Home > General Administration > Tools and Troubleshooting > Networking fundamentals: Subnetting
Subnetting is the process of breaking a network into multiple logical sub-networks. An IPv4 address is comprised of four octets of eight bits or thirty-two bits total. Each octet is converted to decimal and separated by a dot for example: 11111111.11111111.11111111.00000000 = 255.255.255.0
The Subnet Mask allows the host to compute the range of the network it's a part of, from network address to broadcast address.
A device with an IP address of 192.168.1.5 with a subnet mask of 255.255.255.128 knows that the Network address is 192.168.1.0 and the Broadcast Address is 192.168.1.127.
Each place in the octet string represents a value:
128  64    32    16      8       4       2       1
  1     1      1      1       1       1       1       1
When added together (128+64+32+16+8+4+2+1) = 255.
Network Class Ranges
Depending on what value is used, an IP represents a different class of network:
cc0d30f9-421c-4f69-b97d-d71e15ae1b5e
Most LAN networks use private IP addresses outlined here:
5e41a72b-d028-4968-98de-6f7391021bd1
These addresses cannot be routed on the public Internet, but that is why the edge of the network will typically be using NAT (Network Address Translation) to translate the private IP addresses to public addresses. Using subnetting, one can split these private IP addresses to fit as many hosts as needed depending on the subnet mask that is used. The subnet mask divides the network portion (network bits) of the address from the host portion (host bits).
Typical Private Range Masks
 (Blue: Network bits, Green: Host bits.)
Class A: 255.0.0.0
11111111.00000000.00000000.00000000
[-network-].[-----------------host---------------]
Class B: 255.255.0.0
   11111111.11111111.00000000.00000000
[-------network--------].[---------host------------]
Class C: 255.255.255.0
[--------------network---------------].[---host---]
Cisco Meraki allows users to input subnet masks using CIDR notation which is an easier method of appending a subnet mask. If the subnet mask being used in a Class C network is 255.255.255.240, the CIDR notation would be /28 because the network portion (below in blue font) of the mask borrowed four bits from the host portion (red). The borrowed bits are in blue:
255.255.255.240 =11111111.11111111.11111111.11110000
Network Example
The Cisco Meraki MX appliance allows the administrator to configure subnets to their corresponding VLANs at Configure > Addressing & VLANs. Using VLANs help to logically separate subnet segments minimizing broadcast domains. For help setting up VLANs on the MX, please see here. VLANs will need to be recognized downstream on the LAN (The switch). The MX can handle routing between these VLANs (Inter-VALN Routing )so that different VLANs can still communicate if needed.
An example of VLANs with their corresponding Subnets and the IP on the MX that those VLANs point to:
59e94aad-ceea-4094-aabc-a903c81739cb
Below is an example of Per-Port VLAN configuration.
584122bb-227e-49a2-826e-fc1fb29248ad
Below is a network diagram to help outline the above configuration:
57a5f6b9-7795-49bb-8646-00f18246558d
Last modified
Tags
Classifications
Explore the Product
Click to Learn More
Article ID
Explore Meraki
Explore Meraki
Contact Support
Open a Case
Ask the Community
Visit the Community
