How to Restrict Wireless Access by MAC Address Using a Sign-on Splash Page
Click 日本語 for Japanese
Overview
This article explains how to restrict wireless access to specific client devices by MAC address using a sign-on splash page.
MAC-based authentication restricts wireless access to specific client devices. It traditionally requires a RADIUS server. For smaller deployments, a sign-on splash page is an easier way to configure MAC-based authentication.
To set up this configuration, complete these tasks in order:
Configure a sign-on splash page with Meraki Authentication.
Set the captive portal to block all traffic until sign-on is complete.
Add known client devices to the allow list.
Add unknown client devices to the allow list by MAC address.
Devices on the allow list bypass the splash page. All other devices are blocked by a splash page they do not have credentials for.
Prerequisites
The SSID must not use WPA2-Enterprise encryption. Do not combine a Meraki Authentication sign-on splash page with WPA2-Enterprise encryption. Dashboard displays an error if you attempt this configuration.
To add a device that has not connected to the SSID, you need its MAC address. Refer to Finding the MAC address of a Windows or Mac computer.
Step-by-step instructions
A sign-on splash page with Meraki Authentication requires users to enter a username and password to access the network. You manage these credentials from Network-wide > Users.
Navigate to Wireless > Access control.
Under Splash page, select Sign-on with Meraki Authentication.
Block all traffic until sign-on is complete
By default, the splash page allows unauthenticated users to pass non-HTTP traffic. To prevent this traffic, change the captive portal strength:
On Wireless > Access control, locate the Captive portal strength setting.
Select Block all access until sign-on is complete.
Add known clients to the allow list
Devices on the allow list bypass the splash page requirement. To add a device that has already connected to the network:
Navigate to Network-wide > Clients.
Find the device in the client list.
Select the check box to the left of the device name.
From the Apply policy drop-down, select the allow list option.
For more information, refer to adding clients to the allow list or block list.
As an alternative way to bypass the splash page, Apply custom group policies to specific client devices.
Add unknown clients to the allow list
If a device needs allow-list access but has not yet connected to the SSID, add it manually by MAC address:
Select Add clients on the right side of the page.
Add the device to the clients list by its MAC address.
Add the client to the allow list.
For more detailed instructions, see Pre-Configure Network Policy for Client Devices. See Finding the MAC address of a Windows or Mac computer for instructions on locating a machine's MAC address.
Verification
Confirm the configuration works as expected:
Connect a device on the allow list to the SSID. The device bypasses the splash page entirely and connects to the network.
Connect a device that is not on the allow list to the SSID. The splash page appears and prompts for credentials. The user cannot access the network without them.
