New Workflows Icons
Workflow Icons and their Descriptions
New icons have been added to indicate the type of activity, including Atomic (system), Atomic, Workflow (system), Workflow, and plain activities.
Icon |
Description |
| Built-in activities that serve as building blocks and individual functions you can add to a workflow. For more information, see Activities | |
Atomics actions are small, self-contained workflows. For more information, see Atomic Actions. |
Cisco-managed atomics are reusable workflow components maintained by Cisco to simplify and standardize automation across Cisco platforms. For more information, see Atomic Actions. |
Specify multiple paths for your workflow based on a series of one or more conditions. For more information, see Logic Activities - Condition Block. |
Logic activities allow you to perform actions such as creating loops, setting conditions for branching, and choosing specific start and endpoints in a workflow. For more information, see Logic Activities. |
A loop is a control structure in Automation that repeats a set of activities—using For Each (per array item), While Loop (while a condition is true), Break (exit loop), and Continue (skip to next iteration or continue after a failure). For more information, see Logic Activities. |
| Workflows allow you to automate responses and eliminate repetitive tasks, using activities, logic, and even other workflows to communicate with other systems and resources. | |
Tasks enable your workflows to ask for user input before taking an action. For more information, see Tasks. |
Automation can use Java Database Connectivity (JDBC) API calls to update database tables on a remote database server. You can also use database tables as the data source for a For Each Loop to iterate through each row in the table. For more information, see Database. |
Tables allow you to store structured in tables that are similar to a spreadsheet. For more information, see Table activities. |
File operations. Workflows are mostly limited to downloading files from a remote source and uploading files to a remote destination. For more information, see File Operations. |
Execute scripts from a defined list of Python functions. For more information, see Python. |
