Create a Workflow
To create a workflow, use the Workflow Editor to drag objects such as activities, logic components, and other workflows from the Activities panel to the canvas and then configure the properties for each of the objects.
Please review the Workflows Best Practices for guidelines to follow when building a workflow.
Before You Begin
Configure any Targets that your workflow will communicate with. See the Targets Help topic for more information.
High-Level Procedure:
  1. Define the Workflow:
    Set up the workflow’s core properties, including its display name, description, and other important attributes.
  2. Specify Workflow Inputs, Variables, and Outputs:
    • Inputs: Determine which parameters are necessary to start the workflow and mark any that are mandatory.
    • Variables: Create variables to store and manipulate data within the workflow.
    • Outputs: Define what results or information the workflow will provide upon successful execution.
  3. Add Workflow Activities/Logic/Sub-Workflows:
    Use the Workflow Editor to add activities that perform specific tasks, such as integrating with other systems, running scripts, or executing predefined processes.
    This can also include inserting user tasks at points where user input or approval is required. For example, you might add a task to ask a user to approve an automated change or to specify configuration details needed for the next step. Tasks temporarily pause the workflow until a response is received.
  4. Validate the Workflow:
    Review and test the workflow to ensure that all activities and tasks are properly connected, and that input/output relationships are correctly configured. Validation helps prevent errors during execution.
Step-by-Step Process
  1. Choose Automation > Workspace in the navigation menu.
  2. On the Workflows tab, click Create Workflow.
3. Choose a type according to the intent of this workflow, and click Continue. For more information, see the Workflow Intent Help topic.
4. In the Properties panel of the Workflow Editor, define the workflow properties. For more information, see the Workflow Editor Help topic.
5. From the Activities panel, drag and drop activities, logic, or other workflows onto the canvas. For more information, see the Workflow Activities Help Topic.
6. Select each object in the workflow and define its properties in the Properties panel. The exact properties necessary will vary among workflow objects.
For example, you can click the variable_reference_icon.jpg (Variable Reference) icon to use the variable browser to explore all of the variables available while building a workflow.
The variable browser is hierarchical, and variables are only available within the scope in which they are defined. For more information, see the Variables Help topic.
7. When you have completed constructing the workflow, click Validate to verify that the workflow is valid.
If you have invalid activities, they will be displayed with an orange bar, and a warning will be displayed in the upper right corner of the Properties panel.
Resolve any issues and validate the workflow again.
After the workflow has been created and successfully validated:
  • To execute the workflow, click Run. You can then view the status of the workflow from the Runs page.
  • To edit the workflow after the run completes, click Modify to open the workflow for editing.
  • To export the workflow to your Git repository, click Share > Commit To Git. For more information, see the Import and Export a Workflow Help topic.
  • To request that the workflow be published to Exchange, click Share > Submit to Exchange. For more information, see the Publish to Exchange Help topic.
  • Was this article helpful?
