MG Cellular Dipole Antenna Datasheet
The dipole antennas (MA-ANT-C1-A) are included with the MG21E. When in use the dipoles have a spherical coverage in comparison to a patch antenna. The dipole antennas will excel at allowing users to place the MG in areas where a directional patch antenna cannot be mounted. The dipoles are directly attached to the MG21E and require no additional mounting hardware.
Specifications
Category | Specifications |
Electrical |
Antenna Type Dipole |
Main Antenna Frequency Range
Peak Gain (per range)
Polarization Linear, vertical |
Auxiliary Antenna Frequency Range
Physical and Environmental |
Dimensions 129mm x 19.5mm x 12.3mm Material of Radiator PCB Material of Plastic PC Operational Temperature -40°C to +65°C (-40°F to 149°F) Storage Temperature -40°C to +80°C (-40°F to 176°F) Connector RP-SMA (female) |
Warranty | 1 year hardware warranty included |
Ordering Information | MA-ANT-C1-A |
Regulatory |
Certified for use with the MG21E MA-ANT-C1-A |
Radiation Patterns
Main Antenna
1940 (1710 - 2170) MHz
