Z3C Installation Guide
Please note that this document has been deprecated in favor of the following replacement document: https://documentation.meraki.com/Mer...allation_Guide
This document describes how to install and set up the Z3C teleworker gateway. Additional reference documents are available online at: www.meraki.com/library/products.
Z3C Overview
The Meraki Z3C is 802.11a/b/g/n/ac Wireless Security Appliance designed for telecommuting employees and IT staff. It is also a great all-in-one device to test the capabilities of Meraki's cloud-managed networking. This gateway provides the following features:
- 4 wired ports with one PoE-powered port, ideal for phones
- 1 GbE WAN port, 4 GbE LAN ports
- 3G / 4G failover via CAT 3 LTE or USB modem
- Dual-band 802.11ac Wave 2 radios
- 2x2 MU-MIMO, up to 1.3 Gbps data rate
- Wall screws and anchors for mounting to a drywall surface, either vertically or horizontally
Package contents
In addition to the Z3C, the following are provided.
The Z3C front panel
Ports and Status Indicators
The Z3C uses a single LED to inform the user of the device's status.
LED Status |
Meaning |
Solid orange |
Power is applied but the appliance is not connected to the Meraki Dashboard |
Rainbow Colors | The appliance is attempting to connect to Meraki Dashboard |
Flashing White |
Firmware upgrade in progress |
Solid White |
Fully operational/connected, uplink actively using wired WAN |
Solid Purple | Fully operational/connected, uplink actively using cellular failover |
The Z3C Back Panel
Additional functions on the back panel are described below, from left to right.
SIM Card Slot | Active, supported SIM cards can be inserted into this slot to enable cellular capabilities. Uses nano SIM card (4FF size). |
Reset button |
Insert a paper clip if a reset is required.
USB port |
USB 3.0 for 3G/4G wireless cards. Traffic status is indicated by the USB LED. |
WAN / Internet port | This port provides connectivity to the WAN. |
LAN ports |
These 4 ports provide connectivity to computers, printers, access points, or Ethernet switches. A steady green LED indicates bidirectional connectivity, and flashing green indicates traffic. |
PoE+ Port |
One of the LAN port provides PoE+ for connectivity to computers, printers, access points, or Ethernet switches, up to 15W of PoE power. A steady green LED indicates bidirectional connectivity, and flashing green indicates traffic. |
Power input | Designed for use only with the unit’s power supply. |
The Z3C Bottom Panel
Please note that the serial number is located on the product label on the bottom panel of the Z3
Mounting Hardware
The supplied wall screws and anchors allow you to mount the gateway on a drywall surface, either vertically or horizontally.
- For mounting on drywall, use a ¼-in drill bit, then insert the plastic and screw assemblies.
- For mounting on wood or a similar surface, use only the screws.
- Allow the heads of the screws to stick out far enough to be inserted securely into the back of the gateway.
Connecting to WAN
All Meraki Z3C devices must have an IP address. This section describes how to configure your local area network before you deploy it. A local management web service, running on the gateway, is accessed through a browser running on a client PC. This web service is used for configuring and monitoring basic ISP/WAN connectivity.
Setting up a Static IP Address
Do the following to configure basic connectivity and other networking parameters:
- Using a client machine such as a laptop, connect to one of the four LAN ports of the Z3C.
- Using a browser on the client machine, access the gateway's built-in web service by browsing to http://setup.meraki.com. (You do not have to be connected to the Internet to reach this address)
- Click Uplink configuration under the Local status tab. The default credentials use the device serial number as the username, with a blank password field.
- Choose Static for the IP Assignment option.
- Enter the IP address, subnet mask, default gateway IP and DNS server information.
Setting up a DHCP IP Address
By default all Z3C devices are configured to DHCP from upstream WAN / ISP servers. Simply plug the Z3C's WAN / Internet port to your upstream circuit and wait a few minutes for the unit to negotiate a DHCP address. If your Z3C device was configured to have a static address (and not attempt to negotiate DHCP), you can held the reset button while the device is powered until the lights on the device turn off. Doing so will return the Z3C device to its default DHCP settings.
Setting up Cellular Failover
The Z3C has an embedded LTE module for cellular failover connections. The following section will walk through first-time set-up of a Z3C with an internet connection as a primary connection and cellular as failover.
Note that the IMEI cannot yet be found on the Meraki dashboard, only on the physical label of the device. The IMEI of the MXs with embedded LTE, as well as the serial number and MAC address, can be found on the product label at the bottom of cellular-embedded MX devices.
To set up the cellular failover connection, follow the steps below:
Power off the Z3C. Swapping/installing SIM cards while the Z3C is powered on may cause unexpected behavior or errors
Open the SIM tray using the SIM card removal tool included in the box
Insert a nano SIM card (4FF size) and close the SIM tray
Connect the uplink for the Z3C device via a wired connection to connect to the Meraki cloud
Power on the Z3C and wait for the Z3C to show as online in the Meraki dashboard
Check with the carrier of choice if an APN needs to be configured. If so, do that from the Meraki Dashboard under Teleworker Gateway > Monitor > Appliance Status > Uplink tab
Navigate to Teleworker Gateway > Monitor > Appliance Status > Uplink tab and next to Status, select the edit (pencil) button and then select Enabled. When the cellular uplink is successfully connected, you will be able to see the status on the left hand side of the Appliance Status page and in the Uplink tab. The connection will say Ready when it is successfully connected
Test the cellular failover connection by unplugging the wired connection or by using the traceroute tool under Teleworker Gateway > Monitor > Appliance Status in the Tools tab
If, after following the steps above, the SIM card is not detected, please confirm with your carrier that the SIM card is active and has data. You will need the ICCID of the SIM card and IMEI of the device to get troubleshooting help from the carrier
A list of certified carriers can be found in our Z3/Z3C Overview and Specifications document.
Please contact the Meraki Support team if the cellular connection is still not being recognized after following the steps above
Additional Settings
Setting VLANs
If your WAN uplink is on a trunk port, choose VLAN tagging > Use VLAN tagging and enter the appropriate value for VLAN ID for your network.
Setting PPPoE
PPPoE authentication may be required if you are connecting Z3C device to a DSL circuit. You need to know your authentication option and credentials (supplied by your ISP) in order to complete these steps.
- Choose Connection Type > PPPoE.
- Select your Authentication option.
- If you select Use authentication, enter appropriate values for Username and Password.
Web Proxy Settings
These settings take effect if the Z3C device has to fall back to using HTTP to contact the Cloud Controller. By default, web proxy is disabled. To enable web proxy, do the following:
- Choose Web proxy > Yes.
- Enter values as appropriate for Hostname or IP and Port.
- If you require authentication, choose Authentication > Use authentication, and enter appropriate values for Username and Password.
Configuring Physical Link Settings
To configure physical link settings on the Ethernet ports, click Local status > Ethernet configuration. You can enable half duplex, full duplex, and autonegotiation, as well as set 10- or 100-Mbps data rates.
Power Efficiency Modes
The Meraki Z3C Teleworker Appliance has an off mode and a networked standby or efficient idle mode, both with power consumption less than 12W.
In off mode, the power consumption is a measured 0.3W. In the networked standby or efficient idle mode, the power consumption is under that of full operation mode, which is a measured 6.6W. This mode is initiated after treating the last payload packets.
To activate and/or deactivate wireless network ports, you may use the physical on/off switch or deactivate through the Meraki Dashboard.
