How to Use Tags to Manage MR Access Points
Click 日本語 for Japanese
Overview
Tags help with basic management of your access points. You can also use them to partition the wireless network into both physical or security-based segments. This article explains how to tag one or more access points and use the tags for these management purposes:
  • Marking access points with tags
  • Organizing a wireless network with many access points
  • VLAN tagging on specific access points
Use tags to organize a wireless network
Tags help you organize your Meraki network and separate your devices from one another based on many different variables.
For example, a university network might have access points in dorms, dining halls, and classrooms. You can tag each access point with the appropriate label. You can then run searches and reports based on those tags, such as showing all access points that have the tag "dining_hall."
Cisco Meraki also supports multiple tags on a single access point. Continuing the example above, you could also use the tags "ceiling_mount" and "wall_mount." You could then search for all ceiling-mounted dining hall access points.
Prerequisites
To apply VLAN tags by access point tag, the SSID must not use Meraki DHCP (NAT mode). VLAN tagging is not available in this mode. For more information on VLAN tagging, refer to the article on Vlan Tagging on MR Access Points or the VLAN tagging section of the product manual.
Step-by-step instructions
Tag access points
Before you tag access points that broadcast 802.1X SSIDs, go to the Troubleshooting section to understand the impact on connected clients.
  1. In dashboard, navigate to Wireless > Monitor > Access points.
  1. Select the check box for each access point you want to tag.
  1. Select Edit > Tag.
Screenshot shows how to add/remove AP Tags on the Meraki Dashboard UI
  1. Enter a new tag for the access points, or select an existing tag. Tags are case sensitive. Do not use multiple capitalization variants of the same tag. Use a unique tag for each use case. If you need similar tags, add a hyphen or number, such as West1 or Wes-t.
  1. Repeat step 4 for each tag you want to assign.
Screenshot shows how to add VLAN ID Tags to tagged AP's on the Wireless -> Access control page of the Meraki Dashboard UI
Apply VLAN tags to traffic on specific access points
You can tag client traffic that passes through specific access points with a particular VLAN.
  1. In dashboard, navigate to Wireless > Configure > Access control.
  1. Select the target SSID from the SSID drop-down menu.
  1. Scroll down to the Client IP and VLAN section.
  1. Under VLAN Tagging, select VLAN ID if it is not already enabled.
  1. Select + Add VLAN ID.
  1. Enter the access point tags and the VLAN ID you want to use.
  1. Select Save Changes.
Verification
  • Access point tags: Dashboard assigns the tags to the selected access points. To confirm, search or run a report by tag. For example, search for the tag "dining_hall" to show all access points that have that tag.
  • VLAN tagging: On the configured SSID, dashboard tags all client traffic that passes through an access point with the entered tags with the specified VLAN ID.
Troubleshooting
Clients disconnect after you add or remove a tag
Adding a tag to an access point, or removing one, restarts the SSIDs on that access point if they are configured to use 802.1X with my RADIUS. Clients connected to those SSIDs disconnect. Non-802.1X SSIDs are not affected.
