Custom Network Enrollment Strings
Overview
A network enrollment string allows end users to access their organization’s enrollment portal (m.meraki.com) or self-service portal (portal.meraki.com) using a known and recognizable network identifier. Network enrollment strings are unique to each Systems Manager network and can be used as a substitute for the randomly-generated 10-digit network ID.
Network enrollment strings are case insensitive and must follow these guidelines:
- Must be 4 or more characters in length
- Cannot exceed 50 characters in length
- Cannot include any of the following characters: ;:@=&$!‘“,?.(){}[]\*+/#<>|^%
- Cannot be a 10 digit string
- Cannot follow the format XXX-XXX-XXXX where X represents a digit
Configure a Network Enrollment String
Navigate to Network-wide > Configure > General
Enter the desired string into the “Network enrollment string” field
Click Save in the bottom right corner to save changes.
If Systems Manager is a part of a combined network, then "-sm" is automatically appended to the end of the network enrollment string.
Change a Network Enrollment String
Change the desired string in the “Network enrollment string” field
Changing a network enrollment string may cause existing bookmarks or links to break. Please be sure to review all internal documentation and references before editing a network enrollment string to prevent adverse impact to existing workflows.
Once enabled, a network enrollment strings can be changed but they cannot be deleted.
