Catalyst 9300X-M Datasheet
Overview
The Catalyst 9300X-M addresses the most demanding enterprise applications by combining the simplicity of the Meraki dashboard with powerful switching hardware. To satisfy high-bandwidth applications and the deployment of high-speed wifi access points, the Catalyst 9300X-M provides multigigabit ports, 1TB stacking, and modular 10/25 or 40/100G uplinks. The Catalyst 9300X-M delivers resiliency with fast stack convergence and StackPower. The Catalyst 9300X-M provides Adaptive Policy using an over-the-wire tag which segments traffic into security groups to deliver scalable security. The Catalyst 9300X-M is integrated under the Meraki dashboard to provide a simply powerful solution to the most demanding wired access applications.
Adaptive Policy provides simple & scalable security policies to segment traffic using Security Groups. Security Groups are created in the dashboard using natural language such as “IOT device” & “Guest.” The security policy intent (e.g., Permit or Deny) is then simply provisioned between Security Groups which results in the segmentation of each group’s traffic. By making security policy management intuitive and scalable relative to legacy IP-address based Access Control Lists, Adaptive Policy empowers operators to confidently secure their network traffic independent of future network changes.
By pooling & distributing power across C9300X-Ms using a series of StackPower cables, StackPower provides simple and resilient power distribution across the stack.
C9300X-24Y-M
C9300X-48TX-M
A Catalyst 9300X switch can also be migrated to a Meraki-managed persona, where it would function as its Catalyst Meraki 9300X equivalent. For details on the migration process, please refer to our Getting started: Cisco Catalyst 9300 with Meraki Dashboard guide.
Models
| Number of Ports | Model | Description |
| 12 Ports | C9300X-12Y-M | 12-port SFP28 Fiber switch |
24 Ports |
C9300X-24Y-M | 24-port SFP28 Fiber switch |
| C9300X-24HX-M | 24-port mGig UPoE+ switch (24 x 10G mGig) | |
48 Ports |
C9300X-48TX-M | 48-port mGig switch (48 x 10G mGig) |
| C9300X-48HX-M | 48-port mGig UPoE+ switch (48 x 10G mGig) | |
| C9300X-48HXN-M | 48-port mGig UPoE+ switch (8 x 10G mGig + 40 x 5G mGig) |
Features
| Category | Features |
| Highlights |
| Management |
| Remote Diagnostics |
| Stacking |
| Ethernet Switching Capabilities |
| Layer 3 |
| Security |
* Available in a future software release
Catalyst 9300/L/X-M Licensing
The Catalyst 9300-M license applies to all c9300 hardware platforms (c9300 / c9300L / c9300X) excluding the MS390. Catalyst 9300-M license structure includes two feature tiers: Enterprise and Advanced. As with all Meraki managed switches, every Catalyst 9300-M license is available in 1, 3, 5, 7, and 10 year terms.
| Catalyst 9300X-M License Structure | 12/24-Port | 48-port |
| Advanced Features | LIC-C9300-24A | LIC-C9300-48A |
| Enterprise Features | LIC-C9300-24E | LIC-C9300-48E |
The features available with advanced licensing are:
In the Co-term licensing model (most existing Organizations), an Organization must either have all Catalyst 9300/L/X-M Enterprise or all Catalyst 9300/L/X-M Advanced licenses - they cannot be mixed. In the Per-device licensing model, a mix of Enterprise and Advanced can be added to a single Organization, but certain features may require all devices in a Network to have Advanced licenses, e.g. Adaptive Policy.
Additional Information: MS390s existing in the same co-term Organization will require the same license edition (either Enterprise or Advanced) as the Catalyst 9300/L/X-M. License types cannot be mixed and will result in an incompatible license error.
In a co-term license Organization - MS130, MS150, MS390, C9300 require the same license tier (either Enterprise of Advanced) across the entire Organization.
For example, if an organization has existing MS390/C9300/MS150/MS130 with enterprise licenses, they cannot add C9300's with advanced licenses in that organization - they must be added with enterprise licenses.
If the organization has existing MS390/C9300/MS150/MS130 with advanced licenses, they cannot add C9300's with enterprise licenses in that organization - they must be added with advanced licenses.
For more information on licensing, refer to Meraki Licensing Models article.
Subscription licensing is also available for the Catalyst 9300-M switches
Technical Breakdown
Interfaces Specifications
| Model/Persona | Interfaces |
Uplinks (SFP+, SFP28, QSFP+, QSFP28) |
1T/480G Hardware Stack Ports |
Dedicated Management Interface |
PoE/ UPoE Capabilities |
| C9300X-12Y-M | 12 x 1/10/25G SFP28 Fiber | Modular | 2 | 1 | n/a |
| C9300X-24Y-M | 24 x 1/10/25G SFP28 Fiber | Modular | 2 | 1 | n/a |
| C9300X-24HX-M | 24 x mGig UPoE+ RJ45 24 x 10G mGig |
Modular | 2 | 1 | UPoE+ |
| C9300X-48TX-M | 48 x 10G mGig RJ45 | Modular | 2 | 1 | n/a |
| C9300X-48HX-M | 48 x mGig UPoE+ RJ45 48 x 10G mGig |
| C9300X-48HXN-M | 48 x mGig UPoE+ RJ45 8 x 10G mGig + 40 x 5G mGig |
All models are available with modular uplinks that have been listed under the Accessories list. For supported SFP modules please refer the SFP Datasheet.
Cabling Best Practices for Multi-Gigabit operations: While Category-5e cables can support multigigabit data rates upto 2.5/5 Gbps, external factors such as noise, alien crosstalk coupled with longer cable/cable bundle lengths can impede reliable link operation. Noise can originate from cable bundling, RFI, cable movement, lightning, power surges and other transient event. It is recommended to use Category-6a cabling for reliable multigigabit operations as it mitigates alien crosstalk by design.
Physical Specifications
| Model |
Dimensions (h x w x d) W/ Default Power Supply |
Weight w/ Default Power Supply |
Mount Type | Hot Swap Fans | Operating Temperature | Humidity |
| C9300X-12Y-M |
1.73” x 17.5” x 19.2” (4.4 x 44.5 x 48.77cm) |
15.0 lb (6.80 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300X-24Y-M |
1.73” x 17.5” x 20.7” (4.4 x 44.5 x 52.6cm) |
16.2 lb (7.35 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300X-24HX-M |
1.73” x 17.5” x 20.63” (4.4 x 44.5 x 52.4cm) |
13.8 lb (6.25 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300X-48TX-M |
1.73” x 17.5” x 22.03” (4.4 x 44.5 x 55.9cm) |
14.6 lb (6.62 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
| C9300X-48HX-M |
| C9300X-48HXN-M |
14.2 lb (6.44 kg) | 1U Rack Mount | Yes, 3x | -5°C to 45°C | 5 to 90% |
Performance
Model |
Switching Capacity | Stacking Bandwidth | Forwarding rate |
| C9300X-12Y-M | 1000 Gbps | 1 Tbps / 480 Gbps | 744.04 Mpps |
| C9300X-24Y-M | 2000 Gbps | 1 Tbps / 480 Gbps | 1488 Mpps |
| C9300X-24HX-M | 880 Gbps | 1 Tbps / 480 Gbps | 327.38 Mpps |
| C9300X-48TX-M | 2000 Gbps | 1 Tbps / 480 Gbps | 1488 Mpps |
| C9300X-48HX-M | 2000 Gbps | 1 Tbps / 480 Gbps | 1488 Mpps |
| C9300X-48HXN-M | 2000 Gbps | 1 Tbps / 480 Gbps | 1488 Mpps |
Power Supply and Specifications
Model |
Default Power Supply | Hot Swap Power Supply | Available PoE W/ Primary PS | Available PoE W/ Secondary PS* |
Power Load (idle/max) |
| C9300X-12Y-M | PWR-C1-715WAC-P-M | Yes, Dual | n/a | n/a | 97.1 / 157.3 W |
| C9300X-24Y-M | PWR-C1-715WAC-P-M | Yes, Dual | n/a | n/a | 139.6 / 243.7 W |
| C9300X-24HX-M | PWR-C1-1100WAC-P-M | Yes, Dual | 735W | 1835W | 127.2 / 912.6 W |
| C9300X-48TX-M | PWR-C1-715WAC-P-M | Yes, Dual | n/a | n/a | 184.3 / 269.8 W |
| C9300X-48HX-M** | PWR-C1-1100WAC-P-M | Yes, Dual | 590W | 1690W | 178.9 / 672 W |
| C9300X-48HXN-M | PWR-C1-1100WAC-P-M | Yes, Dual | 690W | 1790W | 127.2 / 912.6 W |
* The PoE values are provided considering the secondary PS to be the default power supply of the respective model.
** The C9300X-48HX-M switch is hardware limited to 36 ports of 90W UPOE+ max without stack-power. With stack-power the switch is limited to 32 ports of 90W UPOE+.
Note: For Japan, the recommendation is to deploy the switch with 200V+ outlets. The 1100WAC power supplies will not operate on 100V. Please reference Table 13. AC Power Cords for the appropriate 250VAC power cable.
PSU configuration and PoE budgets
Model |
Primary PSU |
PoE |
With Secondary PSU |
w/ 1900W Secondary PSU |
| C9300X-24HX-M | PWR-C1-1100WAC-P-M | 735W | 1835W | 2160W |
| C9300X-48HX-M | PWR-C1-1100WAC-P-M | 590W | 1690W | 2490W |
| C9300X-48HXN-M | PWR-C1-1100WAC-P-M | 690W | 1790W | 2590W |
Package contents
In addition to the MS switch, each shipment includes the following.
- 1 x default power supply unit for the switch model (please refer to the power supply and specifications section)
- Rack mount brackets (rack screws not included)
- 3 x Pre-installed fans.
Optional Accessories
| Accessory | Description | Supported Models |
| PWR-C1-350WAC-P-M | 350W AC Power Supply | C9300, C9300L, C9300X |
| PWR-C1-715WAC-P-M | 715W AC Power Supply | C9300, C9300L, C9300X |
| PWR-C1-1100WAC-P-M | 1100W AC Power Supply | C9300, C9300L, C9300X |
| PWR-C1-1900WAC-P-M | 1900W AC Power Supply (230V)** | C9300, C9300X |
| C9300X-NM-2C-M* | 2 x 40G/100G QSFP28 Uplink Module | C9300X |
| C9300X-NM-8Y-M** | 8 x 1/10G/25G SFP28 Uplink Module | C9300X |
| STACK-T1-50CM-M | Catalyst Meraki 1T Stacking Cable, 0.5 Meter | C9300, C9300X |
| STACK-T1-1M-M | Catalyst Meraki 1T Stacking Cable, 1 Meter | C9300, C9300X |
| STACK-T1-3M-M | Catalyst Meraki 1T Stacking Cable, 3 Meter | C9300, C9300X |
| CAB-SPWR-30CM-M | Catalyst 9300/X-M 30CM StackPower Cable | C9300, C9300X |
| CAB-SPWR-150CM-M | Catalyst 9300/X-M 150CM StackPower Cable | C9300, C9300X |
| FAN-T2-M | System Fan | C9300, C9300X |
| 4PT-KIT-T2-M | Catalyst 9300-M Rack Mount Kit | C9300, C9300X |
Please refer to power supply models for details.
*NOTE: The C9300X-NM-2C-M modules will operate at 40Gbps with software support in CS17 firmware. For 100G operation, IOS-XE 17.15+ is required.
**NOTE: Using the C9300X-NM-8Y on the C9300X-48HXN-M is hardware limited to only supporting ports 1-6 on the uplink module. Ports 7&8 are permanently disabled. For more details see IOS-XE documentation.
***NOTE: The PWR-C1-1900WAC-P-M provides 1900 W output power when the nominal input voltage is 230 V. If the nominal input voltage is 115 V, then the output power is limited to 1500 W. The power supply does not work with standard 125VAC power cords(common with 1100W and lower power supplies), you require a C21 power cable like the North American(C9K-PWR-CAB-AC-US). Also a good option is the universal C20-C21 jumper cable(C9K-PWR-CAB-AC-BL), suitable for Rack PDUs . See Table 2 for all suitable worldwide power cord options. Please note there are no -M versions of these cables, they must be ordered with the Cisco SKU.
SFP Modules
The following SFP/Fiber transceivers are supported. For detailed SFP specifications, refer to the Meraki SFP datasheet.
For information about Cisco Optics compatibility, please click here
| Transceiver Model | Standard | Supported C9300-M platform |
1 Gbps MA-SFP-1GB-SX MA-SFP-1GB-LX10
1000BASE-SX over OM1/2/3/4 up to distances of 1KM 1000BASE-LX10 over OS1/0S2 up to distances of 10KM
10 Gbps MA-SFP-10GB-SR MA-SFP-10GB-LR MA-SFP-10GB-ER MA-SFP-10GB-ZR |
10GBASE-SR over OM1/2/3/4 up to distances of 400 M 10GBASE-LR over OS1/2 up to distances of 10 KM 10GBASE-ER over OS1/2 up to distances of 40 KM 10GBASE-ZR over OS1/2 up to distances of 80 KM |
MA-SFP-10GB-LRM |
10GBASE-LRM over OM1/2/3, OS1/2 up to distances of 300 M Not supported on C9300X |
C9300, C9300L only |
40 Gbps MA-QSFP-40G-CSR4 |
QSFP-MPO12 over OM2/3/4 up to distances of 400 M
C9300 |
40 Gbps MA-QSFP-40G-SR-BD |
QSFP Duplex LC over OM2/3/4 up to distances of 150 M |
C9300, C9300X |
100 Gbps MA-QSFP-100G-LR4 MA-QSFP-100G-SR4 |
100GBASE-LR4 over OS1/2 up to distances of 10 KM 100GBASE-SR4 over OM3/4/5 up to distances of 100 M |
NOTE: Catalyst 9300X switches do not support LRM modules.
Regulations and Compliance
Electromagnetic Compatibility Certifications |
FCC Part 15 (CFR 47) Class A, ICES-003 Class A, CISPR22 Class A, CNS13438, EN 300 386 V1.6.1, EN 55022 Class A, EN 61000-3-2, EN61000-3-3, KN 32, TCVN 7189 Class A, EN 55032 , CISPR 32 Class A, V-2/2015.04, V-3/2015.04, VCCI-CISPR 32 Class A, CISPR24, EN 300 386 V1.6.1, EN 55024, KN35, TCVN 7317 |
| Safety |
CAN/CSA-C22.2 No. 60950-1, UL 60950-1, EN 60950-1, IEC 60950-1, AS/NZS 60950.1 |
| Environmental | Reduction of Hazardous Substances (RoHS) |
| Warranty | Full lifetime hardware warranty with next-day advanced replacement included |
MTBF Rating
Model |
MTBF at 25°C |
| C9300X-12Y-M |
265,650 |
| C9300X-24Y-M |
249,350 |
| C9300X-24HX-M |
220,250 |
| C9300X-48TX-M |
206,480 |
| C9300X-48HX-M |
185,420 |
| C9300X-48HXN-M |
188,200 |
Installation Guide
For instructions on how to install and configure the C9300X series switch please refer the C9300/L/X Series Installation Guide
