Guidance for Cleaning/Decontaminating Cisco Meraki Hardware
This article addresses details about how to properly clean / decontaminate Cisco Meraki Hardware.
Guidance for MX and MS
- A simple wipe down with an antibacterial wipe is recommended
- Alcohol and alcohol wipes are acceptable too
- Do not allow liquids inside the vents
Guidance for MR and MG
- Hot soapy water is also safe, but avoid getting the cable ports wet
Guidance for MV
The domes are made of polycarbonate material and have a hard coating, making it UL-746C compliant.
How are MV Cameras recommended to be cleaned? Follow the 4 guidelines below.
While cleaning, make sure you are only using a clean, dust-free cloth (chamois, microfiber cloth, optical cloth are all okay). Do not use chemical wipes as the material on these wipes typically leave streaks.
As for the disinfectant liquid, we recommend water and dish soap. Isopropyl alcohol is also okay. Do not use any harsh cleaning liquid.
Ensure you do not apply too much pressure on the dome while cleaning.
2 minutes of cleaning a day should be no problem.
Can all MV camera domes be cleaned the same way? Yes
Image quality does not look great, what can I do?
