How to Block and Allow Clients on a Cisco Meraki Network
Overview
This article explains how to allow list or block a specific client on a Cisco Meraki network. You can configure this on a client-by-client basis, and the change affects the client immediately.
You can allow list or block clients on these devices:
- Meraki WAN appliances (MX Security Appliance)
- Meraki access points (MR Access Points)
You cannot add a client to the allow list or block list on a Meraki switch.
You configure client policies once a device appears in the network client list. You can also pre-configure a policy for clients that are not yet listed.
Built-in client policies
Two built-in policies are available for a client:
- Allow list
- Blocked
Normal is the default setting for every client. It subjects the client to all network-wide settings.
You can also apply group policies to a client. Apply them the same way as the policies described below.
What the allow list policy does
An allow-listed client receives the following settings:
- Exempt from all firewall rules, both Layer 3 and Layer 7. Applies to the MX Security Appliance and the MR Access Points.
- Bypasses AMP.
- Bypasses a Click-through splash page.
- Bypasses a Billing (paid access) splash page. The client accesses the network on an SSID without paying or authenticating.
- Bypasses a Sign-on splash page without authenticating. Applies to the MX Security Appliance and the MR Access Points.
- Exempt from the Per-client bandwidth limit. Applies to the MX Security Appliance and the MR Access Points.
- Exempt from Traffic shaping rules. Applies to the MX Security Appliance and the MR Access Points.
- Bypasses Content filtering on the MX Security Appliance.
Allow listing previously did not exempt clients from L3 rules. It did exempt them from L7. Now, allow-listed clients are exempt from all firewall rules — L3 and L7. Allow-listed clients do not bypass - restricted YouTube content and IDS/IPS under Security & SD-WAN > Configure > Threat Protection.
What the block policy does
A blocked client receives the following settings:
A firewall rule blocks all communication with other devices on the network. This applies only to traffic that traverses the Meraki device on which the block is configured.
A Blocked Splash Page appears when the user tries to load a web page.
Prerequisites
Review the following before you configure client policies:
- A Meraki MX Security Appliance or MR Access Points in your network. You cannot apply these policies on a Meraki switch.
- Access to the Network-wide > Monitor > Clients page on the Meraki dashboard.
Client limits
- The limit is 3000 clients for allow listing and 3000 clients for blocking.
- An error appears when you attempt to allow list or block more than 3000 clients.
The single configuration pane to block and allow list users on the security appliance and the SSIDs is only available on a combined network. For uncombined networks, complete these settings on each dashboard network.
Step-by-step instructions
You can allow list or block a client in two ways on the Meraki dashboard.
Placing a client on the Block list blocks both LAN and Internet traffic.
Using the clients list
Navigate to Network-wide > Monitor > Clients.
Check the boxes of the clients that you want to allow list or block.
Select the Policy drop-down above the client list.
Choose blocked or allow listed.
To apply the policy per SSID or only on the MX Security Appliance, select Different policies by connection and SSID.
To clear the setting, remove the block list or allow list policy. Then select normal.
If you use a splash message when applying a block, limit the message to one paragraph.
Adding a client that has not connected
A client that has never connected to the network can still have a policy applied. The same applies to a client that is not in the client list.
Select Add client.
Enter a friendly name for the device.
Enter its MAC address.
Choose the policy you want to apply.
Select Save changes.
Using the client details page
The client details page shows the current policy. You can update it here.
Open the client details page.
To apply the policy per SSID or only on the MX, select Different policies by connection and SSID.
Configure blocked or allow listed per SSID and on the MX Security Appliance.
To clear the setting, remove the blocked or allow list policy. Then apply normal.
Verification
Confirm your configuration was applied successfully:
Filter clients to determine which clients have a policy configured.
To check pre-configured clients:
Choose to show all clients with a policy. This shows clients you pre-configured but that have not yet been seen on the network.
If a client does not appear immediately, refresh the page first.
Troubleshooting
Review the following behavioral notes and edge cases.
Blocked client behavior
- A blocked device still receives an IP address. It can also resolve DNS names.
- The EAP exchange is still allowed for wireless clients. Devices can associate with an SSID.
- The block applies to client traffic after the 4-way handshake completes.
Allow list bandwidth and association behavior
- A device is still subject to association requirements and per-SSID bandwidth limits on MR Access Points.
- A device is still subject to Uplink Configuration and Security Filtering on an MX Security Appliance.
- Certain RADIUS attributes assign a bandwidth limit to a client. These include Filter-ID (via a Group Policy), Maximum-Data-Rate-Upstream, and Maximum-Data-Rate-Downstream.
- These RADIUS attributes are considered before any dashboard-assigned configuration. A device is still subject to these bandwidth limits even when allow listed.
- View limits applied with the Maximum-Data-Rate-Upstream or Maximum-Data-Rate-Downstream TLVs under the Wireless > Monitor > Splash logins page.
Template-bound network behavior
Client policy assignments apply to individual networks. Allow-listing a client in one network does not automatically allow-list it in other networks bound to the same configuration template. Removing the client from the allow list in one network does not automatically remove it from the allow lists in those other networks.
To apply or remove the same client policy across multiple networks, update each network individually or automate the changes using a custom API script or a Dashboard Workflow.
Meraki DHCP behavior
Security appliance policies have no effect for clients connected to an SSID with Meraki DHCP. The client MAC and IP address get NATed at the MR before reaching the security appliance.
Site-to-Site VPN firewall rule behavior with group policy
- If the Site-to-Site VPN Outbound Firewall Rule allows and the Group Policy L3 denies, traffic is denied.
- If the Site-to-Site VPN Outbound Firewall Rule denies and the Group Policy L3 allows, traffic is denied.
- If the Site-to-Site VPN Outbound Firewall Rule denies and the Group Policy allow-listed preset is configured, traffic is denied.
