2025
    v1.23.7
    January 16th 2025
    • [General] Under the hood platform stability improvements
    v1.23.6
    December 18th 2024
    • [Fix] Fixed a bug where dewarped exports were cropped incorrectly when wall mounted
    • [General] Enhanced stability and added accommodations for upcoming features
    v1.23.5
    December 1st 2024
    • [General] Enhancement of platform stability and core services
    v1.23.4
    November 21st 2024
    • [Fix] Resolved an issue causing camera buffering when audio was enabled
    • [Fix] Fixed a bug that caused export failures due to invalid character input
    v1.23.3
    October 30th 2024
    • [New] Improved error messaging for the exports feature to enhance clarity and user guidance
    • [New] Fixed the default state of the event search minimum duration slider
    • [General] Added additional control over throttling of certain services
    v1.23.2
    October 23rd 2024
    v1.23.1
    October 14th 2024
    v1.23.0
    October 10th 2024
    v1.22.8
    September 27th 2024
    v1.22.7
    September 16th 2024
    • [New] Enabled split exports for Smart Retention enabled cameras
    • [New] Enabled additional error checks for Physical Access Control (PAC) integration
    • [General] Optimized task handling to prevent unwanted memory growth
    v1.22.6
    September 11th 2024
    • [New] Fixed image quality issues when peeking into video tile
    • [New] Updated the login page to display a specific error message instead of a generic timeout message
    • [General] Added better logging and additional checks for edge use cases
    v1.22.5
    August 29th 2024
    • [New] Resolved issues stemming from the frequency of server calls related to the availability bar on some servers
    v1.22.4
    August 28th 2024
    • [New] Updated idle timeout manager for video walls
    • [New] Fixed issue where dewarp camera tiles were not counted in the camera count for video walls
    v1.22.3
    August 15th 2024
    • [New] Fixed issue with new video walls not loading video in some instances
    v1.22.2
    August 14th 2024
    • [New] Fixed issue with video wall retaining image when seeking
    • [New] Fixed issue with skipping 1 frame forward or backward
    • [General] Added accommodations for upcoming features
    v1.22.1
    August 8th 2024
    • [New] Fixed issue with users being logged out of full screen video wall view after idle timeout
    v1.22.0
    July 31st 2024
    • [New] Fixed crashing of the video wall creation page caused by fisheye view reset
    • [New] Resolved issues with page isolation in a multi-org, multi-tab setup
    • [General] Added an empty state for no selection, new monitoring endpoints, and additional telemetry
    v1.21.0
    July 17th 2024
    • [New] Added a 404 page with a “back to homepage” button for URL’s that do not point to an existing page
    • [New] Added a ‘Select all’ button when exporting from a video wall
    • [New] Changed default behavior to ‘OFF’ for same time range applied to all exports
    • [New] Added ability to show motion intensity with different levels of opacity on video timeline
    • [General] Updated video player stability and added accommodations for upcoming features
    v1.20.2
    July 11th 2024
    • [New] Fixed issue where some clients were unable to access historical footage
    v1.20.1
    July 10th 2024
    • [General] Added changes to the backend for upcoming features and integrations
    v1.20.0
    June 20th 2024
    • [New] Added the ability to search video walls by name
    • [New] Added icons on video tiles to indicate the streaming source (Cloud/LAN)
    • [New] Added high/low bitrate icons to live video tiles
    • [General] Enhanced telemetry for ongoing improvements
    v1.19.3
    June 11th 2024
    • [New] 'Delete' button removed for read-only users when viewing video wall
    • [General] Security fixes and enhancements
    v1.19.2
    May 31st 2024
    • [New] Removed old dependencies and implemented infrastructure updates to facilitate upcoming feature expansion
    v1.19.1
    May 28th 2024
    • [New] Fixed login issues for users accessing vision portal in Canada region
    v1.19.0
    May 22nd 2024
    • [New] Improved video wall initialization time
    • [New] Added a consistent UI for empty video walls and event search
    • [New] Upgraded application navigation framework
    • [General] General stability and performance improvements to live, historical and clip playback
    v1.18.0
    May 8th 2024
    • Auto focus the search input of the network and organization selection modals
    • Improved rendering of camera thumbnails during the creation of a video wall
    • Added ability to search events from oldest to newest and vice-versa within event search
    • Removed low light alert when using event search for vehicle type detection
    v1.17.9
    April 24th 2024
    • Stability fixes and improvements
    v1.17.8
    April 4th 2024
    • Create video wall flow no longer redirects to newly created video wall
    • General improvements and stability fixes for video wall
    v1.17.7
    March 28th 2024
    • Removed surveys from features that are now out of beta
    • Color labels are more consistent in attribute search
    • General improvements and video player stability improvements
    v1.17.6
    • Fixed issue with organization switching
    v1.17.5
    • General stability fixes
    v1.17.4
    • Updated empty state for the video wall page when no video walls are created.
    • 'Event Search' is now out of Beta, beta tag has been removed.
    • Event length in event search can be modified.
    • Preset video wall templates added with ability to swap tiles.
    • General improvements to tracking metrics for performance of video walls and audio.
    v1.17.3
    • Event search feedback modal removed.
    • Increased resource allocation to handle more users.
    v1.17.2
    • Stability and performance improvements.
    v1.17.1
    • Clicking at any point of the motion event navigates to the time clicked, added Shift+ Click to navigate to beginning of motion event.
    • 'Configure Camera' button disabled when no cameras are selected to create video wall.
    v1.17.0
    • All thumbnails within event search, motion search, and camera made more consistent.
    • Update event search to filter by moving people and vehicles.
    • Update video wall creation grid to vertical gravity to improve tile snapping.
    • Update the organization selection modal to allow selecting the current organization.
    • Bug fix: Fix app crash with 0 video walls.
    v1.16.3
    • Various bugs and performance fixes.
    v1.16.2
    • Bug fix for checkboxes not being selectable when editing video walls.
    • Organization switching made more reliable.
    • 'Back to dashboard' button added to Vision again (For Org Admins Only).
    v1.16.1
    December 21
    • Audio will be turned off on video walls, by default
    • Video wall rotations to show only for the selected network
    v1.15.0
    November 7
    • A delayed notification message will show when an export takes too long
    • Event Search will now have a list view for camera selection
    • Misaligned tags fixed on the Event Search page
    v1.14.0
    October 25
    • Live Only Admins will not see event search, motion search, player controls or the timeline anymore
    • Back to dashboard button will no longer exist on the Vision Portal
    • Various performance and bug fixes
    v1.13.0
    October 13
    • Event Search will now show list of cameras selected, which can also be hidden from the eye icon
    • Event Search loading messages updated when results take a long time or matching events aren't found
    v1.12.0
    October 10
    • Various performance issue fixes
    v1.11.7
    Sept 26
    v1.11.3
    Sept 13
    • Event Search: Clip Modal updated
    • Event Search Bug: Stalled results will be able to re-load
    • Various performance issues fixes
    v1.11.1
    Aug 29
    v1.11.0
    Aug 21
    v1.9.6
    Aug 2
    • Fix stale motion search results when switching between video walls
    • Fix view failure when switching between dewarped cameras
    v1.9.5
    July 19th
    • Update event search minimum event duration UI
    July 5th (v1.9.4)
    v1.9.4
    • Minor UI update to thumbnail size selection
    v1.9.3
    v1.9.2
    • Video walls are now sorted alphabetically
    • Exports with combined footage are now searchable
    • Minor UI improvement to avatar dropdown
    June 7th (v1.9.1)
    • Various performance and stability fixes
    May 26th (v1.8.3)
    • Revamp of the exports page to include time of creation
    May 9th (v1.8.1)
    • Event search filter selections and results will show even when you move around different pages on Vision
    • Export failures will now show detailed errors, with the reasons and addition of camera name and export time range
    • You can now delete multiple exports at once on the Exports page
    April 13th (v1.8.0)
    • You can now dewarp on wall mounted fisheyes, with a DPTZ oriented to support wall mounts (rotate around the X axis)
      • ​​​​​Try this using "Dewarp" on the Camera List page for a fisheye configured to be a wall mount under Settings on Dashboard
      • Try this using "Dewarp" on wall mounted fisheyes on the video wall page too
      • You can also use new DPTZ presets for wall mounted fisheyes while creating a new video wall
    • Various stability and performance bug fixes
    March 28th (v1.7.7)
    • If your password expires, the Vision Portal will now direct you to renew it
    • Feedback portal added for Event Search (feature available via the Meraki Early access program)
    • Navigate motion search results quickly using the left/right arrows now
    • Various stability and performance fixes
    March 10th (v1.7.6)
    • NEW FEATURE: Event Search added to the Meraki Early access program
    • Performance fixes for the Event Search feature
    March 10th (v1.7.5)
    March 8th (v1.7.4)
    • Deleting an export will not cause an error anymore
    • Auto select a camera when drawing region of interest in Motion Search
    February 28th (v1.7.3)
    • Camera names will now truncate on a video wall to give more room to watch your video on smaller tiles
    • You will not see any loading indicators anymore when you zoom into a fisheye video stream
    February 15th (v1.7.2)
    • Add daylight timezone behaviour
    • Change screenshot filename and timestamp
    January 31st (v1.7.1)
    • Logins will now have CAPTCHA support
    • You will now be redirected to your last viewed video wall or camera
    • Use the forward/backward arrow keys on your keypad to watch video
    • Lots of stability and performance fixes
    January 5th, 2023 (v1.6.23)
    • Various performance and stability improvements
    December 16th, 2022 (v1.6.22)
    December 7th, 2022 (v1.6.21)
    November 18th, 2022 (v1.6.20)
    • [Video Wall FEATURE] You can now export different time ranges from each video wall tile
    • [Video Wall FEATURE] You can now export from every dewarped tile from a single fisheye camera
    October 25th, 2022 (v1.6.19)
    October 14th, 2022 (v1.6.18)
    • Adds buttons to "peek" and "unpeek" into camera tiles on the video wall
    • Alphabetizes the network list
    October 12th, 2022 (v1.6.17)
    • Adds the ability to dewarp exported fisheye videos on the "Exports" page
    • Allows disabling of dewarp via mouse scroll
    • Miscellaneous UI changes
    October 6th, 2022 (v1.6.16)
    Sept 29th, 2022 (v1.6.15)
    Sept 21st, 2022 (v1.6.14)
    Sept 15th, 2022 (v1.6.13)
    • You will now be redirected to the last viewed network, by default
    • Wall mounted fisheyes will only zoom in and out, and not dewarp
      • Note: To be treated as a wall mounted fisheye, configured the "Mounting" setting on the Meraki Dashboard "Video settings" tab
    • Miscellaneous UI fixes
    Aug 19th, 2022 (v1.6.12)
    • Adds the ability to rename your exports
    • Updates the logging of Vision portal local streams on the Dashboard Video access log
    • Shows the region of interest selection grid when using video wall peek mode for Motion Search
    Aug 11th, 2022 (v1.6.11)
    •  All new “THEATER MODE” :tv: for single camera and video wall display
    • Gives you benefits of a “full screen” but also allows you to open multiple windows on the side
    • Fixes an issue while using the time-picker and the “natural language processing” text input box
    • Ex. Type in yesterday and click enter to help you select the first option
    July 29th, 2022 (v1.6.10)
    No customer-facing changes in this release
    July 28th, 2022 (v1.6.9)
    July 15th, 2022 (v1.6.8)
    July 14th, 2022 (v1.6.7)
    July 12th, 2022 (v1.6.6)
    • Support for Multi-Network Video Walls
    • Video Walls can now be created, edited, re-named and deleted
    Documentation here
    July 6th, 2022 (v1.6.5)
    • Increase dewarp zoom capability by 3x on fisheye cameras
    • Add video wall zoom out via clicking anywhere on peek view
    • Update to new Cisco loader design
    • Fix calendar error bugs
    June 22nd, 2022 (v1.6.4)
    June 15th, 2022 (v1.6.3)
    • Video error messaging will now match with dashboard
    • Stability and Performance improvements (mainly for the Video Wall)
    June 8th, 2022 (v1.6.2)
    • No customer-facing changes in this release
    June 6th, 2022 (v1.6.1)
    May 27th, 2022 (v1.6.0)
    • Adds a time range filter for Advanced Motion Search
    • Removes the "show password" toggle in the login page
    • Fixes timepicker date selection issue for users on a different timezone than the network timezone
    May 16th, 2022 (v1.5.2)
    • Adds default video wall rotation to rotate through all video walls unless edited
    • Adds camera list search by camera model
    • Adds status overlay for loading indicator for fisheye cameras
    • Conducts Motion Search and export on selected camera on the video wall
    • Fixes logout timeout issue while in full screen video wall
    • Some MV21/71 playback improvements
    April 12th, 2022 (v1.4.2)
    • Added the ability to "Change organization" under the top-right user icon
    • Added larger "Update" button for when a new release is available
    • Loads the first online camera on the camera list (fixed issue from previous implementation)
    • Added on-hover camera details on the camera list to show associated tags and model number
      • Note: Tags are editable on Meraki Dashboard, accessible via bottom-left of Meraki Vision
    • Changed the status color for "Alerting" cameras to show as green and online instead of red
    • Offline cameras show as "Offline" on the video wall
    • Changed loading spinners to the Cisco logo in various places
    • Various performance and stability improvements in video playback on video wall
    March 18th, 2022 (v1.4.0)
    • Added a "What's New" dropdown to the header to show recent updates to the interface and notify you if an update is available
    March 15th, 2022
    • Fix for video wall screenshot
    • Hover over camera list to view full camera name
    March 8th, 2022
    • You can now digitally zoom and dewarp on a selected camera on the video wall
    • You can now export dewarped fisheye footage
    • You can now run a Motion Search on MV2 cameras even without Cloud Archive
    • Page now loads the first online camera on the list
    • Fixes page selection error on exports page
    • Improves page performance of Advanced Motion Search
    November 16th, 2021
    First release of the interface!
  • Was this article helpful?
