MR46 Datasheet
High-Performance 802.11ax Wireless
The Cisco Meraki MR46 is a cloud-managed 4x4:4 802.11ax access point that raises the bar for wireless performance and efficiency. Designed for next-generation deployments in offices, schools, hospitals, shops, and hotels, the MR46 offers high throughput, enterprise-grade security, and simple management.
The MR46 provides a maximum of 2.98 Gbps* aggregate frame rate with concurrent 2.4 GHz and 5 GHz radios. A dedicated third radio provides real-time WIDS/WIPS, with automated RF optimization. A fourth integrated radio delivers Bluetooth scanning and beaconing.
With the combination of cloud management, high-performance hardware, multiple radios, and advanced software features, the MR46 makes an outstanding platform for the most demanding of uses—including high-density deployments and bandwidth or performance-intensive applications like voice and high-definition video.
MR46 and Meraki Cloud Management
Management of the MR46 is performed through the Meraki cloud, with an intuitive browser-based interface that enables rapid deployment without time-consuming training or costly certifications. Because the MR46 is self-configuring and managed over the web, it can be deployed at a remote location in a matter of minutes, even without on-site IT staff.
24x7 monitoring via the Meraki cloud delivers real-time alerts if a network encounters problems. Remote diagnostic tools enable immediate troubleshooting over the web so that distributed networks can be managed with a minimum of hassle.
The MR46’s firmware is automatically kept up-to-date via the cloud. New features, bug fixes, and enhancements are delivered seamlessly over the web. This means no manual software updates to download or missing security patches to worry about.
Product Highlights
Features
Dual–radio aggregate frame rate of up to 2.98 Gbps*
The 5 GHz 4x4:4 radio and the 2.4 GHz 4x4:4 radio offer a combined dual-radio aggregate frame rate of 2.98 Gbps*, with up to 2,402 Mbps in the 5 GHz band and 574 Mbps in the 2.4 GHz band. Technologies like transmit beamforming and enhanced receive sensitivity allow the MR46 to support a higher client density than typical enterprise-class access points, resulting in better performance for more clients from each AP.
* Refers to maximum over-the-air data frame rate capability of the radio chipset, and may exceed data rates allowed by IEEE 802.11ax operation.
Multi-user multiple input multiple output (MU-MIMO)
With support for features of 802.11ax, the MR46 offers MU-MIMO and OFDMA for more efficient transmission to multiple clients. Especially suited to environments with numerous mobile devices, MU-MIMO enables multiple clients to receive data simultaneously. This increases the total network performance and improves the end user experience.
Dedicated third radio delivers 24x7 wireless security and RF analytics
The MR46’s dedicated dual-band scanning and security radio continually assesses the environment, characterizing RF interference and containing wireless threats like rogue access points. There’s no need to choose between wireless security, advanced RF analysis, and serving client data. A dedicated third radio means that all functions occur in real time without any impact to client traffic or AP throughput.
Bluetooth Low Energy beacon and scanning radio
An integrated fourth Bluetooth® radio provides seamless deployment of Bluetooth Low Energy beacon functionality and effortless visibility of Bluetooth® devices. The MR46 enables the next generation of location-aware applications while future-proofing deployments, ensuring it’s ready for new customer engagement strategies.
Automatic cloud-based RF optimization
The MR46’s sophisticated and automated RF optimization means there is no need for the dedicated hardware and RF expertise typically required to tune a wireless network. The RF data collected by the dedicated third radio is continuously fed back to the Meraki cloud. This data is then used to automatically tune the channel selection, transmit power, and client connection settings for optimal performance under even the most challenging RF conditions.
Integrated enterprise security and guest access
The MR46 features integrated, easy-to-use security technologies to provide secure connectivity for employees and guests. Advanced security features, such as AES hardware-based encryption and Enterprise authentication with 802.1X and Active Directory integration, provide wired-like security while still being easy to configure. One-click guest isolation provides secure, internet-only access for visitors. PCI compliance reports check network settings against PCI requirements to simplify secure retail deployments.
Enterprise mobility management (EMM) and mobile device management (MDM) integration
Meraki Systems Manager natively integrates with the MR46 to offer automatic, context-aware security. Systems Manager’s self-service enrollment helps to rapidly deploy MDM without installing additional equipment, and then dynamically tie firewall and traffic-shaping policies to client posture.
Application-aware traffic shaping
The MR46 includes an integrated layer 7 packet inspection, classification, and control engine, enabling the configuration of QoS policies based on traffic type, helping to prioritize mission-critical applications while setting limits on recreational traffic like peer-to-peer and video streaming. Policies can be implemented per network, per SSID, per user group, or per individual user for maximum flexibility and control.
Voice and video optimizations
Industry-standard QoS features are built-in and easy to configure. Wireless multimedia (WMM) access categories, 802.1p, and DSCP standards support and ensure important applications get prioritized correctly, not only on the MR46, but on other devices in the network. Unscheduled automatic power save delivery (U-APSD) and new target wait time features in 802.11ax clients ensure minimal battery drain on wireless VoIP phones.
Self-configuring, self-maintaining, always up-to-date
When plugged in, the MR46 automatically connects to the Meraki cloud, downloads its configuration, and joins the appropriate network. If new firmware is required, this is retrieved by the AP and updated automatically. This ensures the network is kept up-to-date with bug fixes, security updates, and new features.
Advanced analytics
Drilling down into the details of network usage provides highly granular traffic analytics. Visibility into the physical world can be enhanced with journey tracking through location analytics. Visitor numbers, dwell time, repeat visit rates, and track trends can all be easily monitored in the dashboard and deeper analysis is enabled with raw data available via simple APIs.
Specifications
| Category | Specifications |
| Radios |
| Antenna |
| 802.11ax, 802.11ac Wave 2 and 802.11n Capabilities |
Note: *40MHz channels are supported only in the 5GHz band.
** Feature is automatically enabled via firmware update to MR 27+ |
| Power |
Note: Actual power consumption may vary depending on the AP usage. |
| Interfaces |
| Mounting |
| Physical Security |
| Environment |
| Reliability |
| Physical Dimensions |
| Security |
* Feature can be enabled by contacting support ** Feature supported on firmware MR 27+ and can be made available on MR 26; see the WPA3 article for more information *** Feature will be made available via a future software update |
| Quality of Service |
| Mobility |
| Analytics |
| LED Indicators |
| Regulatory |
| Warranty |
| Ordering Information |
Compliance and Standards
| Category | Standards |
| IEEE Standards |
* Feature can be enabled by contacting support; see the Hotspot 2.0 article for more information |
| Safety Approvals |
| Radio Approvals |
| EMI Approvals (Class B) |
| Exposure Approvals |
| EMC |
Context and Comparisons
802.11ax, 802.11ac Wave 2, and 802.11n Capabilities
MR36 |
MR44 |
MR46 |
MR56 |
DL-OFDMA, UL-OFDMA, TWT support, BSS coloring |
2 x 2 multiple input, multiple output (MIMO) with two spatial streams |
2.4 GHz: 2 x 2 multiple input, multiple output (MIMO) with two spatial streams 5 GHz: 4 x 4 multiple input, multiple output (MIMO) with four spatial streams |
8 x 8 multiple input, multiple output (MIMO) with eight spatial streams on 5 GHz 4 x 4 multiple input, multiple output (MIMO) with four spatial streams on 2.4 GHz |
Maximal ratio combining (MRC) and beamforming |
SU-MIMO, UL MU-MIMO, and DL MU-MIMO support |
20 and 40 MHz* channels (802.11n); 20, 40*, and 80 MHz channels (802.11ac Wave 2); 20, 40* and 80 MHz channels (802.11ax) |
Note: *40MHz channels are supported only in the 5GHz band. |
Up to 1024-QAM on both 2.4 GHz and 5 GHz bands |
Packet aggregation |
Power
MR36 |
MR44 |
MR46 |
MR56 |
Power over Ethernet: 37 - 57 V (802.af compliant) |
Power over Ethernet: 42.5 - 57 V (802.3at) or 37 - 57 V (802.3af) - low power mode ** |
Power over Ethernet: 42.5 - 57 V (802.3at compliant) |
Alternative: 12 V DC input |
Power consumption: 15W max (802.3af) |
Power consumption: 30W max (802.3at) or 15W max (802.3af) - low power mode ** |
Power consumption: 30W max (802.3at required) |
Power over Ethernet injector and DC adapter sold separately |
Note:
** Feature available via firmware update to MR 27.6+. Please see our Low Power Mode article for more information.
Interfaces
MR36 |
MR44 |
MR46 |
MR56 |
1x 10/100/1000 BASE-T Ethernet (RJ45) |
1x 100/1000/2.5G BASE-T Ethernet (RJ45) |
1x 100/1000/2.5G/5G BASE-T Ethernet (RJ45) |
1x DC power connector (5.5 mm x 2.5 mm, center positive) |
Physical Dimensions
MR36 |
MR44 |
MR46 |
MR56 |
9.84” x 4.72” x 1.42” (25 cm x 12 cm x 3.6 cm), not including desk mount feet or mount plate |
12.05" × 5.06" × 1.74" (30.6 cm × 12.84 cm × 4.43 cm), not including desk mount feet or mount plate |
12.05” x 5.06” x 1.74” (30.6 cm x 12.84 cm x 4.43 cm), not including desk mount feet or mount plate |
12.83” x 5.54” x 1.76” (32.6 cm x 14.079 cm x 4.47 cm), not including desk mount feet or mount plate |
Weight: 17.35 oz (492 g) |
Weight: 26.07 oz (739 g) |
Weight: 28.22 oz (800 g) |
Weight: 35.27 oz (1 kg) |
RF Performance Table
2.4 GHz
Operating Band |
Operating Mode |
Data Rate |
TX Power (conducted) |
RX Sensitivity |
2.4 GHz |
802.11b |
1 Mb/s |
26.0 |
-99 |
2 Mb/s |
26.0 |
-94 |
5.5 Mb/s |
26.0 |
-94 |
11 Mb/s |
26.0 |
-90 |
2.4 GHz |
802.11g |
6 Mb/s |
26.0 |
-94 |
9 Mb/s |
26.0 |
-93 |
12 Mb/s |
24.0 |
-90 |
18 Mb/s |
24.0 |
-89 |
24 Mb/s |
23.0 |
-86 |
36 Mb/s |
23.0 |
-83 |
48 Mb/s |
22.0 |
-78 |
54 Mb/s |
22.0 |
-77 |
2.4 GHz |
802.11n (HT20) |
MCS0 |
26.0 |
-95 |
MCS1 |
26.0 |
-92 |
MCS2 |
24.0 |
-90 |
MCS3 |
24.0 |
-87 |
MCS4 |
24.0 |
-84 |
MCS5 |
22.0 |
-80 |
MCS6 |
22.0 |
-79 |
MCS7 |
21.0 |
-77 |
2.4 GHz |
802.11ac (VHT20) |
MCS0 |
26.0 |
-95 |
MCS1 |
26.0 |
-92 |
MCS2 |
24.0 |
-90 |
MCS3 |
24.0 |
-87 |
MCS4 |
24.0 |
-84 |
MCS5 |
22.0 |
-80 |
MCS6 |
22.0 |
-79 |
MCS7 |
21.0 |
-77 |
MCS8 |
20.0 |
-73 |
2.4 GHz |
802.11ax (HE20) |
MCS0 |
26.0 |
-95 |
MCS1 |
26.0 |
-93 |
MCS2 |
24.0 |
-91 |
MCS3 |
24.0 |
-88 |
MCS4 |
24.0 |
-85 |
MCS5 |
23.0 |
-81 |
MCS6 |
22.0 |
-79 |
MCS7 |
21.0 |
-77 |
MCS8 |
20.0 |
-74 |
MCS9 |
20.0 |
-72 |
MCS10 |
19.0 |
-68 |
MCS11 |
19.0 |
-66 |
5 GHz
Operating Band |
Operating Mode |
Data Rate |
TX Power |
RX Sensitivity |
5 GHz |
802.11a |
6 Mb/s |
26.0 |
-93 |
9 Mb/s |
26.0 |
-91 |
12 Mb/s |
24.0 |
-89 |
18 Mb/s |
24.0 |
-87 |
24 Mb/s |
23.0 |
-84 |
36 Mb/s |
23.0 |
-81 |
48 Mb/s |
22.0 |
-77 |
54 Mb/s |
22.0 |
-75 |
5 GHz |
802.11n (HT20) |
MCS0 |
26.0 |
-93 |
MCS1 |
26.0 |
-90 |
MCS2 |
24.0 |
-88 |
MCS3 |
24.0 |
-85 |
MCS4 |
24.0 |
-82 |
MCS5 |
23.0 |
-78 |
MCS6 |
22.0 |
-77 |
MCS7 |
22.0 |
-75 |
5 GHz |
802.11n (HT40) |
MCS0 |
24.0 |
-90 |
MCS1 |
24.0 |
-88 |
MCS2 |
24.0 |
-85 |
MCS3 |
24.0 |
-82 |
MCS4 |
24.0 |
-79 |
MCS5 |
23.0 |
-75 |
MCS6 |
22.0 |
-74 |
MCS7 |
22.0 |
-73 |
5 GHz |
802.11ac (VHT20) |
MCS0 |
26.0 |
-93 |
MCS1 |
26.0 |
-90 |
MCS2 |
24.0 |
-88 |
MCS3 |
24.0 |
-85 |
MCS4 |
24.0 |
-82 |
MCS5 |
23.0 |
-78 |
MCS6 |
22.0 |
-77 |
MCS7 |
22.0 |
-75 |
MCS8 |
21.0 |
-71 |
5 GHz |
802.11ac (VHT40) |
MCS0 |
24.0 |
-90 |
MCS1 |
24.0 |
-88 |
MCS2 |
24.0 |
-85 |
MCS3 |
24.0 |
-82 |
MCS4 |
24.0 |
-79 |
MCS5 |
23.0 |
-75 |
MCS6 |
22.0 |
-74 |
MCS7 |
22.0 |
-73 |
MCS8 |
20.5 |
-69 |
MCS9 |
20.0 |
-67 |
5 GHz |
802.11ac (VHT80) |
MCS0 |
24.0 |
-87 |
MCS1 |
24.0 |
-85 |
MCS2 |
24.0 |
-82 |
MCS3 |
24.0 |
-79 |
MCS4 |
24.0 |
-77 |
MCS5 |
22.0 |
-72 |
MCS6 |
22.0 |
-71 |
MCS7 |
20.0 |
-69 |
MCS8 |
19.0 |
-65 |
MCS9 |
19.0 |
-64 |
5 GHz |
802.11ax (HE20) |
MCS0 |
26.0 |
-93 |
MCS1 |
26.0 |
-91 |
MCS2 |
24.0 |
-89 |
MCS3 |
24.0 |
-86 |
MCS4 |
24.0 |
-83 |
MCS5 |
23.0 |
-79 |
MCS6 |
22.0 |
-77 |
MCS7 |
22.0 |
-75 |
MCS8 |
21.0 |
-72 |
MCS9 |
21.0 |
-70 |
MCS10 |
19.0 |
-67 |
MCS11 |
19.0 |
-64 |
5 GHz |
802.11ax (HE40) |
MCS0 |
24.0 |
-90 |
MCS1 |
24.0 |
-89 |
MCS2 |
24.0 |
-86 |
MCS3 |
24.0 |
-83 |
MCS4 |
24.0 |
-81 |
MCS5 |
23.0 |
-76 |
MCS6 |
22.0 |
-75 |
MCS7 |
21.5 |
-73 |
MCS8 |
20.5 |
-69 |
MCS9 |
20.0 |
-68 |
MCS10 |
18.5 |
-64 |
MCS11 |
18.5 |
-61 |
5 GHz |
802.11ax (HE80) |
MCS0 |
24.0 |
-87 |
MCS1 |
24.0 |
-85 |
MCS2 |
24.0 |
-83 |
MCS3 |
24.0 |
-80 |
MCS4 |
24.0 |
-77 |
MCS5 |
22.0 |
-73 |
MCS6 |
22.0 |
-73 |
MCS7 |
20.0 |
-70 |
MCS8 |
19.0 |
-67 |
MCS9 |
19.0 |
-65 |
MCS10 |
17.0 |
-61 |
MCS11 |
17.0 |
-59 |
Signal Coverage Patterns
5 GHz - Wireless
2.4 GHz - Wireless
2.4 GHz - Bluetooth®
2.4 GHz - Scanning
5 GHz - Scanning
Installation Guide
For instructions on how to install and configure MR46 access points, please refer to the MR46 Installation Guide.
