MV84X Datasheet
Overview
The MV84X multi-sensor camera revolutionizes surveillance by delivering unmatched coverage for large areas. By combining four cameras into a single sleek design, the MV84X offers unmatched coverage. Designed for dynamic environments like warehouses, airports, and manufacturing floors, this powerful camera ensures zero blind spots with its four cameras, with combined 20MP resolution and 360-degree analytics. The MV84X empowers businesses with instant insights, AI-powered object detection, providing a seamless blend of powerful technology and simplicity for the ultimate security solution. Perfectly built for today's fast-paced, demanding spaces, this is more than just a camera: it’s a next-gen security experience.
Use Case
The MV84X is ideal for capturing wide and multi-angle views...
- Multi-corridor intersections
- Long hallways
- Open spaces like lobbies
- Wide parking lots
- Building perimeters
- Entryways
- And more
This flexibility makes it particularly valuable in large or complex spaces like
- Offices
- Retail storefronts
- Warehouses
- And more
Security that tells a complete story
The MV84X delivers up to 20MP combined video resolution and offers 360° views, capturing not just the broad context of a scene but also precise detail when needed. Its panoramic field of view enhances situational awareness, making surveillance more efficient. Outdoor-rated and equipped with IR illumination, the MV84X improves safety and security in parking lots, hallways, warehouses, and other open spaces, even in low-light conditions.
Product highlights
Advanced feature spotlight
Smart Retention
Retain critical motion events in high resolution without sacrificing overall storage. Smart Retention delivers predictable retention days by recording two streams—one high‑resolution for motion and one lower‑resolution continuously while reducing bandwidth and storage overhead. Simply enable it per camera or via profiles. You can comply with local regulations with adjustable retention limits while ensuring key events remain crystal‑clear.
Key Benefits
    High‑quality motion capture + standard resolution continuous coverage
    Predictable retention days and reduced bandwidth
    Flexible settings for compliance needs
    Minimum 60 days of video guaranteed
Event Search in Meraki Vision Portal
A powerful tool that streamlines investigations by enabling simultaneous searches across multiple cameras, complete with advanced detection and duration filters.
Key Benefits
    Adaptive filtering: Narrow down results by defining regions of interest and setting minimum event lengths.
    Faster review: Immediately see motion recaps, play back short video clips, and export critical footage.
    Straightforward interface: Easily configure search parameters and timeline ranges within the Vision Portal, reducing the time spent on manual review.
By focusing your search on exactly what matters, Event Search makes it easier to uncover crucial details quickly.
MV84X Camera Specifications
| Category | Specifications |
| Camera |
| Video |
| DORI Specifications (Maximum Resolution) |
| Networking |
| PoE Requirements | With IR: 802.3bt (PoE++) Without IR: 802.3at (PoE+) Maximum Power per Port: 60 W |
| Environment | Operating Temperature
| Data and network security |
| Physical characteristics |
| Warranty | 5-year hardware warranty with advanced replacement |
| Hardware | MV84X-HW: 4x5MP Multi-Sensor camera with 4TB for internal edge storage |
| Licensing | LIC-MV-MULTCAM-XY: Meraki MV Enterprise license (X = 1, 3, 5, 7, 10 years) |
| Accessories |
Each Meraki camera requires a license to operate.
