Z3 and Z3C Datasheet
Image of a Z3 unit with the LED lights to the left-hand side corner, and the Cisco label on the top of the device.
Features
  • Managed via Cisco Meraki Dashboard
  • Automatic Firmware upgrades
  • Automatic WAN Failover to Cellular Uplink
  • L3/L7 Stateful Firewall
  • 1:1 and 1:Many NAT
  • Configurable VLANs / DHCP support
  • Static Routing
  • Client VPN endpoint
  • Meraki AutoVPN and L2TP/IPSec VPN endpoint
  • Custom Traffic Shaping
  • Historical Client Usage statistics
  • Netflow support
  • Syslog integration
  • Remote Packet Capture tools
Hardware Features
  • Built-in Cellular 100 Mbps CAT 3 LTE Uplink (Z3C only, requires SIM card)
  • Built-in 802.11ac Wireless Wave 2 capability
Configuration
The basic initial configuration of the Z3 and Z3C is just as simple as with other MX/Z devices. The links below provide additional information and instructions relating to each step in getting the device setup and configured for the first time.
  1. Claim the device to an Organization on the Meraki Dashboard
    1. If a Dashboard Organization does not yet exist, Create one
  2. Add the device to a Dashboard Network
    1. If a Network does not yet exist, Create one first
  3. Physically connect the device to the local network
    1. Insert an activated SIM card to allow the cellular uplink to function (Cellular model only)
    2. Power on the device and let it check in to the Dashboard
    3. If necessary, configure a Static IP on the WAN interface through the Local Status Page to allow it to check in.
  4. Finish configuring the device from the Meraki Dashboard
    1. Manage local VLANs
    2. Modify Firewall rules
    3. Configure VPN connectivity
    4. Configure custom APNs for cellular modems
Technical Breakdown
WAN Interface
Z3 Z3C
1x GbE RJ45 1x GbE RJ45
Cellular Uplink via 3rd Party USB Modem Built-in Cellular Uplink (Nano SIM Card [4FF]) or 3rd Party USB Modem
LAN Interface
Z3 Z3C
3x Dedicated GbE RJ45 3x Dedicated GbE RJ45
1x Dedicated GbE RJ45 PoE 1x Dedicated GbE RJ45 PoE
802.11 Wireless Interface
  Z3/C
Radio Information
802.11a/b/g/n/ac Wave 2 (2.4 or 5Ghz), 2x2 MU-MIMO
Antennas  4x Internal dipole antennas (Gain: 3dBi @ 2.4Ghz, 4 dBi @ 5Ghz)
Maximum Data Rate 1.3 Gbps
Regulatory Domains FCC, IC, C-Tick, RoHS
Cellular Interface
When bringing the units online for the very first time, Z3C units should be connected via a wired WAN interface to the Meraki Dashboard to retrieve an update to allow for proper use of the integrated cellular connectivity.
   US / North America Bands Worldwide Bands
HSPA+ 2, 4, 5 1, 3, 8
FDD-LTE 2, 4, 5, 13, 17 1, 3, 7, 8, 20
TD-LTE - -
GSM Bands 850, 900, 1800, 1900 900, 1800
CA N/A N/A
Certifications PTCRB (US) RCM (ANZ, APAC), GCF (EU)
Tested Carriers AT&T, Bell Canada Orange, Telia, Telecom Italia, Telefonica, Post, BT, STC, Telenor, SingTel
Carrier compatibility is generally based on having compatible bands on the modem. In the open market, carriers may only require regulatory domain certifications and open market certifications, like the PTCRB and GCF, to be compatible for their network. Sometimes carriers will require additional testing before a device can be used on their network. The section Tested Carriers is based on Meraki device certifications being approved by those specific carriers. A carrier being listed above means that they have officially certified the Meraki product for their cellular network. There maybe many unlisted carriers could be functionally compatible with Meraki devices. The list of tested certified carriers is based on the carrier validating Meraki per their network parameter requirements. If a carrier you are looking to use is not listed above, it could be that they do not require additional compliance testing for their network.
Please note that until certification has been obtained, the Z3C will not work on Verizon's network.
Throughput and Capabilities
  Z3/C
Recommended Maximum LAN Clients Up to 5
Max Stateful Firewall Throughput in NAT mode 200 Mbps
Max Stateful Firewall Throughput in Passthrough mode 100 Mbps
Max VPN Throughput 75 Mbps
Physical
  Z3 Z3C
Mount Type Desktop Desktop
Dimensions
(h x d x w)
6.83 x 4.41 x 1.04 in /
173.4 x 112 x 26.3 mm
7.9 x 4.41 x 1.04 in /
200 x 112 x 26 mm
Weight 0.85 lbs / 0.386 kg 1.1 lbs / 0.487 kg
Power Supply 50W (54 V / 0.92 A)  50W (54 V / 0.92 A)
Operating Temperature
32°F - 104 °F
0°C - 40°C
32°F - 104 °F
0°C - 40°C
Humidity 5% to 95% 5% to 95%
Accessories
Accessory Description
MA-STND-1 1x Desk Stand (Z3/C)
MA-PWR-50WAC 1x 50W Power Adapter (Z3)
MA-PWR-30W-US 1x 30W Power Adapter, US (Z1)
MA-PWR-CORD-US 1x AC Power Cable, US plug
MA-PWR-CORD-EU 1x AC Power Cable, EU plug
MA-PWR-CORD-UK 1x AC Power Cable, UK plug
MA-PWR-CORD-AU 1x AC Power Cable, AU plug
Warranty
Z-series Warranty coverage periods are as follows:
Product Warranty Period Warranty Information
Z-series (e.g. Z3, Z3C) Lifetime
Z-series Accessories 1 Year
The following are considered accessories:
SFP Modules, all mounting kits and stands, interface modules, additional power cords
Additional warranty information can be found on the Return Policy and Requesting a RMA page of the Cisco Meraki website.
If your Cisco Meraki device fails and the problem cannot be resolved by troubleshooting, contact support to address the issue. Once support determines that the device is in a failed state, they can process an RMA and send out a replacement device free of charge. In most circumstances, the RMA will include a pre-paid shipping label so the faulty equipment can be returned.
In order to initiate a hardware replacement for non-functioning hardware that is under warranty, you must have access to the original packaging the hardware was shipped in. The original hardware packaging includes device serial number and order information, and may be required for return shipping.
Meraki Z3/Z3C devices have been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation.
Troubleshooting
Common Troubleshooting Steps
My cellular uplink is stuck at 'Connecting'
Built-in Cellular - Ensure that the SIM card is inserted correctly and is activated with the correct PIN entered, if necessary. Ensure there is no USB modem connected as the MX will prefer a USB cellular modem to the internal modem, if available.
USB Cellular - Ensure that the USB Modem is activated and able to pass traffic when connected to a PC. Ensure it is fully connected and powered on when connected to the MX. If a custom APN is needed contact Meraki Support to get it applied.
My modem is connected but is getting very poor throughput
Meraki strongly recommends that the cellular uplink be used on a 4G connection with good signal strength to provide adequate bandwidth to support using the cellular connection as a backup uplink. If no 4G signal is available or the available signal is low strength the achievable throughput may not be adequate to fully support a remote site and more restrictive traffic shaping rules should be used to ensure traffic is prioritized appropriately.
Common Event Log Messages
There are currently no Z3/C specific Event Log entries, for more general information about navigating the Event Log and the types of Events that could be expected please check out our Event Log documentation.
FAQ
Is the Z3C using the Cellular Uplink?
When the Z3C is using the Cellular Uplink it will display a Pink Status LED instead of the usual White LED.
Is this SD-WAN over LTE?
No.
Can LTE be used as the primary uplink?
No, LTE is currently only supported as a fail-over link and should only be primary during a temporary WAN failure event.
How does LTE work for free trials?
Meraki does not supply SIM cards so while the unit can be trialed, it is up to the end user to procure a working SIM card on a compatible carrier.
Do these models support eSIM capability?
No. Currently, Meraki customers will need to acquire a SIM card from their carrier and install.
Will the LTE devices be available in the USA and Worldwide?
Yes. There will be two models: the North American model and the worldwide model
Should I contact Meraki support for carrier issues?
No, you will need to bring support issues to the carrier for carrier issues.
How do I troubleshoot carrier issues?
The Meraki Dashboard provides the ability to monitor signal strength, performance, and historical traffic for troubleshooting purposes. For additional troubleshooting related to the carrier, the carrier will need to be contacted.
If an external USB cellular modem and the internal LTE SIM card are both connected, which one takes precedence?
The external USB cellular modem will take priority over the internal LTE SIM.
Can I change the APN?
Yes. Custom APNs can be configured from Cellular section of the Uplink tab on the Security Appliance > Appliance Settings page.
  • Was this article helpful?
