Resetting Cisco Meraki Devices to Factory Defaults
Click 日本語 for Japanese
Overview
Cisco Meraki devices can be reset to factory defaults using the reset button on the device. This requires a paper clip or object with a long thin tip. Insert the tip of the paper clip into the reset button, then press and hold for 10-20 seconds or until the power light goes out (whichever occurs first). This will reset the device to factory defaults and reboot. If a static IP address was configured for the device, it will need to be configured again using the local status page.
Resetting a Meraki appliance to factory defaults will clear the local configuration stored on that appliance. This will clear any statically assigned IP address information, Ethernet configuration, DHCP lease pool, and web proxy settings.
If a device is still in a network after being factory reset, it will re-download its previous configuration when it comes back online. This includes any previously assigned static IP addresses. If the configuration needs to be completely reset, make sure to remove the device from its network before resetting to factory defaults (you may follow Adding and Removing Devices from Dashboard Networks
Before attempting a factory reset, it's recommended that you wait until after the status light has started cycling colors. This will ensure the device has finished booting and is prepared to accept the factory reset.
Rack-Mounted Security Appliance
To reset a rack-mounted security appliance to the factory defaults, press the button labeled Reset on the front panel of the security appliance for 10-20 seconds. This will clear the static IP address settings, DHCP lease pool, and local configuration of the device. After resetting the unit, the device will need to download its latest configuration from the dashboard. Please be patient as this could take up to 5-10 minutes.
To reconfigure a static IP address on a security appliance, please follow the instructions in Using the Cisco Meraki Device Status Page article.
Reset button of the rack-mounted MX security appliance - located on the front panel next to the USB port
Compact MX Security Appliance and Z-Series Teleworker Gateway
To reset a compact (non-rack-mounted) security appliance or teleworker gateway to the factory defaults, press the button labeled Reset on the back panel of the security appliance for 10-20 seconds. This will clear the static IP address settings, DHCP lease pool, and local configuration of the device. After resetting the unit, the device will need to download its latest configuration from the dashboard. Please be patient as this could take up to 5-10 minutes.
Reset button of a compact MX or Z-Series appliance -  located on the back panel next to the USB port
The reset button on different security appliances or Teleworker gateway appliances may have different indicators/words such as "Reset," "Restore," or simply a circular arrow icon. There is only ever one hole for a factory reset on these appliances, regardless of the label.
"Restore" label used instead of "Reset" on an MX or Z-Series appliance
On some security appliances, the reset button is located on the side of the unit (next to the USB port) and labeled with a circular arrow:
Circular arrow label used instead of "Reset" on an MX or Z-Series appliance
MX84
On the MX84, the reset button is located on the back of the unit, and labeled with a circular arrow:
Circular arrow label used instead of "Reset" on the MX84 appliance
MS Access Switches
To reset a switch to the factory defaults, press the button labeled Reset or Restore on the front panel of the switch for 10-20 seconds. Be sure to release the button after 10-20 seconds or when power light goes out (whichever occurs first). This will clear the static IP address settings and local configuration of the device. After resetting the unit, the device will need to download its latest configuration from the dashboard. Please be patient as this could take up to 5-10 minutes.
Note: Holding the reset button after the switch reboots will place it in factory test mode. If this has occurred, reboot the device to return it to normal behavior.
Reset button of an MS switch located on the front panel next to port 2
On MS420 series switches, the Restore button will be located on the right side of the switch, adjacent to the Small-Form Factor Pluggable (SFP) ports.
Reset button on the MS420 switch is located on the front-right side of the switch - next to management port
For diagrams indicating the location of the reset/restore button, view the MS Installation Guides articles.
For information about configuring a static IP address on the switch, view the MS Quick Start Guide.
MS350 Series Switch
On the MS350 series switches, the reset button is located on the back of the unit, labeled with a circular arrow:
Circular arrow reset button on MS350 switch - located on the back-left panel near the management port
Catalyst Series Switches (MS390, C9300/X/L)
To reset Catalyst MS390/C9K Switches:
  1. While the switch is powered on
  2. Hold reset pin(MS390) or mode-button(C9300/X/L) and release to perform the below reset options
    • C9300/X/L also have a backup reset pin on the rear of the switch below and to the left of the console port
Reset option Reset pin hold time LED Scheme
Level 1 Reset
Reset button pressed for >=1s and <8s
short .5sec on/off  cycle
Level 2 Reset
(Day0 Config, Keep FW Image)
Reset button pressed for >=8s and <20s ".-.-"
short,long alternating cycle
Level 3 Reset
(Factory Reset, Day0 Config)
Reset Button preseed for >= 20s "----"
long 3sec on/off  cycle
MS390 Front Panel
Meraki Stage and LED Behavior
Blue beacon LED behavior
Off
Pre-IOS stages
Flashing / Blinking blue
System is ready to initialize the Meraki subsystem  (IOS has completely booted)
Solid Blue
Meraki subsystem is up and functional
Meraki Stage and LED Scheme for MS390 and CAT9K
SN #
Meraki Stage
MS390
CAT9K
Technical
Description
Software Naming
Rainbow LED
Beacon LED
  System LED
1
Switch is powered off or not receiving power.
Off
Off
Off
2
Switch if powered on and is loading the bootstrap firmware.
Solid Amber
Solid Amber
3
Switch is loading the operating system.
Blinking Green
Blinking Green
4
System error: Switch failed to load operating system or bootstrap firmware.
Blinking Amber
Blinking amber
5
Setting up local management and cloud-connectivity requirements.
Note: If the switch has not been assigned a static management IP previously, it will try to obtain an IP via DHCP in this stage.
Cycling through different colors
Blinking Blue
Blinking Green
UAC is down and trying to find uplink
CONNECTION_IN_PROGRESS
6
System error: Switch failed to complete local provisioning.
Solid Amber
Solid Amber
UAC is up but nextunnel config fetch is failing
MERAKI_PROC_FAILURE
7
Switch is completely provisioned but unable to connect to Meraki cloud.
Solid Amber
Solid Blue
Solid Amber
UAC is up, nextunnel config fetch done, trying to establish nextunnel or nextunnel down
NO_CONNECTION
8
Firmware download / upgrade in progress
Blinking white
Blinking Green
One shot install or install add/commit/activate operation is in progress
UPGRADING
9
There is a fault with the power supply, fan, or network module (not traffic-related)
Alternately blinking Amber & White
Blinking Amber
Not supported, will be supported later
(not available in Aurora-MVP as well)
FAN_PS_NM_FAILURE
10
Switch is fully operational and connected to the Meraki cloud
Solid White
Solid Green
Nextunnel Established/Up
CLOUD_CONNECTION_UP
Stack-Jumping Recovery Process
NOTES:
Can only be done on similar switches.
  • MS390 only stacks with other MS390s all models
  • C9300 and C9300X can stack with each other
  • C9300L can only stack with C9300L (requires stacking kit)
  • C9200L can only stack with C9200L (requires stacking kit)
Software Requirements
  • Mode must be in the same mode (CLI/DNA mode or Cloud-Managed)
  • Cloud-managed must be the same 'generation' of code (CS firmware or Cloud-Native IOS-XE)
clipboard_e8d0effd15376195ee2c5c74e8a469e40.pngclipboard_e4122ed0b4a0476c18436f9d95e4ab74f.png
STEPS
  1. Connect stacking cable between unpowered 'bad' switch and powered good switch  (STEP 1)
  2. Power on 'bad' switch. The good-switch will be the active member and overwrite the new stack member (STEP 2)
  3. Wait  until stack comes online in dashboard. Now reverse the process to unstack
  4. Power off 'bad' switch, remove stacking cable and delete/remove the stack in dashboard
  5. Power on the recovered 'bad' switch. Wait for it to fully boot/reload
  6. Factory reset the switch before connecting to uplink
CW Access Points
Reset via the Reset button
Note: The device reset process is now unified across Meraki and Catalyst modes.
To reset CW Access Points:
  1. Unplug AP
  2. Hold reset pin
  3. Power on AP
  4. Hold the reset pin to perform the below reset options.
Reset option Reset pin hold time LED status
0. Mode indication
~ 5 sec
  • Blink green = Meraki Mode
  • Blink blue = Catalyst Mode
1. Config reset
> 10 sec Solid white
2. Full reset (maintains management mode)
> 20 seconds Orange
3. FIPS reset (Catalyst mode only)
> 30 seconds Solid red
4. Factory reset (back to global use AP onboarding)
> 60 seconds Solid pink
5. Abort reset
> 90 seconds NA
Note: This reset operation is consistent with traditional Catalyst-managed AP deployments and is now integrated with Meraki-managed AP deployments.
Console output is now available for reference during the reset process.
LED Indicators
MR Or Dashboard Management Mode
Your access point is equipped with a multi-color LED light on the front of the unit to convey information about system functionality and performance:
  • Orange - AP is booting (permanent Orange suggests hardware issue)
  • Rainbow - AP is initializing/scanning
  • Blinking Blue - AP is upgrading
  • Green - AP in Gateway mode with no clients
  • Blue - AP in Gateway mode with clients
  • Blinking Orange - AP can't find uplink
Note: Blinking Green LED indicates that the device is in site survey mode. Please see the Conducting Site Surveys with MR Access Points for more details.
Catalyst Management Mode
  • Green - AP operating normally with no clients
  • Blue - AP operating normally with clients
  • Blinking Green - Boot loader signing verification failure
  • Blinking Green & Red - Discovery or join process in progress
  • Blinking Red, off, Green, off, Blue, off - General warning; insufficient inline power
MR Access Points
Outdoor Access Points
To reset an outdoor Access point (AP) to the factory defaults, press the button labeled Reset below the Ethernet port of the Access point for 10-20 seconds. This will clear the static IP address settings and local configuration of the device. After resetting the unit, the device will need to download its latest configuration from the dashboard. Please be patient as this could take up to 5-10 minutes.
Note: MR58 and OD2 devices do not have a reset button.
The reset button is located in a small pin-sized hole next to the Ethernet port.
Reset button of the outdoor MR access point is located below the Ethernet port
To set up a static IP address on a Cisco Meraki AP, refer to the Static IP Assignment on a Cisco Meraki Access Point article.
MR70, MR78
For these models, the reset button is located next to the Ethernet port, within the cable bay.
Reset button placement for MR70 and MR78 access points
Indoor Access Points
To reset an indoor access point to the factory defaults, press the button labeled Reset for 10-20 seconds. The location of this button varies and is illustrated below. Resetting the unit will clear the static IP address settings and local configuration of the device. After resetting the unit, the device will need to download its latest configuration from the dashboard. Please be patient as this could take up to 5-10 minutes.
The reset button for most indoor models is located adjacent to the power and Ethernet ports on the Access point. Exact location will vary by model.
Reset button of the MR11, MR14, MR18, MR26, MR32, MR33, and MR34 is located next to the Ethernet port.
To set up a static IP address on a Cisco Meraki Access point, visit the article for Static IP Assignment on a Cisco Meraki Access Point.
MR12, MR16, MR24, MR30H, MR36H
For these models, the reset button is located on the rear plate of the AP.
Reset button of the MR 12, MR16, MR24 is located on the back plate.
MV Security Cameras
Each camera model has a different reset button location. After resetting any camera, the device will need to download its latest configuration from the dashboard. Please be patient as this could take up to 5-10 minutes.
Stored video will not be deleted upon doing a factory reset. To delete video, the camera must be removed from the network.
  • [No photo] For the MV21 and the MV71 to factory defaults, press the button located next to the Ethernet port for five seconds,
  • For the MV63 the reset button is under the dome behind the desiccant packet.
  • For the MV93 the reset button is on the rear side.
  • For the MV12 and MV22 turn the optical dome to unlock it from the base.
On the MV12:
Reset button of the MV12 is located beneath the optical dome, along the inner edge.
On the MV22:
Reset button of the MV22 is located beneath the optical dome, along the inner edge.
  • For the MV52, the reset button is the under the top lens hood, towards the rear. Slide the hood of the camera away from the front lens towards the mounting plate, and slide the longer cover under the hood to find the pin hole to factory reset the camera. Note that it may require significant force to slide the plastic hood away from the camera body.
On the MV52:
Reset button of the MV52 is located on beneath the optical dome, above the ball joint.
  • For the MV63 and MV72 you will first need to loosen four Torx head security screws before removing the optical dome.
On the MV72:
Reset button of the MV72 is located beneath the optical dome along the outer edge.
  • For the MV32 the reset button is next to the Ethernet port as in the MV21 and MV71.
On the MV32:
Reset button of the MV32 is located on the back panel near the cutout for the Ethernet cable.
MT Sensors
Factory Reset Button
 MT10, MT11, MT12, MT14, MT20, Mt30
Next to the battery compartment, there is a pinhole button to factory reset the sensor. If the button is pressed and held for at least 5-15 seconds and then released, the sensor will reboot and it will be restored to its original factory settings by deleting all configuration information stored on the unit.
MT15, MT40
On the back of the sensor, there is a sticker with the FCC information and the serial number, here you will find a pinhole button to factory reset the sensor. If the button is pressed and held for at least 5-15 seconds and then released, the sensor will reboot and it will be restored to its original factory settings by deleting all configuration information stored on the unit.
You can also review the installation guide for the respective MT model.
MG Cellular Gateways
For instructions on factory resetting an MG Cellular Gateways, see the installation guide for the respective MG model.
  • Was this article helpful?
