C8110L-G2-MX Datasheet
Overview
The Cisco C8110L-G2 are enterprise security appliances running MX OS which are designed for distributed deployments requiring remote administration across small to medium branch environments. It is ideal for network administrators who demand both ease of deployment and a state-of-the-art feature set.
The Cisco C8110L-G2 are designed to securely extend the power of cloud managed networking to almost any location by providing two dedicated WAN ports. This device offers four LAN Gigabit Ethernet ports.
Key Features
Software Features
Hardware Features
1 x 1 Gigabit RJ45 Ethernet ports dedicated for WAN uplinks
1x 1 Gigabit RJ45 Ethernet ports LAN/WAN convertible
3 x 1 Gigabit RJ45 Ethernet LAN ports
Models
C8110L-G2 |
# of WAN Uplinks |
2 |
Stateful Firewall Throughput |
1 Gbps |
Maximum VPN Throughput |
750 Mbps |
Advanced Security Throughput |
500 Mbps |
Recommended use case |
Up to 50 devices |
Technical Specifications
WAN Interfaces
C8110L-G2 |
1x Dedicated GbE RJ45 |
| 1x WAN/LAN convertible (Default to WAN) |
LAN Interface
C8110L-G2 |
3x Dedicated GbE RJ45 |
Performance Specifications
C8110L-G2 |
Recommended Use Case |
Up to 50 devices |
Max Stateful Firewall Throughput in NAT mode |
1 Gbps |
Max VPN Throughput |
750 Mbps |
Physical Specifications
C8110L-G2 |
Mount Type |
Desktop / Wall Mount |
Dimensions (h x d x w) |
1.1 x 5.7 x 10.2 in / 29 x 144 x 261 mm |
Weight |
1.6 lbs / 0.76 kg |
Power Supply |
30W DC (12V 2.5A) |
System Power (idle/max) |
6 / 13 W |
Operating Temperature |
32°F - 113°F 0°C - 45°C |
Storage and Transportation Temperature |
-4°F - 158°F -20°C - 70° C |
Humidity |
5% to 95% |
Regulatory and Certifications
Ordering Information
Model SKU |
Description |
C8110L-G2-MX |
Cisco C8110L-G2 Cloud Managed Secure Router |
Package Contents
- C8110L-G2
- Power Adapter
- [Optional] Power cord
Accessories
Accessory |
Description |
PWR-CC1-30WACIC |
C8110L-G2 Replacement Power Adapter (C8111-G2) (30 Watts AC) |
CAB-AC |
1x AC Power Cable, US plug |
CAB-ACE |
1x AC Power Cable, EU plug |
CAB-ACU |
1x AC Power Cable, UK plug |
CAB-ACA |
1x AC Power Cable, AU plug |
Additional Resources
Configure your Dashboard Network
The following is a brief overview only of the steps required to add an C8110L-G2 to your network. For detailed instructions about creating, configuring and managing Meraki networks, refer to our Managing Dashboard Networks document. Additional resources can also be found via: documentation.meraki.com.
Login to http://dashboard.meraki.com. If this is your first time, create a new account.
Find the network to which you plan to add your C8110L-G2 or create a new network.
Add your C8110L-G2 to your network. You will need your Meraki order number (found on your invoice) or the serial number of each C8110L-G2 which looks like Qxxx-xxxx-xxxx, and is found on the bottom of the unit. If a license key was purchased at the same time then you should have received it via email.
Go to the map / floor plan view and place each C8110L-G2 on the map by clicking and dragging it to the location where you plan to mount it.
Troubleshooting
Common Event Log Messages
Common event logs exist for wired events. As such, no specific C8110L-G2 event log entries are required at this time.
For more general information about navigating the Event Log and the types of Events that could be expected please check out our Event Log documentation.
Warranty
Cisco Secure Router warranty coverage periods are as follows:
Product |
Warranty Period |
Warranty Information |
C8110L-G2 |
2 Years |
C8110L-G2 Accessories |
1 Year |
The following are considered accessories: SFP Modules, all mounting kits and stands, interface modules, additional power cords |
Additional warranty information can be found on the Return Policy and Requesting a RMA page of the Cisco website.
If your Cisco Meraki device fails and the problem cannot be resolved by troubleshooting, contact support to address the issue. Once support determines that the device is in a failed state, they can process an RMA and send out a replacement device free of charge. In most circumstances, the RMA will include a pre-paid shipping label so the faulty equipment can be returned.
In order to initiate a hardware replacement for non-functioning hardware that is under warranty, you must have access to the original packaging the hardware was shipped in. The original hardware packaging includes device serial number and order information, and may be required for return shipping.
Cisco Secure Routers C8110L-G2 devices have been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation.
