Workflow Editor
Workflow Editor
Click New Workflow or on an existing workflow to open the Workflow Editor, a drag-and-drop editor that enables you to build simple to complex workflows.
The Workflow Editor is comprised of three sections:
- Activities - This (left) panel contains the building blocks and individual functions you can add to a workflow. Activities include actions based on API calls to your integrated products, logic components, and other workflows.
You can now use the Show only user-managed option to switch between viewing all assets and viewing only the items you’ve created, such as activities, atomics, and workflows.
- Workflow Canvas - This (middle) panel is where you build the structure and set the actions, order, and logic for a workflow. Drag and drop items from the Activities panel to here to add them to a workflow. You can drag and drop items on the canvas to change their location and order in the workflow.
- Properties - This (right) panel includes the properties of the workflow itself as well as those for each activity on the Workflow Canvas.
Activities
This toolbox contains objects that you can add to a workflow to provide functionality.
The Activities panel includes three sections:
- Activities - Built-in and third-party functions that you can use to perform actions. Expand the various sections and then drag and drop the actions you want to use in your workflow. See the Activities Help topic for more information.
- Logic - Logic components add flexibility and branching to your workflows by allowing you to add elements such as groups, conditions, and loops. See the Logic Activities Help topic for more information.
- Workflows - You can add other existing workflows as child objects to nest within your parent workflow. This allows you to create smaller, targeted workflows that you can then incorporate and piece together as needed to achieve more complex objectives.
Activities Panel Subcategories
The Activities panel in the Workflow Editor now supports a two-level hierarchy — groups and subgroups. Related atomics and activities within a group can be organized into nested, collapsible subgroups for easier navigation.
The categorization options are:
Groups — top-level collapsible sections (e.g., "ServiceNow")
Subgroups — nested collapsible sections within a group (e.g., "Change Requests")
Atomics without a subgroup remain directly under the group
Creating an Atomic Workflow with a Subgroup
In the Workflow Editor, create a new workflow or edit an existing one.
Enable Designate as Atomic Workflow in the workflow properties.
Set the following fields:
| Field | Required | Description | Example |
| Activity Group | Yes | The parent group name that appears in the Activities panel | "ServiceNow" |
| Activity Sub-Group | No | The nested subgroup name within the parent group | "Change Requests" |
Save the workflow. The atomic will now appear under the specified group and subgroup in the Activities panel.
Workflow Canvas
The Workflow Canvas is where you construct the workflow using objects from the Activities panel.
Drag and drop each item onto the canvas where you want it to be in the workflow, wherever a green plus icon appears. You can drag each item within the workflow to rearrange the order.
The editor canvas defaults to a compact view with "small" zoom and a collapsed properties drawer, creating a more focused workspace.
Hover over an object on the canvas and click the
(Ellipsis) icon to see its actions menu. Available actions include:
View Workflow Summary - Open a dialog box showing the object name, description, and other information such as variables.
Duplicate - Copy the object and its configured properties.
Delete - Remove the object from your workflow.
Collapse - This option is available only for Logic items and allows you to collapse them for improved canvas organization.
Modify Child Workflow - This option enables you to make changes to the child workflow associated with the selected object.
Properties
The Properties panel is where you define the attributes of the workflow itself and of any activities within the workflow.
You must configure properties for each workflow activity.
Click the activity to see and define its properties.
The required properties will vary depending on the activity.
In addition to the display name (64 character limit), owner, and description (1024 character limit) of the workflow, this area includes options to clean up after the workflow successfully runs, mark the workflow as an atomic, and tag the workflow with a category. For more information, see the Categories Help topic.
Variables
Lists any required values you want to store and share among activities or workflows. For more information, see the Variables Help topic.
Variable references are displayed as pills in the UI fields. The length of text in each pill is reduced by generally concatenating the properties. Hover over a pill to display a tooltip showing its full path of breadcrumbs. For a broken reference, the pill says “Reference not found” and the tooltip on hover shows the full, raw reference link with the underlying data.
Automation Rules
Determine when this workflow is automatically executed and what type(s) of rule this workflow belongs to. For more information, see the Rules Help topic.
- Select one or more rule types from the drop-down list, then when using the variable browser, you can add generic references to variables per rule type, instead of having to do so for each specific rule, adding flexibility to reusing and sharing content. When you create a workflow with generic references, it's easier to reuse the workflow for multiple rules. And when you share a workflow with generic references, it's easier to import it without having to import each specific rule.
- If you want this workflow to start in response to a schedule or when an incident or specific event occurs, click Add Automation Rule. In the resulting dialog box, select the name of the existing (or click Add New) rule, and click Select. Edit the rule as needed, and click Save to add it to the workflow's list of associated automation rules. For more information, see the Automation Rules Help topic.
- When a rule's toggle switch is clicked to on, the association between the rule and this workflow is activated, so that this workflow is enabled to automatically run when the rule conditions are met.
Version
You can use the Workflow Editor to export a workflow to a Git repository for storage. For more information, see the Import and Export a Workflow Help topic.
Exchange
If and when this workflow was published to Exchange, including version number and link to view its details in Exchange. For more information, see the Publish to Exchange Help topic.
Target
Targets and target groups define the systems and resources that the workflow will communicate with or act upon. For more information, see the Targets Help topic.
Credentials
For targets that require authentication, account keys are used. For more information, see the Account Keys Help topic.
Page Header Functions
The header of the Workflow Editor page includes the following options :
- Share -
- Submit to Exchange - Submit the validated workflow for publishing to Exchange,
- Commit to Git - Export the workflow to a Git repository, you must select a Git repository in the properties before you can commit the workflow.
- Export as JSON - Export the workflow as a JSON file; copy the resulting JSON to your clipboard, or save it to a local file.
- View Runs - View the execution data for the workflow on the Runs page.
- Validate - Check that a workflow and activities have all of the necessary properties defined in order to run successfully.
- Run - Perform a single execution of the workflow.
- Settings - Modify the settings for the Workflow Editor; you can hide the Activities or Properties panels, select whether or not to receive a confirmation dialog when you delete activities or unlock a workflow, collapse property sections, show inline suggestions.
Unlocked - The workflow is currently unlocked and can be edited. To lock it and thereby prevent changes that could invalidate it, click the Unlock option and provide a message (such as why this workflow is locked) in the Lock dialog box, and click Save. For example, "Workflow is being used with one or more automation rules, so editing it may invalidate it and prevent the associated rule(s) from running. Duplicate this workflow before modifying it."
Locked - The locked workflow cannot be edited. Unlock it so that it can be edited, click the option and review the Lock message before deciding whether to click Unlock and edit.
Workflows are automatically locked when:
The workflow is published to Exchange. If you'd like to make changes to the workflow, you can unlock and edit it. Then, you can publish the update to Exchange.
The workflow was installed from Exchange. If you'd like to make changes to the workflow, you can unlock and edit it. However, if you edit the workflow and choose to install an update later, your changes will be overwritten. Consider duplicating the workflow before making changes.
The workflow is used by one or more automation rules. If you'd like to make changes to the workflow, you can unlock and edit it. However, workflows must be in a valid state to be run by automation rules. So while you're editing it, the workflow is invalid and will not be executed by any automation rules. Consider duplicating the workflow, making your changes to the copy, and then updating the automation rule(s) to use the new version.
The workflow is used by another workflow. If you'd like to make changes to the workflow, you can unlock and edit it. However, workflows must be in a valid state to be run. So while you're editing it, the workflow is invalid, and any workflows using it may not be able to run. Consider duplicating the workflow, making your changes to the copy, and then updating the parent workflow with the new version.
As a user with an Administrator role, you can lock or unlock any workflow in your tenant, whether you're the author or not.
